Need Advice on Building Road
   / Need Advice on Building Road #11
Yes, neighbor, the old courthouse there is long gone. I live several miles north of Germanton proper near the south side of Hanging Rock State Park. Still a Germanon address.
   / Need Advice on Building Road #12
Since you intend to asphalt this eventually, you could continue whatever was done to prep for the asphalt that is there now if you are happy with that.
   / Need Advice on Building Road #13
For your amount of traffic, 6" of whatever is used locally will do fine. I am torn about stripping too deep, definently strip the sod, but being that it appears to be well compacted already, I dont think I would cut out more than 4", leaving the base material a bit higher.then natural ground. After its paved (i would recommend 1.25" of SP-9.5 or S-3) you might need a little bit of fill yo dress back upto the asphalt.
   / Need Advice on Building Road #14
+1 on your neighbor's suggestion, & btw your soil reminds me a bit of my own.(?) (~50/50 sand/gravel) If fairly well drained, your existing base shouldn't need built up much. When a base is more porous than surrounding soil it can hold water. Coarse stuff will have plenty of voids and may need a lot of settling or compacting to prevent that. (often an issue here in our winter climate.)
'Crusher run' will 'lock down' like few others, and will 'track' around minimally once settled, but it will get dusty if you work it a lot. (in our mushy spring thaw conditions it will resettle/refinish quickly) Don't expect you BB to be the end-all for smoothing. You're bound to get some rippling when using it. If it ever snows down your way use the FEL vs a 'pavement plow' to clear gravel lanes, or let it melt off. You don't want 'curbs' piling up on the sides (with gravel a blade scrapes loose) that won't let rain water drain off to the sides.
Firmly tamping adjacent to asphalt will reduce crumbling & break-off if someone drives a bit wide on the paved portions. Plan to use a fair bit of Roundup to keep weeds at bay, knowing how they'll pop up everywhere, and esp ~12" off the pavement ('chemical trim') to keep an eye on/maintain what your mower will have to cross.
   / Need Advice on Building Road #15
57s and asphalt do not go together they walk or move to much and are good for concrete and French drains. If car traffic only 4 in base if three quarter ton truck 5in at minimum best with 6in. Under cut soil to depth of stone. If you pave it later only minor dressing up will be needed. If low spot holds water put in culvert or French Drain to remove water. If any questions just ask or pm me. Been doing this for a while
   / Need Advice on Building Road #16
You may also find milling material may be a viable alternative and cheaper to
   / Need Advice on Building Road #17
Another +1 on the asphalt millings to 'top' near the buildings. Up here, it's very affordable .. when available. It rolls flat, blends/touches-up easy, and stays put. That's nice where our ground freezes/thaws a lot. btw: I also like that you don't lose so much to erosion while aiming/adjusting drainage & runoff from shower to storm to ??. :)
PS: The guy offered .. :rolleyes:
   / Need Advice on Building Road #18
Personally I would ask the guy that did your asphalt what he recommends given that you plan to pave in the future.
MarkV
   / Need Advice on Building Road #19
MarkV
   / Need Advice on Building Road #20
You are building a house with no truck traffic , interesting .
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
Informational Lot - Financing (A56438)
Informational Lot...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
