Chipper Woodmaxx vs Jinma chipper
/ Woodmaxx vs Jinma chipper #22
I also have a B2920, how's the chipper running these days? I am in the market and trying to figure out what is the best option for my Kubota. Is the hydraulic drive just too much HP for the B2920 PTO?
For 8 inch diameter material ? yes, probably.
Would you REALLY be feeding 8 inch material ?
Most of us can find better use for that size stuff.
See my earlier post where I speculate on power requirements for 6 inch vs 8 inch material (all other factors being about equal).
It is around 14 vs 25 HP.
EDIT: Ooops, just noticed that post was also a reply to your same post as this reply is responding to.
That was last night, I'm not FULLY awake yet.
:END EDIT
I see little/no problem with a $2750 chipper with an 8 inch capacity that is tractor power limited to 7 or 7 1/2 inch material.
Things don't get any "better" by limiting your choice to a chipper with LESS maximum capacity (-:
A side thought on the hydraulic drive.
Once you have another source of hydraulic power you have added opportunities.
Obviously a chipper occupies the PTO and it seems there are times where a hydraulic winch would be SO HANDY for dragging brush to the chipper. I am thinking a couple of hoses, a valve, some simple way of attaching a winch to the chipper's lower frame and you could have a very nice set up.
MOST of the time I would be chipping OR dragging, so this would not be an ADDITIONAL power requirement.
Of course, this would depend on the pump capacity.
I doubt one could run a 20K winch with any useful sort of line speed (-:
/ Woodmaxx vs Jinma chipper #23
:END EDIT
Thanks for the feedback, I didn't ask about any thoughts regarding the options Woodmaxx offers: hydraulic feed or mechanical feed, what's the different? I assume mechanic is only gear diven from pto? What other factors are there between the two options? As far as 8" material is concerned, I would normally burn this size, I'm looking to chip a max of 5", maybe the occasional 6" tag elders that we are clearing out for our deer blinds and shooting lanes. As a general rule, I'm primarily looking to chip lots of 1-3" material, but wanted a machine that gets the job done quickly with minimal effort and efficiency.
/ Woodmaxx vs Jinma chipper #24
Aside from Woodmaxx, is there anyone out there that wants to brag about the pto chipper they use? again, I'm generally looking to chip 1-3" material, but don't want to be limited to smaller material, I will have 4-6" material available at all times! I would like a machine that gets the job done with little effort and efficiently. I have a Kubota B2920, this is a 29 hp engine with 21 hp at the pto. Any feedback is appreciated, I've been down the road where I've bought stuff that is nothing more than a waste of time and effort and ultimately find myself upgrading soon after my "good deal" purchase!
/ Woodmaxx vs Jinma chipper #25
Ya kinda/sorta DID ask about woodmaxx options (hydraulic vs mechanical).
The pump is driven from one of the belts that drive the chipper disc, one of four IIRC, i.e. the disc is driven by 3 belts on the hydraulic version, by 4 on the mechanical version.
The hydraulic version does represent a greater potential load on the PTO, so max capacity is reduced, though I can't tell by how much.
It depends on the length and weight of what is being dragged in and what it drags against, without pump specs it isn't possible to tell what maximum drag the hydraulic feed could be expected to handle - and from that what horse power load it could become on the PTO - subtract whatever that is from the PTO power to get what is available for the chipper itself.
/ Woodmaxx vs Jinma chipper #26
I'm running the Woodmaxx Hydraulic chipper with my B3030 which has 23 hp at the pto. (Woodmaxx specifies a minimum of 19 hp at the pto). I use it mostly to to chip pine and can chip up to 6" diameter pine without any issues. The hydraulic feed helps as I can slow down the feed rate for large diameter pieces. I can easily chip 4" hardwood as well.
Vic
/ Woodmaxx vs Jinma chipper #27
+1 vote for the Woodmaxx brand. Just received ours, assembled it, mounted it, and went to work. It works VERY well on our L3130 (26 @ the PTO). It eats whole trees from small branches all the way up to 5" diameter (a lot of white pine and Doug Fir, some cedar) and hasn't even slowed down. We'll make firewood from about 4" on up. We are working on learning and adjusting the machine to our needs, but the hydraulic infeed was wide open at 36 FPM and never slowed down. I cleared trees for 40 minutes and then helped my Dad feed the chipper which he had been feeding at his slower pace, and it did great.
Had one problem with the Chinese manufacturing: the top infeed roller was mis-aligned on it's driveshaft. This causes that roller to "wobble." This is not a huge problem, and did not affect the short term performance, but we were concerned about long term wear. After a Saturday call and voicemail to Woodmaxx Customer SERVICE, a return phone call and fix was implemented at 0700 local time Monday morning. The fine folks at Woodmaxx diagnosed the problem after checking their records of similar symptoms, and immediately shipped out a replacement top infeed roller, free of any charge and including written instructions from the mechanic on the R & R procedures! This is excellent service. Another excellent and pleasantly surprising feature of this machine: it comes standard with Cat 1 pins AND Cat 2 bushings!
It is not perfect, and is not made in America, but it is as good or even better than your money should be able to buy and is supprted by an excellent company filled with great people offering unexpected levels of service.
/ Woodmaxx vs Jinma chipper #28
Just so you are not misled...that SG guy that says he bought a WoodMaxx chipper is a "shill". Read his note...English is NOT this guy's native language.
/ Woodmaxx vs Jinma chipper #29
What (or who) is "that SG guy" ??? After reading about the WoodMaxx WM-8H --- I'm nearly convinced this is the chipper for me and my Kubota L6060. (English has always been my native language. :dance1: )
/ Woodmaxx vs Jinma chipper #30
I have the 8" Hydraulic Feed Woodmaxx. One nice thing about the feeder is that is has variable speed so you guys with less HP can chip big limbs by slowing the input speed.
/ Woodmaxx vs Jinma chipper #32
I also own a Woodmaxx WM-8H and have put large piles of brush through it. Hydraulic in feed works well and I leave it in max speed. I could have used the tractor's hydraulics as well but they don't offer this as an option.
Largest job is feeding the wood to it as it sucks it in quite fast, and dealing with the piles if wood chips. The chips are quite fine and easy to shovel, scoop up.
Cleat
/ Woodmaxx vs Jinma chipper #33
Received the WM-8H last week. Does a great job.
Update:
I took down 5 medium trees and chipped up the branches in short order. What a great way to get rid of them in lieu of burning brush piles when the conditions are right. I posted in another thread that the only problem is the drive belt for the hydraulic feed roller loosened up on me which was about a 10 min fix.
HP
/ Woodmaxx vs Jinma chipper #34
Just received my woodmaxx hydraulic feed chipper this past weekend. Ran about a dozen old limbs thru it and it works better than expected. I looked at several options before going with woodmaxx. For the cost and getting the 3 year warranty, I feel like this machine offered the best bang for the buck. Plan to give it a good workout in the next several days.
/ Woodmaxx vs Jinma chipper #35
I've been running my WoodMaxx WM-8H for 9 months, and ran it all winter with the weather permitted. A few things to remember grease everything, often. Change the hydro filter often.
Most of what my wife (in the picture) and I run through the chipper is invasive honeysuckle and vine. With the stump end being 2.5-3" and the brush end being yards wide. Sometimes it a wrestling match to get the brush to go through but it usually feeds in perfectly. The chips you see there were the result of about an hours worth of steady feeding.
Tractor is a Kubota L3800 HST (roughly 30hp at PTO).
If you are feeding hardwood in the 4 to 6" range that have dried out you cant feed them at max speed or it will cause belts to slip so I usually just slow the feed down.
/ Woodmaxx vs Jinma chipper #36
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=364923"/>
Great report! I don't use mine in the winter here in Illinois - same model. Looking forward to springtime! Why didn't you choose the orange model? Mine makes that many chips in about an hour. I'd say your wife needs to pick up the pace a bit!!!!
/ Woodmaxx vs Jinma chipper #37
At the time we ordered ours they didn't have orange in stock and was a week out from paint (if i remember correctly).
The wife was always waiting on me and a friend to get the brush cut with chain saws. Yes the feeder works faster than two guys with saws.
/ Woodmaxx vs Jinma chipper #38
yeah, very cool photo.
/ Woodmaxx vs Jinma chipper #39
I have a WoodMax 8" chipper that has only about 10 hours on it, that I want to sell. I want to get a manure collector for my tractor, that is why I'm selling the chipper. Not a scratch on it, blades still sharp. Paid $2,865, will sell for $2200. You pay shipping.
/ Woodmaxx vs Jinma chipper #40
Location ?, Location ?, Location ?
2012 Gastron 18ft Boat w 18ft S/A Boat Trailer. (A61574)
2012 Gastron 18ft...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A61572)
2016 New Holland...
2014 International WorkStar 7500 T/A Dump Truck (A61573)
2014 International...
2021 POLARIS PRO XD 4000D UTV (A64280)
2021 POLARIS PRO...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
