BX25D. Mod #1 and continued.
/ BX25D. Mod #1 and continued. #441
Nice looking modifications.
Did I miss the chipper video? :p
I'm really looking at a BXM32 or BX42 myself.
I think it sounds great, when can you start? :laughing:
How about this comming Monday Ken. Have it in front of the shop door for 8:30 and I'll start. Don't be late :mad: :laughing:
Thanks. Nope you didn't miss it because its not made yet BUT maybe this weekend. ;)
/ BX25D. Mod #1 and continued. #443
Have you considered modifying your steps, I find those on the M Series much less slippery and easier on the feet than those on the GL.
I personally haven't had an issue with the step other than missing it in the dark so I added a led light to it. I only have one step because you loose a step with the 3rd function system.
/ BX25D. Mod #1 and continued. #445
I am going to put truck bed coating on mine.
/ BX25D. Mod #1 and continued. #446
The tractor turned out really awesome.. Although, I still think you're missing a few options! :)
Here's a couple more really cool BX modifications that I'm sure you could definitely perfect with your skills:
* Front Fenders
* Hydraulic Backhoe Thumb
* Bucket Grapple
(Just mentioning it in case you're bored! :) )
* Front Fenders
* Bucket Grapple
I thought about fenders but decided against it because in a wooded envoirment they woud be easily damaged especially with such small wheels as on the BX. If I get really bored later on I may design a set of flexible front fenders anyway plus a set of rear fender extensions.
The Bucket grapple is out for me due to the extra weight it adds to the FEL and the effect it has on the lifting capacity. I have pondered building one out of aluminum though and that would possibly work.
The hydraulic thumb is a definite possibility. I haven't used the mechanical thumb yet so I'll decide after I put some time on the machine.
I have a few more mods to do with the machine but the shop is gone crazy busy and I just don't have the time to dedicate to them at the moment but I'll eventually get back at it. Thanks for the links. Much appreciated.
/ BX25D. Mod #1 and continued. #448
Man me too. I'd love to get my paws on a Kioti. They are a nice machine to put a few additions to. I guess the first for you would be a stack conversion? I'd like to do a double acting stack conversion. install the stack with an exhaust valve on the lower end so when you didn't want the stack in place it could be easily removed if you wanted to go into a wooded area then flip the valve to direct the exhaust to the lower exhaust pipe. Wadda dink Ken :D
For those who haven't followed any on my Kubota 5740 mods here's a break down of what was done.
Custom additions to GL5740 HSTC3 :
- Modified the FEL tubes for storage area's by machining custom caps for the tubes.
- Modified the truck plow to adapt to the tractors FEL.
- Modified the bucket by adding a top guard and hooks.
- Added custom built emergency light bar and LED emergency light to the top of the cab.
- Added L.E.D. strobe lighting to the rear of the snow blower and built custom boxes to house them in.
- Added custom build boxes to the plow so Super Nova L.E.D. strobe lights could be installed adding extra lighting to the FEL side on when plowing.
- Added a reverse beeper. (not a small task on these tractors)
- Added a reverse camera with a color 7" LCD monitor that is also inferred and has a built in microphone in the camera it's self. The camera was adapted to the top rear light making it appear that it was always there.
- Gauge pods were added to each side of the LCD monitor and an ambient air temperature and digital volt gauge was added to each pod.
- Two RAM mounts were added in the cab for mounting various items like my phone and MP3 recorder. Also a new mount was just installed for the new IPhone 4
- A moisture sensing system was adapted to the wiper system so when I'm using the tractor the wipers will work automatically when snow or water is present on the windshields. That way I don't need to be switching the wipers on and off myself. The system takes care of that for me.
- Mud flaps were added to the front fenders to help keep the water off the front glass when traveling the machine.
- All powder coated upper mud flap hardware was removed and replaced with stainless hardware.
- All common steel hardware that was present on the snow blower was replaced with stainless steel to prevent corrosion.
- Some custom badging and company lettering was added to the tractor.
- Custom trim was added to the rear fenders to give it a more refined look.
- Added a parking brake warning light. Well a better one that came with the tractor
- The rear factory lollipop top lights that came with the tractor were replaced with L.E.D. lollipop lights.
- Added a few cool rubber holders on the snow blower to hold a shovel and bar.
- A LED light was added to the cab step so it's easy to see where to place your feet in the dark.
- Fabricated a custom coffee mug holder.
- Designed and fabricated a front bumper with quad flashing LED lights and shackle Center.
- Fabricated an aluminum forward light bar and installed a LED light on it including two side mounted LED alley lights
- Designed and built an LED 4X4 display indicator for the cab.
- Designed a custom LED mount for the snowblower chute. Installed two LED lights on the chute so I could early see where the snow is going.
- Designed and fabricated an exhaust stack conversation kit to for the Kubota Grand L 5740 HST-C3.
- Replaced the stereo system with a Sony X-Plod and Infinity speakers.
- Installed an air horn.
- Added a power plug for charging cell phone at the dash.
- Added rear wheel weights and fabricated custom Center caps for them.
- Custom fitted the floor to accept a new Grammer Air Ride seat.
- Added a rear view mirror
- Added a shock to the front snow blade to eliminate blade recoil after hitting obstacle.
- Fabricated covers to cover up the spring adjusters on the front blade
Have you had any thought about heated mirrors on the outside? I have a L3540HSDC and blowing snow they are often getting coated with blowing snow. I have been thinking about trying to find something to solve this problem.
Yes I have and its a "must have mod" in my honest opinion. I've given it some thought on how I might attempt it so I have a direction to go in. I might have already had it done but the BX came along and took up all my time. It will be the next mod on the Grand L for sure and will be done in the fall :thumbsup:
That wet/blowing snow on the mirrors is a real pain in the
/ BX25D. Mod #1 and continued. #450
Yes, it bothers my "donkey" too!!!! You will have to make a post of that mod and make parts for two. I will let you know where to send the parts and bill when they are ready!!!
/ BX25D. Mod #1 and continued. #451
4shorts; I am coming into all of this a little late, but have to say that your work is AWESOME! I am enjoying the pics, and the detail.
I have a couple of ways figured out in my mind to do it. Might be a good opportunity to go with lighted power/heated mirrors at the same time. Wish I could get at this stuff right away but work gets in the way every time :mad:
Well thank you very much. Its always nice to hear that there are at least four of five people enjoying this thread :laughing:
Oh it made my day seeing your beagles in your avatar. I just love beagles. We always had one but my son has two now. Thanks for taking the time to comment :thumbsup:
Well today is the official day the BX goes to work. It will start its working life by chipping and shredding wood. Wifey looked out the window this morning and said "hope you put fog lights on the BX and chainsaw" I looked out the window and said " well I know what the next mod will be" :laughing:
Anyway I'll snap a few photos for you all and maybe a short video.
/ BX25D. Mod #1 and continued. #453
You'll have start a camera mod thread, camera fog lights :thumbsup:
Well wifey and I put 2.5 hours on the chipper this morning and all I can say is WOW! It's friggen awesome. It's exceeded all my expectations. All the wood was green and just cut and never once plugged. They say the BXM32 is good for 3", well I put a lot bigger in it than that and it handled it for fun. We got a lot of video footage of it in action so I'll try and throw together a video of it later on but here's a few photo's of it and what it can do. The chipper was a joke for the Kubota BX25D as well. I'm impressed. :thumbsup:
/ BX25D. Mod #1 and continued. #457
Looks good my friend. Wallenstein really builds a great chipper. All you need now is to add a hitch to the chipper and make a covered top for your trailer, you'd be all set. Here's what I did for a temporary cover, untill I make one using a fine mesh screen.
/ BX25D. Mod #1 and continued. #458
Woow LED fog lights on a chain saw. This I gotta see.
I love the pic of your son's Beagles! Beagles are like potato chips, you can't have just one!
Now that's a great way of putting it when it comes to beagles and it sure is the truth. Just love Beagles.
Thank Bud. That's a good idea but it would be to small. I'll do similar but with a larger trailer. Man it don't take all day to fill a trailer with mulch. We figured we got a $100 plus of chips today and even started to use them around the property.
OK BUT I'll start another thread for that one ;)
Well after wifey and I did some chipping I decided to take the chipper off and put the back hoe on with the claw I made. Taking the chipper off was so easy with the castor set up I made for it. I had it off and pushed in the shop in no time. Got the back hoe on with the claw and laid down 100' of underground wiring. It was so much easier. Then we pulled up a few roots with the claw.
The BX worked great although it's much slower than the large equipment I'm use to operating but If I wanted faster I just needed to spend another $400.000 and I would have gotten faster so the BX will do just fine for now :D
I got some great HD video to put up but just ran out of time to maybe tomorrow I'll do it. Here's a few photos to bore you all with for now. :eek:
PALLET OF LILLISTON ROLLING COULTER PARTS (A63745)
PALLET OF...
2014 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2014 REITNOUER...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
JOHN BLUE T/A FERTILIZER SPREADER (A63745)
JOHN BLUE T/A...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
