Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #281
What is the weight savings on the 54" with lighter v. heavier steel?
/ Everything Attachments #282
It's about 25 pounds. That may not seem like much but every little bit helps when it comes to agility and maneuverability.
/ Everything Attachments #283
Tim, since you quoted me, I'll give you a reply. I have a 32 hp and think a 54" is plenty for the tractor to lift. But I have not owned one yet. Apparently, EA thinks the same.
I have a JD 3320 with 300CX loader. Would I be looking at the 54" or 60" loader? Also, has there been a change in the steel used on these?
/ Everything Attachments #285
No, the listed weight is for the heavier version. We do not have the ultra light weight updated yet.
/ Everything Attachments #287
Called and talked with Travis just before they closed. He stayed late to answer all my questions and explained why he felt the 54" ultra light was a better solution for my tractor. I'm happy to say that my order is placed and I'm excited for it to arrive so I can get to work!
/ Everything Attachments #288
Thanks Tim! I can't wait to see it on that JD. That will be a perfect combo.:thumbsup:
Travis
/ Everything Attachments #289
Travis/Ted, I saw several posts on various EA threads requesting a 48" grapple with a single gripper rather than the double grippers you have been building. Is there any consideration in building such a 48"?
/ Everything Attachments #290
Ted did think about designing one but the majority of customers wanting 48" grapples have small tractors generally without quick attach and he isn't interested in doing any custom mounts at this time.
Most customers i've talked to prefer the double lid design, especially with our 54" Wicked Grapple being as light as it is.
I wouldn't totally count the 48" out for the future, but the next grapple out of our factory will be a C shaped grapple rake like the Bradco Compact Root Rake. It was supposed to be designed and on the market already but has been pushed back because we've been so busy this spring.
/ Everything Attachments #291
Thanks for the reply. I understand about not wanting to make custom mounts. I already have a SS QA, which is one of the reasons for wanting the 48". For my tractor the QA takes up some of my lift capacity so I was looking for something as light as possible. I will see what you come up with in the future, I am not in a hurry.
/ Everything Attachments #292
What size tractor is this new grapple going to be rated for? I am looking for that style grapple but the link you gave said it was rated for up to a 55 hp tractor.
I like the price of the wicked grapple but not sure what tractor it is rated for. Or should I be looking at the heavier duty Bradco units?
Thanks!
/ Everything Attachments #293
/ Everything Attachments #294
I will probably go with the WR Long RBDG 84, it's the style I want. Thanks for your time.
/ Everything Attachments #295
I plan on purchasing a "C" shaped grapple in the near future. I am currently recovering from a smashed foot and it has given me time to think about good grapple designs. I have used a flat bottom grapple and a "C" shaped on different equipment, 30 years in the tree business. I prefer the "C" shaped.
Traditionally "C" shaped grapples have one long top grapple. this is to allow back dragging. I like the flexibility and of twin top grapples to better grab material. Wondered if there was any way to incorporate a twin top grapple into a "C" shaped grapple design. Of course this may add tothe cost but may make a great product.
I Stand Alone
/ Everything Attachments #296
I Stand Alone
/ Everything Attachments #297
I Stand Alone
That was mentioned in another thread and Ted likes the idea. I think he plans to design our C shaped grapple rake so you can use it with twin grapple lids and also have the option of pinning them together as one solid lid.
Travis
/ Everything Attachments #298
I have a question about tractor size and your implements.
I have a Mahindra 2516 25hp and with loader and loaded tires it's around 2500lbs I believe. The width from the outside to outside back tires is 54.3 inches.
I'm looking at a few implements from your site: your extreme duty disk harrow,root rake,cultipacker and brush hog. The harrow, root rake2.0 and cultipacker are the ones you build, and I'm looking at the Cain brush hog.
My question is what size in each of these implements will fit my tractor without beating it up?
Thanks
/ Everything Attachments #299
Thanks
I would go with 60" in each of those attachments. You can use the Xtreme angle iron harrow with 16" or 18" blades which is wider than 60" but will be fine. If you want the heavier Xtreme box frame harrow with adjustable gangs, i'd stick with the 16" blades for your tractor.
Travis
Status
2015 Ford F-150 Ext. Cab Pickup Truck (A64556)
2015 Ford F-150...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
UNUSED JCT DB600 DUSTLESS BLASTER (A65055)
UNUSED JCT DB600...
