Let's See Your Workbench
   / Let's See Your Workbench #31
went out to the shop to take a picture of mine but I could not find it maybe later.
Yes, mine does similar tricks - takes days to find it again.
   / Let's See Your Workbench #32
Shopfox workbench leg set $159 plus Grizzly 72x30 inch maple top 1.75 inches thick $199 both purchased from Grizzly. I have owned two of these, the best workbench leg set value out there, Heavy Duty is not an understatement.
   / Let's See Your Workbench #33
Workbench??????--Whats that??? thanks; sonny580
   / Let's See Your Workbench #34
My pole barn is going to be built in the next couple months and I've been contemplating different work bench options. I was hoping you guys could give me some ideas. So let's see 'em!!!
This is my little shop, the tops are 2x12 syp, the doors, rail & styles are spruce, all have 3 coats of poly for durability, I also put full access sliders in as storage in a small area was critical.003.jpg004.jpg005.jpg006.jpg
   / Let's See Your Workbench #36
I agree, Bird
David Sent from my iPad using TractorByNet
   / Let's See Your Workbench #37
Thanks guy's. I do believe you both have a good space to accomplish your desires, mine is a place to just let it loose and enjoy, this took me 1-1/2 years to complete and I still find myself looking at ways to make it more efficient.
   / Let's See Your Workbench #40
My bench can really hide from me, I can never see the top, and I think it moves somewhere else while I am looking for it! :laughing:
It is an old gurney with the top removed, and a 8' solid door on it.
I put everything on casters, so they can be stored pushed together in a small space, then pulled out with room to use it, when needed.
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
