SPIKER
Elite Member
Hi All:
Well after greasing up the house shower & having to make trips in all time I'm going to fix up a Utility/Shower/Bathroom in the barn.
I already have it walled off and it has cold water & a Sump Pump going into a small underground grinder pump back to the septic system.
Issues I have are already finished concrete floor (With Sump Crock & single thrown sewer connection in the concrete.)
I'm planning on building/framing a 3'x4' corner shower/TILE SURROUND, I was planning on NOT tiling the floor as it is concrete already. Besides Grout how do I SEAL the bottom of the walls/Tile to the concrete floor without it leaking and getting up into the stud walls? PLATES are all Treated Lumber with CUT Concrete Nails & GLUED DOWN and Standard Nail Gun Nails into untreated vertical studs been in for over a year~16months. The FLOOR has a Water Based Stain & Top Coat Clear Sealer that is somewhat slippery when wet Real Slippery so adding TILE MAY HELP. I'm using 12" Ceramic TILE & Store has several options for the Mastic-Adhesive but not sure which would be best. This shower will be a DOG Wash and ME mostly after working in barn or on car etc.
I COULD Tile the floor but wasn't planning on it & don't see the need since the floor is sealed & coated concrete with no cracks (18months old.)
ALSO 1 Wall is OSB & I was thinking to spruce it up Taping the joints with Durabond90 and Tile Tape. then Skim Coating the entire OSB Wall with the Durabond90. followed up with a coat of white paint this will be the interior wall of the barn & will hold tools on the other side of the wall.
I have the NEW Lightweight 1/2" Tile Backer Board DUROBoard not yet installed, should I use PL400 Glue under it on the Studs & OSB or just the DUROScrews? Any recommendations for best place to get the GROUT and ADHESIVE-MASTIC for the tile, I have Menards, HD and LOWES all local. The Menards Price for Version3 Tile Adhesive was almost 40 bucks a bag (a bit expensive I thought.) I'm heading out tomorrow for some DUROBond90 for the wall & would like to get the tile mastic then as well.
I'm not in a major hurry so looking for thoughts on this one. Also will be adding old washer & drier in there & HOT water (Instant on type) as I get some deals to wash Greasy Work cloths. These are all going in a 110" x 14' room in one corner of my Pole Barn.
thanks
Mark
thanks
Mark
