sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,429
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
I've just been thinking about tractor weight but you're right on about that, sd455dan.
yeah For some reason? every time i had to haul the ford or rhino the darn things ended up with something attached to the 3 point
seriously tho I have to wonder where these GVWR come from (I know the manufacturer) but why is it so hard to find a hard # for the the individual trucks -like on the same sticker the GVWR is on ,and I personally believe there should be a 5thwheel# , goose neck # and a conventional # right on the sticker...on any HD rated truck imo
and I also think- as apparently Dodge and GM maybe Ford to- that there are allowances to be made for towing with GN or 5th wheel trailers on some 3/4 to 1 tons (engine, trans differences)
That MAY be more about warranty- and the manufacturer has to consider short haul- the same as driving across the continent
these trucks share the same hd brakes hd frames, hd full floater rear axles, hd front axles, hd springs, e rated tires (starting to sound like the thread on Rental Yards only allowing 3/4 and 1 tons to haul) but as has implied the tow rating or GCWR is written in stone but if in stone ) why do the county, state have no problem ..Legally licensing the truck /trailer - in my case 26,000lbs. and my truck is only GVWR at 9900lbs. 700 more than your truck
One more question how far -on relatively flat roads are you actually planning to tow your tractor/equipment??
