What size gooseneck trailer?
/ What size gooseneck trailer? #11
No, the tow rating is the tow rating. Can it pull more? Sure.
You get no credit for load on the ball. Your 10,500# rating is just that.
Legally.....
Chris
/ What size gooseneck trailer? #12
Legally: 2004 Dodge 1 ton registered for 16,000 lbs GVWR
Legally: 40' Gooseneck trailer registered for 20,000 lbs GVWR
Legal: GCWR- 36,000 lbs
Truck: empty 8,000 lbs
Trailer: empty 8,500 lbs
Legally cross CMV scales in multiple states grossing into the 30k range. I know law suit blah, blah...OK if the trucking companies have been sued and lost, I don't think this would be possible to do today. Yet its done everyday.
OK I am going to bow out of this thread, I just get a kick out of everyone preaching tow rating as the gospel.
The OP, your truck will do more than fine. Just get a good trailer and brake setup and you will be safe.
/ What size gooseneck trailer? #13
Hello all,
I definitely want a gooseneck and I like the idea of a low profile deckover but I dont know if my truck is big enough for that. I know a diesel truck would be the best but I need to make do with what i've got for the time being. My truck is a 2001 reg cab, long bed, chevy 3/4 ton HD with the 6.0 gas engine and 4.10 gears. Its in good shape and has only 48K miles so I'm confident in its abilities up to its ratings at least. (No hills to worry about around here) Door sticker says the GVWR of the truck is 9200 lbs and the manual says it can tow 10,400 lbs.
Low profile deckover seems to be a contradiction of terms. Do you have any pictures, or links to look at?
You need to put your truck on the scales with a full tank of gas. Also get the weight on the front and rear axles. I used the scales at the local co-op.
Here is mine, 2006 GMC short bed 3/4 ton HD 4x4 diesel, 7300 lbs, front 4100, rear 3200.
The link to my trailer, read #18, #28 and #34: http://www.tractorbynet.com/forums/trailers-transportation/273476-stand-up-slide-ramps-2.html
/ What size gooseneck trailer? #14
The thing you will find that really limits your capacity is your brakes #1 and your pin load of your trailer #2. I have a 14.5kGN that weighs about 5400 lbs and it would carry alot more than my SRW one ton was happy toting around even with air bags and 10ply tires. If you ever felt a one ton rear end get squirrely and mushy thats enough to pucker your *** let alone trying to panic stop that mess. You can easily find a 12k GN or 14k gn (which are more prevelant). License it for what your state will allow (pa goes by the manufacture's gcwr) and be on your merry way. Just add what your truck weighs to what your trailer weighs and subtract it from your GCWR. Thats what you can haul. IMO GN's pull so much nicer than bumper pull trailers do even though DP and I disagree about that from what I recall. Now if your flirting with that upper weight limit, you might need to consider upgrading in the future. There are hundreds of stories of guys pulling a yacht with vw beetle (exaggeration) and it works great for them. My question to them would be, how fast can you whoa that horse? Trailer brakes be damned, if you have a wire come loose and you are on truck brakes alone, are you going to be able to stop it at all? So to beat a dead horse, your tow rating, is your tow rating is your tow rating.
faxman, a Low profile deckover is exactly what it says. On my trailer, the axles are actually recessed into the mainframe and there are metal plates over the tires where the decking stops to give you more clearance. Now its only about 3" lower than a full height deckover, but as they say, every inch counts! lol
/ What size gooseneck trailer? #15
Everybody can tow whatever trailer they want - that is human nature. You can legally register a truck for towing a large load trailer, everyone knows that - just look at the pickups staggering up grades in the west, with a huge loaded trailer behind them. But. Just because you can do it, does not mean it is safe, or a good idea. If, heaven forbid, you have a wreck with anything that exceeds the manufacturer's rated load, the insurance will NOT pay up. As the insurance will not pay, whoever you hit collided with an uninsured vehicle, for which you will be cited. So, yes, you can tow anything you want, and probably won't get pulled over for a 'reasonable' load, just don't hit anything.
/ What size gooseneck trailer? #16
Ok, thanks, I have seen those.
/ What size gooseneck trailer? #17
Hello all,
Sorry for the elementary question here but I've not got much experience here pulling heavier loads and none with gooseneck trailers. My question is what size trailer do i need to be looking for to match up with my pickup? The heaviest thing I would need to tow is a JD tractor that weighs approx. 9500 - 10000lbs. I do not ever see myself having to haul anything heavier than that.
I guess the main thing I'm wondering is can you add those 2 numbers (9,200lbs + 10,400lbs = 19600) and then subtract the actual weight of truck (with passengers and cargo) to come up with the amount of weight i can tow? I dont know exactly how much the truck weighs but I read somehwere the payload was 3950lbs so, for example, that would make the truck come in at 5250lbs empty. Add another 500 for passengers and now I'm at 5750 lbs.
So does that mean i can tow 13,850lbs (19600lbs - 5750lbs = 13850) worth of trailer and equipment?
Doesn't your GM list a Combined Gross Vehicle weight? If a 1/2 ton Ford on p rated tires can legally tow 13000lbs. I'm sure your goose neck equipped 2500 hd 4.10 equipped truck with (_ ply tires) can pull that set up, gvwr as I was informed does not limit trailer towed weight as much as it does payload....
/ What size gooseneck trailer? #18
Actually no. The GM 3/4 tons of that era were rated quite low compared to what is offered after 2008.
Chris
/ What size gooseneck trailer? #19
My owners manual allows 16000 gcwr for those 3/4 ton gas trucks.
/ What size gooseneck trailer? #20
Well it sounds like, no matter how you slice it, if he wants to stay within the factory advertised ratings. He will be overweight...As others have said goose necks pull nicer than bumper pull, my guess is if he tried a bumper pull at his max rating and then tried a goose neck with the set up he is planning (overweight) he would find that the truck / trailer feels safer with the goose neck even though not meeting the factories guidelines, the #s he's quoting are where a goose neck and 5th wheel are both just getting started, that should count for something... then again guess it still comes back to the trucks rating
EDIT : new info from edmunds suggests it may very well be within tow limits suggested by gm for 5th wheel trailer towing see last post..
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
