BX25D. Mod #1 and continued.
/ BX25D. Mod #1 and continued. #41
Just saw this thread ... awesome work as usual 4shorts. I love the ripper tooth, and beautiful welds on that! If you compared mine to yours - mine looks like chicken scratch! :laughing: I like the doubled up plate at the tip end.
As for the armor plate - I realize you have no plans for MMM- now dont get me wrong , the plate looks great and it appears to be substantial. But I cant help but wonder about the last plate covering the MMM shaft. It only held by two bolts in front? In T slots? I don't doubt your reasoning for doing it - but whats the purpose of t slots since from pics it doesnt look big enough to slip in on the bolt while still in? whats to stop the brush from wiggling its way in the back and bend it out? The front and middle plate looks good though. If you had to do it over again, would you be able to punch in a curve for the MMM
shaft so it can be used at the same time?
Thanks. When I was designing this the main goal I had was to protect the HST fan but ended up with the forward and rearward plates. These plates are 1/8th thick and it will take something very substantial to bend them. That being said there's nothing that's completely perfect. I can remember operating a Cat D-9 one time and tore the undercarriage out of it.
I didn't think the vendors out there selling plates for the BX's were substantial enough or my needs so that's why I went this route. The T slots were punched to make alignment easier during installation and I doubt very much a branch will move any of these plates. If they do I'll redesign :D
Wonder why no shackle hook on a back hoe bucket? Used to operate excavators with them. They were handy to have. Well I got one now :)
/ BX25D. Mod #1 and continued. #44
Paul, very nice job as always. I am curious about the comment on the available units. The BXpanded Under Armor is made of the same 1/8 thick steel.
No offense to you but I didn't say all of them. I was just generalizing and didn't mention any names. Just the ones I looked at. I didn't consider yours.
/ BX25D. Mod #1 and continued. #46
Great work as usual Paul. I often wonder if the reason they don't offer options like this is so they can sell more parts. I will be waching for the rest of your mods. As clean as you keep you equiptment, I keep wondering if after the first job you will let it sit in the shop with the bucket all scratched up or if it will eat at you untill you put a coat of paint on it.
Bill
Bill
Thanks Bill. You might be right on the selling of parts but I think they're missing a great opportunity by not selling more accessories as well. That would be my dream job. Finding accessories for each model :D
This will be my summer tractor so it will get used but when it goes to sleep for the winter and the 5740 comes out to play I MIGHT paint the scratches in the bucket before I park it :eek:
Great hearing from you buddy :thumbsup:
Well I got a spill guard on the bucket tonight. Spill guards have saved my butt in the past and i put one on the 5740 so I figured why not :D Hooks next.
/ BX25D. Mod #1 and continued. #49
I like the spill guard Paul.
One thing though.. Personally, ive never spilled much if anything off the back of my BX bucket. :eek: I know the spill guard and cutting edge didnt add much weight, but IMHO the BX needs all the lifting capacity it has, I notice a difference between my tooth bar is on or off. You might want to look at beefing up the lift capacity to go along with the mods, Im interested in seeing what you come up with if you go that route.
Im a little under the hyd pressure spec right now and Im going to add a few shims once I get them ordered from Kubota (they're super cheap, well under a dollar each). Should give me about 100psi more which I imagine will make a noticeable difference. Then the question becomes, if 100psi is good, why not add 200psi;)? Did you check your hyd press yet?
I actuallly have the kit here to test the hyd system and I'll do it this weekend. It's most likely needing an extra shim. If its like the other machines I've owned it's set up undered powered. I'll report on what my findings are once I do the test. I have a 3540 out by the shop now with the hood beat up on it due to debris falling off the bucket. I guess I'll be putting one on that machine as well :rolleyes:
Thanks.
/ BX25D. Mod #1 and continued. #51
best thread i've read in a while. man i'm jealous!
/ BX25D. Mod #1 and continued. #52
Nice job. I like the Ripper and the under side protection. I am going to build some additional protection for mine. I think it would be tough to get something up into the fan but extra protection never hurts.
/ BX25D. Mod #1 and continued. #53
When I grow up, I aspire to do nice work like that. I would like to see the YouTube video of the ripper in action. I can imagine the little BX doing a lot of the moving instead of the root. I have thought of similar ideas and may sharpen my backhoe bucket edges to help cut the roots. Any thought of putting an edge on that ripper or is it more for loosening up the ground for FEL work?
Hey I'm happy to hear your enjoying it :thumbsup:
Thanks Roger. Ya why take chances. Just well to put the protection in place and not have it on your mind every tie you get in a bad area. Even tall grass can take out those fans.
Ha. Thanks David. There will be videos on my YouTube channel for sure of the ripper tooth in action. When I was building the tooth I thought about adding cutting teeth to the front portion of the tooth but decided not to because this tooth will be used not just for roots but to dig in stubborn ground and I felt that would dull the effectiveness of the teeth. I may just design a special tooth just for roots. I have a few ideas I'm toying with. :thumbsup:
/ BX25D. Mod #1 and continued. #55
This is great, I go to bed and the next day you have something else for me to see. ( and do ) Awesome work as usual.
/ BX25D. Mod #1 and continued. #56
Paul- as always, I am enjoying your projects. Can't wait to see what else gets improved on the little guy! As for my own puny trailer project, I posted it in the trailer forum under Cheap, Serviceable Trailer. Getting ready to build some treated wood sidewalls, when my eBay hot-dipped galvanized carriage bolts show up.
Thanks buddy. Here's another one for ya :D
Thanks Varmint. I'm heading over to have a look. :thumbsup:
I'm going to title this mod "Thinking Inside The Bucket"
Installed the bucket hooks. I went with two 5/16th weld on hooks for each side of the bucket and they are attached in line with each FEL loader arm. In the center I went with a 11.000 lbs swivel ring. I placed it in that area because that's where the thickest part of the bucket happens to be. All the holes were punched on the Edwards iron worker and the weld on hooks were pulse welded on a Millermatic 350P. Galvanized carriage bolts were used for the installation.
Placement of hooks on any bucket is based on personal preference in my opinion and the placement of my hooks are right where I wanted them and yes, inside the bucket and out of the way
Here's a few more photo's.
/ BX25D. Mod #1 and continued. #60
Where did you find the weld on hooks? I looked all over for them locally. Expensive?
Ballymore Man Lift (A65579)
Ballymore Man Lift...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
17.5X25 industrial tire on Deere articulated loader rim, Coal Valley, IL (A65640)
17.5X25 industrial...
