BX25D. Mod #1 and continued.
/ BX25D. Mod #1 and continued. #1
4shorts
Elite Member
Bay Roberts, Newfoundland
Kubota 5740,BX25D
I'm calling this mod #1 although I already got a few others done but I'll post on them later.
This is a ripper tooth I fabricated. It's pretty well built from scrap around the shop. It weighs 36 lbs so that's not to bad considering the bucket weighs around 40 lbs. As you can see I also added a replaceable tooth. I figured it was better to do that rather than wear out the bottom of the tooth. I had planned to add the ripper tooth to the bucket but changed my mind because if I did it that way I would get the benefit from my thumb plus the change over from bucket to tooth is less than 5 minutes.
I guess the pictures will tell the story. In one photo you'll see a small shaft I machined. I threaded each end to hold the pin keepers in place that way I wouldn't have to use a nut on the inside to fasten the bolt plus the solid 3/4 shaft will add some strength to the mount. I made the tooth out of 1 plate and cut it with the Miller plasma. I welded it with the Millermatic 350 P in pulse mode and I included some photo's of how the welds look. I should have taken a few more photo's but when I'm doing something like this I sometimes get so involved in it I loose track of time and forget about the camera
Anyway you'll get the idea. I figured I'll use this on some tough ground and aiding in pulling tree roots. A big thank you to my lovely wife for designing and cutting the graphics. :thumbsup:
I add photo's of more mods as time will allow.
/ BX25D. Mod #1 and continued. #3
Wow! Very cool. I am super jealous of your skills. I love the posts and pics. Paint job looks fantastic, what do you spray it with?
Thanks man. I just load up a HVLP gun with some enamel and shoot it. it's almost a waste of paint to do it becuase once it hits the ground trhe paint will come off but hey, it was a Kodak moment :laughing:
/ BX25D. Mod #1 and continued. #6
I hear a ripper tooth like that works good on shearing roots, and is much better than a bucket for that task.
Very cool work as always.
/ BX25D. Mod #1 and continued. #7
Paul, looks great! As usual excellent workmanship! Stanley
/ BX25D. Mod #1 and continued. #8
Man, What A Tooth! Looks good Paul, now I want one for my BH.
I am so copying you on that :mischievous:
Go for it my friend. That's why I post this stuff. Sharing ideas :thumbsup:
Thanks Matt. That's the reason I needed a ripper. Glad you like it.
Thanks Stanley. I appreciate that. Glad you liked it as well. It was a fun project. Only twenty more mods to do lol.
Thanks Ramsay. Oh ya. I can see you using one of these. Wonder where you could get one ;) For those that don't know this guy he happens to be a long time customer of ours and a close friend.
/ BX25D. Mod #1 and continued. #11
Excellent job with the ripper tooth! I really like the design and wish I had one for my backhoe.
While I don't own a BX, it makes me want to buy one knowing all the really cool mods you have in store for it! Again, nice job and keep up the great job of posting all your work!
/ BX25D. Mod #1 and continued. #12
I can't wait until you put some video of that puppy in action on YouBoob.
I might expect Sigourney Weaver to come out of the corner, battling that thing.
Nice job.
Thank you very much. I'm happy to know your enjoying it. I'm like all you guys in the way that I enjoy seeing photo's so it's nice to know at least a few of you are enjoying it :thumbsup:
Nice job.
:laughing: Good one. When I get all the mods done the vids will start pouring in. Promise. :)
I'll call these lot of photo's a mini mod.
Don't worry. It will start to get more interesting in the next few pictures I post.
The one thing I see a lot of in the shop are guys wearing out the lip of there bucket due to the lack of a cutting edge. It's much cheaper to install a cutting edge than it is to repair a bucket and if installed properly you can reverse the cutting edge when the outer edge wears to the point of uselessness.
I couldn't get the right length of cutting edge so I went with this one and cut it to fit. As you can see I used a horizontal and saw and kept the cutting fluid on while it was doing the cutting. it was the only way to save the blade. I could have used a cut off saw but I don't find them to be very actuate and the band saw is dead on and clean as you can also see in the photo's. You'll notice I put a rubber gasket on the bottom of the bucket before I installed the cutting edge. It really wasn't necessary to do that but I had the rubber in the shop plus It will keep any debris from getting between the edge and the bottom of the bucket. I also didn't show drilling the holes in the bucket. I figure you've all done similar things to that before plus drilling is really "boring" lol.
This is just the start to the bucket mods and I'll be posting more in the coming week. At least now I won't be wearing out my bucket.
Hope you enjoy the photo's.
/ BX25D. Mod #1 and continued. #15
It's beautiful work but I would be concerned about all those bolts sticking up. I use my bucket to haul around stuff like air conditioners etc. and this would be pretty hard with those bolts. Plus, if you're moving around big rocks or other such stuff I could foresee damage to the bolts. Well, just my opinion anyway!
Sent from my iPad using TractorByNet
For me its not an issue because I use a fork lift or the QC forks on the tractor. It's hard to avoid bolts on a bolt on cutting edge and when the time comes to turn over the cutting edge I usually just cut the bolts off and replace them so daae to the bolts are a given and is expected. It takes about 20 minutes to remove the bolts, turn the cutting edge around and install new bolts. I still think its much better than wearing out the lip of the bucket which will take a day to repair and repaint. Even our 5740 has a bolt on cutting edge.
/ BX25D. Mod #1 and continued. #18
Wow- I was going to post some photos of my new Harbor Freight 4x8 trailer assembly and the little additions I made, but Paul's work is so fine, I am embarrassed to waste people's time with my junk. Not only are the welds perfect, but the photos are really good, too, which makes the posts even better. Keep up the sweet work! I have bolts/nuts in my bucket from attaching the tooth bar, and I think I would have used flat head allen bolts, threaded into the bucket's thick lip, if I had to do it again. I think that would work?
/ BX25D. Mod #1 and continued. #19
4shorts-
All of the mods you have made on your tractors are extremely creative, innovative, etc. They are well thought out and not just "bling" that serves no purposeful function. Your creativity and ingenuity are enviable. Your fabrication skills are outstanding also. From the materials you use to the impeccable craftsmanship your mods are amazing. I wish I lived close enough to you to see if I could get you to do some mods on my L3200 HST. I would like to have my tractor "tricked-out" with some of your mods (tool box, lighting, cutting edge, etc.). I could follow your lead, but I don't have the craftsmanship or tools to complete them as accurately and neatly as you do. Your improvements are professional and factory quality.
Keep up the good work and keep the photos and videos coming.
/ BX25D. Mod #1 and continued. #20
What bucket size and model tractor was the cutting edge from? Also what were the original dimensions of it? If i had to guess I'd say it started off as 54" x 6" x 1/2" but not positive.
Great job once again!
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
