syncroshuttle question
   / syncroshuttle question #11
Massey synchro shuttle definitely needs to be clutched, you might do it a few times without clutching, but i wouldn't recommend it.
   / syncroshuttle question #12
I went out and drove it this weekend, yup, I clutch it. Funny, it's something I do out of habit, and sitting in the computer chair I can't do remember it....
Must be the age kicking in....:laughing:
Now, why did I come into this room.......:rotfl:
   / syncroshuttle question #13
Syncro Shuttle is best described as a manual transmission that has a separate lever to shift forward / N /reverse in any of the gears that you are in. The clutch is needed for any shifting.
Power Shuttle is similar to the Syncro, except you can use the forward / N / reverse lever without clutching. Shifting between the individual 12 gears requires the use of the clutch.
   / syncroshuttle question #14
koodos to you for admitting a mistake. So often people will dig their heals in or not come back to thread rather than admit a mistake.
Now are you sure with yours you need to? I thought all the 12X12's were power shuttle?
I drive a tractor with a power reverser that a friend owns, and I find it much easier on me and the machine to use the clutch myself. The power reverser is just to hard of a change of direction.
   / syncroshuttle question #15
You are right - the 1635 is the 12x12 POWER-shuttle, but I noticed I still clutch it - "old habit's die hard". I went and double-checked - and no, I don't have to clutch - even when I'm wrong, I guess I'm right - except that I can't remember what transmission I have! I only remember the 12x12 part (now about that 6x6 Ram I always wanted.....). Power-shuttle is thus described:"Changing the direction of travel is as simple as slowing the engine and moving the lever in the desired direction of travel, so it痴 perfect for loader work." :thumbsup:
I was thinking I need to go to the barn and pull out the manual again and re-read if I need to clutch or not - but it snowed again this morning and I just didn't have the gumption (or the body heat any longer) after being outside all day.....so I looked it up. :eek:
And I have no issue admitting when I'm wrong, heck - I'm married.:laughing:
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
500 BBL FRAC TANK...
Boom Lift (A59228)
Boom Lift (A59228)
Box of Transport Ratchet Straps (A59230)
Box of Transport...
48" Pallet Forks (A59814)
48" Pallet Forks...
