TPMS
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
Has anyone had any problems with their vehicle's TPMS sensors or had to have sensors replaced ? If you had to have the TPMS Sensor/sensors replaced. what was the cost ?
My 2007 Toyota is my 1st vehicle with this system. I began to read up a little & learned the battery life is about 5-7 yrs. I called local Toyota Stealership to learn that for them to replace the TPMS sensors, it would cost $200.00 per wheel. That's for the sensor and programed to the ECM. Cost of new vehicle ownership went up when the government mandated these sensors be installed
On my GM apparently you can find the aftermarket sensors for 3/4 of the price on ebay etc. You dont need the toyota ones you just need to replacement aftermarket type. Just like other aftermarket sensors.
My neighbor had 1 go bad on a 04 Lincoln. I got one off EBay and changed it myself and programed it. I remember using a old speaker for the magnet in the process.
From what I remembered it was only $30 or so.
Chris
/ TPMS
From what I've been reading and have been told. The newer ones have to be linked to the ECM be means of a device much like a code reader. You can buy these after market TPMS code readers .( about ($230.00) to diagnosis TPMS sensors issues ,(dead batteries,etc,)for some vehicles. Toyota is not on the some vehicle list. If I were to purchase the after market sensors and install it myself for about $50.00 ea. Toyota dealer says. there's no guarantee that their code reader will link up with the after market sensor. It appears that Toyota has Toyota owners by the Gonads until, someone comes out with a after market code reader
Check with your tire guys. Lots of people here have summer and winter wheels and have no issues.
Chris
You can buy Toyota TPMS sensors off of ebay for $25 bucks or so. Any tire shop will also have them as well as the tool to program your Toyota.
/ TPMS
As stated earler.Per Toyota dealer. If These aren't Toyota OEM sensors their system may not read the sensors. Then,I would be stuck with sensors that they can't read.None of the tire shops (that I have called) can program toyota sensors.They tell me they send their customers to the toyota dealer
Chris. On the Toyota fourms. I have read that they just deal with the light or take the dash out and put tape over the light when they change rims or change from summer tires/rims to winter tires/rims
1 guy took all his sensors off and built a cylinder.(looked like 4''pvc with caps on the ends) Put all his sensors in the cylinder filled it with air and mounted it in the bed of his truck
i remember going thru this a few years ago when the valve stems corroded so bad they needed to be
replaced, i took the sensors out of the truck and put in standard valve stems and lived with the
light on the dash. i did read that there was an easy fix, something about finding the right wire under the dash
and grounding it to the body to make the light go out.
i don't plan on keeping my trucks long enough to deal with them any more!
No, the people I know have sensors in both sets.
Chris
I have summer and winter tires on my Vibe (Toyota), my Tahoe, and my CTS. I bought the winter tires at Costco (Blizzaks). I bought extra wheels for each, too, (eBay) so I needed extra sensors for all 3 vehicles. I change the tires over by myself and the guy at Costco resets the TPMS on the cars for free. I give him a tip for the excellant service. Each car behaves differently if you don't reset the sensor maps. Some count rev's per mile as well as pressure. That's another way to determine whether a tire is slowly going down by comparing it to the other tires on the car.
On the Tahoe, there are aluminum valve stems. I had put a stainless steel valve cap on the stem and after a year it BROKE when I tried to remove the cap. I bought a new one from eBay and replaced it myself. On the Caddy, I also rotated the tires front to rear and it caught the change. You can reprogram the system using the car's controls. You bleed down a tire until the horn toots and that tells you it has matched the sensor with the wheel position.
Done.
/ TPMS
I read about unplugging a wire from under the dash somewhere.I've been driving since I was 14 .I'm now 55.I think I'll be ok without this stupid system telling me if I have a low tire or not. I know how/when to check tire pressure.Been doing it for yrs
Amen to that!
Remind me again what year they started mandating this?
I'll have to add that to my list of cars not to own "newer than this year"
2008 and newer.
It's a really nice thing to have when you are driving home from vacation at 2am and the system alerts you to a low tire before it becomes a serious issue.
I work on the things everyday, and other than people who bring them in for low tire lights because they are too lazy to check the pressure themselves, I have no problems with the system.
I really loathe some of the Fords that have the stupid $30 clamp holding the sensor to the wheel.
/ TPMS
Well,The auto makers tell us that tires are made much better now days so, there's no need to carry around the weight of a spare tire in the trunk so, you can save fuel. We,ll put these tire sensors on so, you'll know if your tire is going down and can get it repaired. For the cost difference. Take the sensors off and give me a spare..
This reminds me of all the stuff I get from sales people to keep my customers calling me for service. Tell the customer how it will benefit them for adding this to their plumbing system or their a/c system. They will have to call you every year to keep the system serviced and you'll make XXXXX$$$$$$. I'm not about trying to take customers $$$ to sell them things on their plumbing or HVAC system they don't need
I'd bet it's got as much to do with packaging that spare and weight savings.
Cars are just getting heavier as they get safer.
The TPMS are good for people that never check air pressure. These are the people that would have only 10 or 12 lbs in their tires and never knew it until something happened.
There are aftermarket tire sensors out with significant cost savings over oem. .Some come in the "learn mode" and others can be cloned to match your sensors you are replacing including Toyotas. Both of which you just bolt on an go. Check with a reputable tire dealer or a quality auto parts store.
Or when you hit something and don't realize it.
That can save a tire. Or prevent you from being late to work by alerting you the night before of the slow leak.
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2011 Ford Expedition SUV (A64557)
2011 Ford...
