Work lights on my Max 22
/ Work lights on my Max 22 #11
I can't get the tractor in the garage if I mount them on top of the ROPS ( I have about 1/8th of an inch extra) so i am welding up a bracket that I will mount to the front of the grill guard so there will be no glare on the front plastic to the soft cab. These are flood also in front.
I like that idea. We probably should make a mount kit for the grill guard. The higher the better for lights I think, but LEDs are so bright that you can get away with less than optimal placement and still throw out a lot of light. The pictures I showed earlier in this thread were from lights mounted at the base of the ROPS, and they are still amazing.
Once I have them painted I will post photos.
/ Work lights on my Max 22 #13
Here is our ROPS base bracket. Folks should feel free to copy our design. It works well. It would not be good for a soft cab obviously.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=308326"/>
Wow, those are one big heat sink, they generate that much heat?
/ Work lights on my Max 22 #15
Seems the heat sink is oversized, but then again these are Rigid made units and supposed to last about forever. There is a YouTube destruction video about these where they drag them behind a truck, shoot them with guns, saw them in half, etc. Basically, they keep on working. They are over built.
/ Work lights on my Max 22 #16
Hey guys, Long time lurker, first time poster.
I'm a new owner of a Max25. Purchased with FEL, MMM, 60" Woods rake and 60in Rear blade. Rake and blade were used, but other than paint in perfect condition.
Anyway, had my first crack at snow removal last night. I live in RI and we had a small storm in the area of 3-4in. Glad Ma Nature started us off slow so i could get a feel for it. My driveway is about 1100 ft, 800 of that being a decent uphill grade (or downhill... guess it depends where you are standing). No issues with traction or power at all.... i did take up a little gravel at first, but it wasnt so bad once i reversed the blade and used the back side. I do have a set of chains for when winter really sets in... but for now the Industrial tires seem to do just fine.
I have sent DavesTractor a PM about this, but figured it a good time to drop my first post.
I'm drooling over those ROPS light brackets Dave has pictured. I did just fine with the lighting that comes stock on my Max, but i can see where more would be beneficial... especially out the back. I'm not much for fabrication or welding... so making something like this myself just isn't an option right now. Wondered if anyone knows where i can score a pair of these beauties.
Dave, in the pic you posted showing the difference in lighting (stock vs w the rigid lights). Am i correct in thinking you have 2 spots pointing forward, and one flood pointing back... or is it 2x2? Those images show quite a difference.
Lastly, anyone ever try magnetic lighting up on the ROPS? I know they make some with beastly magnets, but wonder how they'd fair with the vibration.
Thanks in advance guys....
-J
On the MAX 22 & 25 there is a white wire behind the seat which is hot that you can hook the wires to. The only problem is it is hot at all times when the ignition is on. I hooked a set of lights facing backwards also, 35 watt halogens. They throw more than enough light so i can see backing up at night while I am blowing snow.
/ Work lights on my Max 22 #18
I like the idea of using the factory wiring. Personally i would consider adding a toggle btwn that hot wire and the lights so I have an option to turn on and off. At the very least I'd put one on the the rear facing light just in case. I really like the looks of the Rigid LED lights that Davestractor talked about. Now it's all about mounting options. Kootch, how did you mount your rear facing lights? I hate drilling and avoid it if at all possible. And the though of drilling into the ROPS is a turn off.
Kootch, I've read alot of your posts, and will say that you played a part in me deciding to go Mahindra vs Kubota. I know that sounds creepy, but like i said before... I lurked this site for months.
I took a 1 1/2 x 4" piece of metal and drilled a hole for the light, attached the wire and used a tec screw to ground it and mounted the light right around the bracket for the turn signal. I'll take a picture of it this evening if you like. It took me all of ten minutes to wire and mount the light since the wire already had a male barbed end on it. I didn't cut any wires, I just tied them up tight with a zip tie.
/ Work lights on my Max 22 #20
I would love to see how that bracket works. I have plenty of tools to do a project like that, so this would be in my wheelhouse. I did see your pictures of the front light bracket you made. Looks very well done... and having the lights up front would eliminate my next concern....
Curious to how much light hits the work area on lights mounted on the fenders. Just wondering if they have any adverse effects being mounted behind the operator, under eye level.
I don't know, I may be over-thinking the whole thing... but i tend to do that.
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
DSP 900 Balancer with Split Weight (A61307)
DSP 900 Balancer...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
King Kutter II Tiller for sale.
King Kutter II...
