Dump Cart Ideas and Pics
   / Dump Cart Ideas and Pics #1
nyen0004
Morewood, Ontario, Canada
John Deere 2320
I am thinking about building a small dump cart/trailer for my JD2320. I would love to see pics of your carts/trailers, and any imput or ideas you have would be greatly appreciated.
   / Dump Cart Ideas and Pics #2
Check out the versa trailer by dr. It has a dump, with outriggers and the box comes out and makes a logging trailer. Neat machine.
   / Dump Cart Ideas and Pics #3
Subbed for future reference.
I plan on building something for my BX. Im leaning towards a euro style 4 wheeler. like a hay wagon. Since I only have one tractor, 4 wheels will allow me to park and load without having to deal with jacks. Plus I will be able to put more on a 4 wheeler because there is no tongue weight to speak of. This also means I can move a "heavy" trailer with my ATV. Something in the 4x8 range I think. These links are to larger ones, but the concept is the same. There is a manufacturer that makes a reasonably priced trailer kit that several have made, it has wood floors and sides, the manufacturer escapes me at the moment.
   / Dump Cart Ideas and Pics #4
Whoa, that green one must weigh 2,500 lbs. If you put that behind your 700 lb atv, and wander down, even the most modest grade, you will be a "pile at the bottom of the hill".
Be very careful with that. We dont want anybody to get in trouble.
   / Dump Cart Ideas and Pics #5
I thought long and hard on this for my 1026r. I live on hilly land so this was designed to not run away.
I would build a 2 wheeler from an old 3/4 or 1 ton truck rear axle. The brakes would be plumbed to a master cylinder and lever at the front. The lever could be locked with a hasp or detent. The axle would be biased to the rear so that the tongue would always be weighted up to a 30 degree grade. The tongue would have a skid with some small spikes on the bottom to keep it from scooting in muddy conditions. The dump mechanism and bed would be pretty standard fare like that found on an articulated dump truck. The tires would be as tall and wide as possible without hurting stability or width too much. The tread would be fairly aggressive. The hitch would be connected to a trailer adapter on the 3 point hitch.
   / Dump Cart Ideas and Pics #6
I own 6 trailers that are roadworthy (tires & wheel bearings) and 2 that are considered for yard use only. (low speed bushings). On my road trailers I have screw type tongue jacks and a 'shoe' on the bottom of them, basically a flat plate so it won't sink in dirt. I put a 4x4 under the tongue jack before unhooking from my truck which makes it sit high on the front. If I move it with the tractor I can pick it up and move with it, leaving the wooden block behind. My trailers are either 2" or 2-5/8 in balls but I run a 1-7/8" on the tractor hitch so the ball will NOT lock, will always slip out without me ever getting off of the tractor. So moving them around or working with them in my yard is a breeze, hook or unhook and never leave the seat.
If you have a 4 wheel trailer it is tough to back. I have one, bought it just so I could learn to back it up. I'm getting better but it gets tough sometimes. The 2 wheel trailers are a breeze.
Also, the longer the tongue (or trailer in itself), the easier it is to back. The shorter the tongue the faster it turns, very fast response on a short trailer.
For your tractor, I'd think a 5X10 would be a lot better choice. It's a good size general purpose utility trailer and will haul most that the average guy would want to haul but yet still small enough to work well behind your tractor.
The hardest trailer to back is the 3X3 yard cart. When the trailer os shorter than the towing vehicle it can be a nightmare.
   / Dump Cart Ideas and Pics #7
Yeah, as I mentioned in my post, those are for full sized tractors, im downsizing the one I build to 4'x8' or maybe 5x10. No need on shooting down the hills here at a alarming rate.. I can't afford the underwear:)
Surge brakes of some sort might be in order too, if I find it too hard to control.
   / Dump Cart Ideas and Pics #8
swick, I'm not a fan of taking a pickup bed and converting it into a trailer. It's just my own choice/liking. But using a pickup bed does have it's legal loopholes.
I guy local to me was coming home at dusk dark and a tractor trailer hit him in the rear as he was stopped, making a left turn. He did not have lights. They were there but the plug was damaged, not hooked up. Since it was a "manufactured vehicle" and the original lights were still intact, lenses had the reflective material in them that was factory installed, the tractor trailer was at fault. Had it been a home built trailer, he would have been at fault IF his lights did not work.
There's a loophole about hitting ANY manufactured vehicle in the rear if the factory lights and reflector material is still there. Although it was just the bed, it WAS a manufactored vehicle.
   / Dump Cart Ideas and Pics #9
Here is what I made for my BX2660.
   / Dump Cart Ideas and Pics #10
Hey LeeJohn..................that's a real nice looking cart !!!!!!!!!!
MFWD
   / Dump Cart Ideas and Pics #11
My tractor with FEL is probably 4200 lbs but only has 28HP so as you can see this trailer I built is good sized for IT. HOWEVER the tong weight is low and when loading I HAVE to load the front of the trailer first otherwise it will tip up when un-hooked. I drop it and use the FEL to load gravel out of my dry creek/wash. I fill up the front of the trailer normally first and have tipped it up when re-hooking with the Box Blade Ball mount which I have to have the trailer leaning back to get under the dump tong hitch. When using the yellow T bar/Ball I do not have this issue or when I leave it hooked to the truck or neighbor's tractor.
More images of the build & details are on Photo-bucket in the same folder.
It will hold ~2.5 yards of gravel and has a 7K lb axle under it. I was going to put 2 under it but needed the maneuverability around the farm & the bridge prob ably could easily be overloaded with a dual axle trailer.
Behind the truck for perspective.
Mark
That is pretty much what I was thinking of building. I have a few more questions for yah now that I see yours... What are the dimentions. I see hydraulic hose so I am asuming it has hydraulic dumping capability...How does your tractor handle a full loaded trailer for dumping. That was one thing I was worried about with my JD2320, I want to build something the proper size so if filled full with dirt I can still dump it and not have to empty half with a shovel.
I don't have much/any Hydraulic experience:confused3:. So was wondering a few things... first on a set pressure if you take a small diameter cylinder and a larger diameter cylinder will the larger one or the smaller one lift more weight? I know the larger one will move more slowlly then the small one due to volume of oil neede to fill cylinder but I not sure of the lifting capabilities. Anyone that knows anything would be great.:anyone:
   / Dump Cart Ideas and Pics #14
To prevent the 3-pt from lifting if you have little tongue weight, I wrap a short length of chain from the hitch bar to the top link. This prevents what you are showing in the photo. Just remember to remove the chain before raising/lowering the 3-pt hitch.:)
Dennis
Mark
   / Dump Cart Ideas and Pics #15
I just meant to take the axle and frame rails maybe. Send the bed to the scrap yard and build a real bed and dump mechanism. The taller truck tires will pull easier in soft ground than overloaded four wheeler tires plus they will be close to the sides so you can load over them. I think two axle carts are too much complication for a small tractor personally.
   / Dump Cart Ideas and Pics #16
Here is a like to a trailer that Iplayfarmer made a couple years ago. it is a long read but worth it although he pulls it with a garden tractor so it is small.
TractorByNet.com - Compact Tractor Forum his is made of steel frame and wood deck and sides.
here is the link to the build I did in April of 2011. Mine has a walking beam axle and hydraulic dump and is all steel and pulled with my B7510 Kubota.
http://www.tractorbynet.com/forums/build-yourself/204019-my-version-kk-xb-dump.html?highlight=
it also is a long read but may be of some help to you.
   / Dump Cart Ideas and Pics #17
I well check the size tomorrow , the sides are 16". The sides I used 5/4 decking and floor is 3/4 plywood covered with sheet metal. The BX goes a good job on flat ground and it well dump it as high as you can put the gravel, wet dirt I don't know yet. I don't think I would try it on the hill load, just because the BX hasn't got enough weight. The tires that are on it in the pictures didn't last only about 6 times hauling about 1000' and back. The cyls and from old combine head, SA and I put a electric 12 valve to bypass the couple and ran it to then hyd tank. The relief would lift when going down. I added pic so you can see the hyd set up.
   / Dump Cart Ideas and Pics #18
I looked at your trailer and you sure done a good job. It looks heavy, is it? Now that it has been awhile did the cyl do ok? The reason I ask is the rod looks small.
   / Dump Cart Ideas and Pics #19
Leejohn, my trailer is quit heavy but I have not weighed it. Best guess would be between 500# and 700#. the dump works fantastic!!! The Cylinder is a double acting 3"x18" with a 1 1/8" tie rod cylinder. I had filled it with road millings to the top and heaped it some and it dumped without a grunt! I think I calculated that is holds 2.16 tons. I am well pleased with it's performance!
   / Dump Cart Ideas and Pics #20
By the picture the rod didn't look that big. I bet you are well pleased, again a nice trailer.
2018 CATERPILLAR 313FL EXCAVATOR (A60429)
2018 CATERPILLAR...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
TANK MANIFOLD (A58214)
