How To Build A Traditional Hay Stack?
/ How To Build A Traditional Hay Stack? #61
My brother did custom hay stack moving. He started with the type pulled with a tractor and at the peak had 3 truck mounted units.
When big round were fairly new I was riding in station wagon with a guy who nearly killed us by running into the back end of a trailer (may have been a tractor pulled stack mover) loaded with big round bales. He cranked the wheel over and was going down the road mostly side ways when we hit. The back 1/2 of the car collided with the trailer, most everything from about a foot back from our heads was trashed.
I spend a good many hours in my youth driving flag behind slow moving farm machinery. I guess people need to have more kids or hire more help.
/ How To Build A Traditional Hay Stack? #63
I've never had luck cutting hay with a chainsaw. I've heard of it but it always jams between the clutch and cover until the chain binds up when I've tried it. I have a block of hay 30+ feet long, 10+ feet wide by 10+ feet tall left in a barn. The old folks had hay knives to saw blocks out to sell, we work at it a bit every year with pitch forks but are on a face, not the top so its slow going.
I'd be terrified of burning the place down running a chainsaw cutting hay in a barn. It just seems too easy to throw a spark and poof!
/ How To Build A Traditional Hay Stack? #64
That's an outside the barn thing for sure. Besides the spark potential there is the noise and exhaust which would upset the cows or other stock.
/ How To Build A Traditional Hay Stack? #67
Here are the results of a search for the Farmhand F10 loader. It seems to have been capable of building and feeding tall haystacks without a beaver slide.
farmhand f10 loader - Google Search
I was thinking that loader was a F1. Would not be my first brain fart. Spent hours on the thing bucking hay. The one I used had an oil tank mounted behind my right shoulder
Talking about this brings back some buried memories. I would push the hay up into mounds and dad used a then modern loader with a grapple fork to place it in the stack frame. I think he used the F10 loader with a longer reach to top the stack.
/ How To Build A Traditional Hay Stack? #68
Don't worry about the brain fart. A zero is nothing among us tractor drivers. My first knowlege that a hay sweep even existed came from a Farmhand brochure that I picked up at my Allis Chalmers dealer's and the F10 looks like the champion of them all.
/ How To Build A Traditional Hay Stack? #69
When I went to Russia a couple of years ago, I saw lots of haystacks. somewhat similar to this one.
If you want to learn to stack hay, find a rural Russian friend, and volunteer to come and help during haying season.
2612207-73682-summer-mountain-green-meadow-with-stacks-of-hay-carpathian-mt-s-ukraine.jpg
I think they all had the pole in the center. Unfortunately I didn't get a chance to "build" one.
The first year we had some property in the country, my Dad had an idea that we should cut and stack our own hay. We cut a pasture using a sickel bar on an Ariens tiller, then managed to get it piled up. It was a very loose stack, and a lot of work. We covered it with a tarp. Anyway, after that we either bought hay, or later had someone come and bale our hay.
Our neighbor's barn has a wooden track and trolley system down the middle of the hay loft that I'm pretty sure was to stack loose hay, although it hasn't been used for years.
/ How To Build A Traditional Hay Stack? #70
My neighbor had a stack or two like the ones you saw in Russia, when I was a kid. The poles leaning in from the sides are a new wrinkle for me. I guess they cut the branches off and leave them on to help keep the hay in place. Seems like a good idea.
/ How To Build A Traditional Hay Stack? #71
Somewhere, maybe Youtube, I saw a haysweep lift the load to maximum extension above the tractor driver's head and dump it behind him onto the stack. It looked like a good way to get dead, to me.
/ How To Build A Traditional Hay Stack? #72
What we used to call a farmhand used to stack hay. The first is the Farmhand with what looks like a manure fork on it. The models show hay sweeps. They dumped to the front:)
/ How To Build A Traditional Hay Stack? #73
That stack with a pole in it is what I was talking about back on page one. I used to have a barn with a track hay fork like the trolley system you are talking about. In fact the forks and the track are still here in a bone pile. You would back a wagon of loose hay into the barn floor and set the four fork tines into the back half of the load then unhitch one of the horses from the wagon and onto the end of the pull rope. As you drove the horse ahead the half of the load would get pulled up to the track (two angle irons not wood) up at the ridge pole of the barn, trip a toggle and run out into the middle of the bay and dump. back the horse up and set in the front half and repeat. About a half ton to a pull but not much faster then just pitching it off unless you barn was high and the fork was moving it to a higher loft then the floor level you backed the wagon into.
/ How To Build A Traditional Hay Stack? #74
I've tried to relocate the backward dump again without success. I want to find it again to see just how it operated.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A63276)
2014 MACK ELITE...
ROME RLS12 HYD SCRAPER (A63276)
ROME RLS12 HYD...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2022 Ford F-150...
2009 International 4300V 24ft. Cab and Chassis Truck (A64194)
2009 International...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2022 EZ-GO ELITE...
