How To Build A Traditional Hay Stack?
/ How To Build A Traditional Hay Stack? #43
Hmm. All this has me rethinking how I handled some large bales that got the bottoms soaked. 4'x4'x8'. Fortunately it was my Wife that made the mistake (her horses). I was attempting to set the hay up to dry out, which didn't work well enough, as I later manually pulled the wet/moldy part off.
My original efforts: I drove forks mounted on my loader (thank God for Bobcat and quick attach mounts) into the tops of the bales (avoiding cutting the tie strings). Then pushed large ratchet (hay) straps through the slots, using the fork bottoms to push pine 1x4 boards I had handy (I put the strap hooks over the ends of the boards). I wanted to split the bales into squares (versus rectangles) and set the new bales on pallets, then loosen the ratchet straps so the bales could sit in the sun, get some air under/into them and dry out. Theory versus reality.
But cutting the bottoms with a chain saw running canola oil and biodegradable 2 stroke oil would work. Outside of course. You could lay a tarp to the side of the bale you are keeping. Sounds a lot more time efficient than a saw (though if I ever see one for sale locally, I might just have to buy it). Then you might be able to salvage some of the hay (while freshly wet it could be fed to the horses, and maybe even dry out enough to salvage).
/ How To Build A Traditional Hay Stack? #44
It looks like feeding the hay with the sweep will be a little iffy. If I ever get one built, I'll just have to experiment.
My use for a hay knife would be to split a bale so I could get a bale and a half into each of my two hay rings. I think it'll just be easier to buy another ring. Thanks to everyone for your advise.
/ How To Build A Traditional Hay Stack? #45
If you have the loader you must have a bucket. I expect if you add a graphel fork to it that should work. Dads was the same bucket we used for moving manure.
/ How To Build A Traditional Hay Stack? #46
I got my old hay cutter out (has 3 non-serrated sickle mower teeth) and cut some hay. Not as hard as I thought it would be (not sharpened either). I cut some hay in an opened bale and on some that was on the ground.
/ How To Build A Traditional Hay Stack? #47
This advise you gentlemen give from your first hand experience is really helpful and might save me time and money.
/ How To Build A Traditional Hay Stack? #48
Re: Putting it up loose
That is the way my Dad worked his hay towards the end. Got a neighbour with a stack mover to place the stacks in the feedlot. Then there was a movable Stantioned type fence that allowed the cattle to feed. Pretty simple machinery and low manpower:thumbsup:
Egon,
How did your father handle the potential mud problem caused by the cattle standing in nearly the same place as they fed?
/ How To Build A Traditional Hay Stack? #51
It looks homemade to me too but, I can't say for sure because I can't understand their language. I even have a difficult time doing a search using an online translator. Those eastern countries have some seemingly diy equipment that's seldom seen in the USA. Here's a rear mounted hi lift. Самодельный гидравлический подъемник на МТЗ-82 - YouTube
There's one around youtube somewhere loading round bales in a hay loft. I tried to lift a couple of those into a hayloft once using the old track and pulley system that was in the barn. I pulled with the tractor and broke a good rope.
/ How To Build A Traditional Hay Stack? #52
Google < farmhand tractor loader > and go to images. You'll see lots of different style loaders.:)
/ How To Build A Traditional Hay Stack? #54
Egon,
The hay was placed on a slight slope. In the winter ground was froze. When a little warmer just cleaned of with the tractor. :)
/ How To Build A Traditional Hay Stack? #55
Thanks Egon. I should have realized the ground freezes in Nova Scotia. In South Carolina, we'd have deep muck in that situation.
/ How To Build A Traditional Hay Stack? #56
That was back in Alberta. It's even colder there.:)
/ How To Build A Traditional Hay Stack? #57
I've never had luck cutting hay with a chainsaw. I've heard of it but it always jams between the clutch and cover until the chain binds up when I've tried it. I have a block of hay 30+ feet long, 10+ feet wide by 10+ feet tall left in a barn. The old folks had hay knives to saw blocks out to sell, we work at it a bit every year with pitch forks but are on a face, not the top so its slow going.
/ How To Build A Traditional Hay Stack? #58
If you have access to Netflix or even the Internet a few years ago the animal planet did a series called "last American Cowboy" it only lasted one season (unfortunately - it was too normal for most people) anyway there was a old rancher named Stucky and he built them with the old timber hay sloop - you can watch them build haystack on the show. Very interesting.
/ How To Build A Traditional Hay Stack? #59
Pitching hay out of a hay mow or off a stack is a skill that requires a bit of practice. It is like a tetris puzzle in reverse without color codeing. You have to pitch off the last tumble that went on first as each one locks in the ones below. If you just stick the fork in and pry up anywhere else your trying to pick up the hay your standing on. Knowing how it went in helps a lot but if a loading fork or other machinery put it in you might not be able to find the pattern to start picking it apart.
/ How To Build A Traditional Hay Stack? #60
It's really a matter of knowing what the stack looks like as you build it. You get an "eye" for how the layers interlock. You fork the layers off in reverse order that they were piled onto the stack. (For those computer programmer's out there... it's a reverse FIFO.) ;)
When I was pretty young, there were some ranchers that still used horses to stack hay. Not many, but here and there. A fair number still used teams to feed with in the winter, though. Don't remember ANY 4x4 tractor's back in those days. So, it was easy to get stuck and it was even easier to tear the bejesus outta the pastures-hay fields with 2WD tractor's trying to break into the stacks and haul hay. Not so, with a team of horses.
They didn't get stuck...
One poster summed up how the hay was put up when I got a little older. Portable stack frame. Of course, tractor's of many shapes, sizes and manufacturer all fitted with the Farmhand loader. Many of the Farmhand loaders had the long, wooden teeth (probably 8' long) with metal points. Later models had long steel teeth and they were probably 8'-10' long, too.
You'd drive down the windrows and "sweep" up the loose hay with the Farmhand and haul it over to the stack frame and dump. Course, the windrows were all raked with a dump rake. Therefore, the hay didn't get jumbled up too much - it mostly layed flat with the stems in layers upon each other.
That's the key with stacked hay - layered. Sheds rain and snow. Like a shingled roof. And for anyone who has had the experience of stripping a shingled roof from a house or building - you know how impossible it is to peel up more than a couple of layers at a time. Same with feeding a stack. You can only peel up a couple of layers at a time. Get too aggressive and you'll just tear up equipment or your back!
Anyone remember the chain-drive stack movers? Many of them where made by Farmhand, too. Tilt-bed and push the leading edge under the stack and engage the chains to slowly pull the stack onto the frame of the stack mover.
I can remember many tractors (big, 150hp with duals) getting stuck with a stack loaded on the mover trying to get outta the field. Or, worse yet; burying the tractor while trying to load the stack. The stack might be half-way onto the mover and there ya were... down to the frame! :eek:
How about going down the road and coming up on a tractor moving 1-2 stacks of hay. They would take up 2/3 of the road! Your only recourse was to hope that he was pretty close to where he was going or turn around and take another route. 'Cause there was no safe way in the world to ever pass a loaded stack mover! Unless you were on a good oil road and he was pulled over on the shoulder.
A fair number of folk's died while encountering stack movers. (There were no lights anywhere on those things; except the tractor - but, it's impossible to see the tractor from the rear - the load was usually 20'+ wide and 20'+ tall.)
Don't have those kind of problems with big, round bales.
AKfish
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2025 Hydraulic IRANCH Tilt Bucket Mini Excavator Attachment (A64553)
2025 Hydraulic...
2007 Polar Dot 407 Insulated T/A Chemical Tanker Trailer (A64194)
2007 Polar Dot 407...
Bull (A64557)
Bull (A64557)
