Dump Trailer Log Splitter?
/ Dump Trailer Log Splitter? #1
JDdriver
Canada
Has anybody ever heard of a dump trailer log splitter all in one?
I have a wood furnace and only one tractor, I don't want to have to drag my trailer back and then have to drive back to get the splitter out of the bush.
/ Dump Trailer Log Splitter? #2
Is the splitter 3pt hitch or trailer type? If it a trailer type, just put a hitch on the back of the trailer. I would use a reciever type so I could take the hitch off.
I need it to be road legal as well because sometimes I go out to my other acreage and get wood there, it's about 20 kilometers away.
/ Dump Trailer Log Splitter? #4
How big is your splitter? Can you weld/fabricate? Is there a way to mount a pair of reciever hitchs on your trailer and splitter to be able to quick attatch it to haul? There is always a way, sometimes you have to think outside the box. Of course if you have a larger splitter, that probly wouldnt work. Do you have a front end loader, where you could load/chain splitter to the bucket? I know that it is aggravating not to be able to haul it all. I have a old small poulan splitter that would be easy to do like the suggestions above. Are they that strict in Canada on that, looks like you could tow it behind your trailer, maybe run hazard lights on the splitter? LUTT
/ Dump Trailer Log Splitter? #5
Just have a reciver tube welded on the dump trailer and tow the splitter behind. Its done all the time here. Everything from boats behind campers to boats with a jetski behind.
Chris
/ Dump Trailer Log Splitter? #6
For smaller jobs:
- My splitter has a 5 foot wheel base, 7,000 lb mobile home axle with 14 ply tires is mounted approximately 2' from the rear of splitter. The splitter is heavy enough I can pull a trailer behind it.
- The trailer is just under 16' overall length. It has a 4'x8' bed with 2' high sides (half a cord) and a p/u bed tool box mounted in front of it which contains my chainsaws & accessories. It has a single axle (7,000 lb mobile home axle with 14 ply tires) which is mounted approximately 4' from the rear of the trailer. With the two linked together (splitter first), I can go the speed limit while fully loaded very safely - NO SWAY! The trailer does not have enough tongue weight to pull the splitter behind it safely. This setup has been reviewed & approved by the highway patrol . I am not required to license the splitter even though I use it to pull the trailer.
Around here you aren't allowed to tow 2 at a time, Has anyone thought or seen of a trailer with a splitter on the side so when you split it it falls into the trailer? That way I could tow both and it'd be faster to load them if when they split they just fell in. I may have to break out the welder.
/ Dump Trailer Log Splitter? #8
Around here we cant tow two trailers same time on the road either, but I have done that for around my property. Question here is, what type of trailer you have now and splitter? isnt it possible to put your splitter on the trailer if you have enough room? I'm sure there are ways to do this if you become creative.
Yeah at the moment I'm loading my splitter into my trailer(No easy task) and then driving it to the woodlot but when I fill up the trailer I've no way to get the splitter home unless I want to make another trip.
I'm looking for suggestions to build an all in one splitter and trailer, I'm handy with a welder if anyone can help me with some plans to build one I would happy to.
/ Dump Trailer Log Splitter? #10
I saw pic. somewhere that had a log splitter as the tongue of a trailer and the guy used the splitter cylinder as the dump for the trailer. Wish I knew where I saw it.
/ Dump Trailer Log Splitter? #11
When I said this the other day, I meant could you make a carrier with reciever hitch material to carry your splitter instead of towing it. Looks like if you have a dump trailer, it would be to high to mount the splitter on the tounge or in the bed. My dump trailer has 3' sides and sits pretty high off the ground. My old splitter lays flat on the ground, some of the rounds I cut are way to big, I have to bar them on, or nose them with the loader. Now if a guy could come up with a easy way to split them where they fell in the trailer, that would be something. LUTT
/ Dump Trailer Log Splitter? #12
im confused your towing the trailer into the brush with the tractor? if so carry the log spitter on the front of the tractor.
/ Dump Trailer Log Splitter? #13
Maybe this is it?
Picture is a little fuzzy but it will give you some ideas.
/ Dump Trailer Log Splitter? #14
I put my own design horizontal splitter across the A frame of my 3 cub m3 trailer,Works at about chest height,comfy for me,no bending,loglift/bench holds about 400 lb of logs.Unit is on slide,out in work mode,in when mobile.Catch tray for splits straight into trailer.Only bending done is when cutting logs,and to load loglift.I drive to logs,cut,split,load in one operation.I sell about 400 cub m3 of split hardwood per season,and cut ,split landowners timber for them when they can,t process it themselves as a sideline currently charging $50 per hour,works out for them about half the cost of buying in split hardwood firewood.I recommend an all in one unit,had mine for 7 years,cheers.
/ Dump Trailer Log Splitter? #15
IDK your laws, but around here, a tractor can tow about anything as long as it has proper SMV signs. No licenses required.
Towed equipment like splitters, compressors, etc. do not need licenses even if towed by a truck. But even regular trailers don't need licenses if towed by a tractor and are considered "farm equipment." Of course, that varies in different locations.
LOT OF GRAIN BIN LADDERS (A64278)
LOT OF GRAIN BIN...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
GRILL GUARD FOR MASSEY FERGUSON TRACTOR (A64278)
GRILL GUARD FOR...
2006 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2006 MAC 35ft...
