3-Point Hitch top link question
/ top link question #1
ncviauk
Member
Eden
BX 18--
I have a BX1800 with a set of pats Quick Connector. My factory top link is just a little short to work the box blade and tiller. I purchased a top link from tractor supply but it is too long. Does anyone have a suggestion for what to do next.
/ top link question #2
Get a hydraulic top link from Brian[mountain view] that should do it.
/ top link question #3
is the OEM toplink not adjustable?
/ top link question #5
They make top links in different lengths. I always measured my old top link and then took the tape measure to TSC to pick the length that I needed.
/ top link question #7
Take the one you bought back to TSC and get the next shorter size. They should have several different adjustable lengths.
When i first bought my Pats, I had the same problem. Stopped at a Green dealer since I was driving by and priced a longer one. $70:eek: Since I had no idea of how much one should cost I was feeling down BUUUT on up the hwy was a TSC so before paying $70 I thought I'd check at TSC. They had a rack full of them in different adjustable sizes for $19 each.:)
/ top link question #8
Just checking Agri-Supply catalog that is laying on my table and it looks like they carry Cat I in body lengths of 13",16", 19", 20" and a special Kubota one of 14.5". This is body length not minimum/maximum adjustment. Measure the two you have and pick one in between. The link MVR sent has about the same sizes but about $10 higher average cost. TSC should have similar sizes available
2000 Mack RD688S Dump Truck, VIN # 1M2P270C1YM049400 (A61165)
2000 Mack RD688S...
2017 Unverferth 1245R-35 Rolling Harrow (A63116)
2017 Unverferth...
2023 John Deere 8R 280 Tractor (A63109)
2023 John Deere 8R...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
