advice on a 38-42 hp 4x4
/ advice on a 38-42 hp 4x4 #1
Rmart30
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Guys im looking to buy around a 38-42 hp tractor for using at my hunting lease for bush hogging and planting green fields.
I am 99% not going to be getting a FEL with it at this time but would like to add one in the future.
Im also 99% leaning toward a hydrostatic trans just because of all the back and forth work in tight spots.
I have looked and priced a Kubota L3800 hydro 4x4 and it priced at $14,900 + tax with ag tires.
next I went to the green store and they had no 4000 series machines in stock. Said they just didnt sell many that most people went to the 5 series instead.
They quoted me a 4120 hydro 4x4 with ag tires at $26k ..... a 4105 same setup $20k..... or a 5045 gear $23k
Lastly i have looked at a Mahindra 4025. 4x4, ag tires manual trans.... $15k
Now the 5045 is a heck of alot more tractor than the others are but, it wont fit on my fit on my current trailer and id be taking quite a loss on it if i had to upgrade trailers. it would probably cost me in loss on old trailer and upgrade cost at least $2k overall.
I said id like to add a FEL at a later time. Im a construction equipment mechanic by trade and adding a FEL and the hyd to a kubota looked by far to be the easiest as they already have the mid hyd plumbing already there its just a simple 4 bolt block to add on after removing the plate and 2 side mounts for the loader.
So it gets the plus in that deptartment.
The Mahindra outweighs the others by over 1500# (except the 5045)
Any input on this ? Any other models that I should be looking at ?
id rather stay with one of the bigger name brand tractors. After owning one Long tractor and its lack of parts support I don't want to go thru that again.
/ advice on a 38-42 hp 4x4 #2
Likely that I will get shouted down. But, seems to me that if you are going to be doing a lot of field work, you would want a geared Trans instead of Hydro. Pulling plows in large plots season after season does not seem like it would be ideal for Hydro.
But you said you have a lot of back and forth work in tight spots. Are your food plots tiny?
/ advice on a 38-42 hp 4x4 #3
You have any Kioti dealers near you?
/ advice on a 38-42 hp 4x4 #4
I agree:thumbsup: Do you need to trailer it to and from the hunting lease every-time you use it? How many hours do you want to work your tractor each year? If its less then a hundred you might be better off renting machines a couple of weeks and a couple of weekends a year.
/ advice on a 38-42 hp 4x4 #5
I do love tractors, but vtsnowedin makes a good point. For equipment we use only a couple of times a year or so, we just rent.
Of the tractors mentioned I really don't know all that much about them and would also look at Kioti and any other good dealer around.
/ advice on a 38-42 hp 4x4 #6
I do ten acres a year with my HST tractor(and have for nine years),no problem.
No Kioti around that I have ever seen ...most of the food plots this will be used for are small..1/2 -3/4 acre ... our lease is ten thousand acres and the biggest food plot is maybe 2 acres. I have a 4230 deere (100hp) we use for the big stuff with a 12 ft Bush hog. And the 60 hp long also
Im sure wed put 80-100 hrs per yer on this small tractor. Our lease tip to tip is about 6 miles and we will be trailering this smaller tractor to the plots rather than driving the big one back and forth on the roads.
/ advice on a 38-42 hp 4x4 #8
In this case, since pulling does not seem to be an issue, is there any situation where a geared tractor would be better?
/ advice on a 38-42 hp 4x4 #9
Ahh more information. Makes a big difference if you alread have the heavy lifting covered. Are the two you already have parked on the lease or do you bring them in when needed?
/ advice on a 38-42 hp 4x4 #10
I sure like my Mahindra 4035...I also work a lot of deer lease stuff...whatever you end up with I would highly advise an FEL as it has come in VERY handy on the lease on multiple occasions ! I have a PST, no experience with HST...
Rich
/ advice on a 38-42 hp 4x4 #11
Not for my money.I used to run geared tractors when we had beef.As far as I am concerned HST is god-send.Infinate control of speed,what ever you are doing.My bottom plows don't have trips,I can instantly stop if I have to.I run a 8ft.snow-plow in winter,have a roto-tiller box blade,spring tooth-harrow.If I was plowing hundreds of acres;I would have a gear tractor or needed one over 70 HP.
/ advice on a 38-42 hp 4x4 #12
Field work where 90% of the time is spent going in one direction. Working around things, changing directions, etc a hydro will be much faster and easier to use.
Yes, I have run all three: Gear (MF Industrial 35, had a shuttle which was nice, Bolens 1050), GST (has a hydraulic clutch so you dont have to clutch when shifting, Kubota L3830 and 3650) and Hydro (Kubota B7500, BX2660, various lawn tractors)
I would take Hydro over any of them for anythign we do on our 30 acres here. Yes, a gear is going to be slightly more efficient when pulling (ie: plowing a field), but a hydro is much more efficient when mowing, raking, blading, baling, etc.
Aaron Z
/ advice on a 38-42 hp 4x4 #13
To the last two posters.
Thanks for the input. Now that I think about it, I guess I am not certain why I thought this, but I guess I just assumed that doing field work, like plowing, would be hard on the Hydro. And if this is not the case,,,, yea I kind of wonder why you would want a geared tractor at all? Money considerations I suppose. But the difference in cash when you are spending 15+k on a tractor to start with is,,, sort of negligible. Well, it would be to me. Thanks again.
We leave them on the leased land... Its 10 minutes from my house and we are there year round at least 3 or 4 days a week doing something. The 4230 has the big bush hog, a 14' cultivator we use to cut up the fields and pull out all the grass clumps, and we have a 3 pt side mount bush hog for cutting the sides of the roads with.
The long has a FEL and we run with it a 8' woods cutter and a 8' scrap blade to keep the roads serviced.
I also bring in dozers, track hoes or a back hoe 4 or 5 times a year for the big projects. The most a FEL would do on this small tractor would be grabbing up a scoop of gravel and smoothing over a mud hole here or there.
Would come in handy but not sure worth $4k for what wed be using it for.
/ advice on a 38-42 hp 4x4 #15
Seams to me that the light weight and smaller size of the Kubota would benefit to you more than a larger tractor would.
/ advice on a 38-42 hp 4x4 #16
Check out Kioti CS series
/ advice on a 38-42 hp 4x4 #17
HST is great, but it does not put as much effective power to the ground as geared tractor of the same horsepower. That said, HST it great and much easier on the operator, particularly with back and forth work and in tight places as the other posters have said. The best advice on brand is how good are the closest dealers, what reputation do they and the brand they are selling offer. A good dealer with an inferior machine can be a better value than a bad dealer with a better machine. Service and parts after the sale are a big deal. Also, looked at used tractors and check the resale value. That says a lot about a brand. I am a Kubota fan for value for money, but there are other quality brands as well.
/ advice on a 38-42 hp 4x4 #18
I am not attempting to change your mind or influence you in regards to your decision, but it would probably be cheaper to equip your tractor with a FEL in the beginning than later on. Most TBN members will testify that once you have a FEL, you will wonder how you ever got along without one before. There are so many uses for a FEL. Just a thought.
/ advice on a 38-42 hp 4x4 #19
Well being completely JD biased :D I'd trade in the long on a 5055E with loader and just drive it out to the ends when needed. You end your parts problem with the Long ,have all it's abilities ,and the 553 loader is fully capable. You have more work for the new tractor to do to justify it's cost as it takes on the Longs brush hogging chores and you food plot tilling will be a snap.
If you go the smaller HST route be sure it has a cruse control so you don't have to hold the go pedal down all day while disking a flat food plot and steering split breaks on the opposite side from the go pedal. I'm not sure which Kubota's have that arrangement but others will advise I'm sure.
/ advice on a 38-42 hp 4x4 #20
It seems everyone on here thinks you should always include a fel with the purchase. I seem to be the oddball in that I don't wan't one on every tractor I own. I bought the 4520 cab without the fel and have been well pleased with it's compact footprint.
For the Kubota's I think the L3800 might be a little light but look at an L4240 and up these are good tractors imo. I think the Deere 4520 while more costly is a good hp to weight package and is very capable. I should also say that hydraulics for most brands are available as an inplace option with mid mounted couplers for adding a fel later on.
You might also want to consider a tlb if you have much backhoe work too. I find my Deere 110tlb gets lots of use for small to medium jobs and has been a very flexible arrangement. A Kubota L45 would be another good choice too. I find these smaller backhoes with 10ft hoes can do the vast majority of my tasks, rarely do I have to call in a larger machine.
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
500BBL WHEELED...
1997 Duraco Dura Patcher 81DJ (A60352)
1997 Duraco Dura...
2021 CATERPILLAR 299D3 SKID STEER (A62129)
2021 CATERPILLAR...
Kubota T1700X OHV Riding Mower HST (A61166)
Kubota T1700X OHV...
