Cutting torch questions
/ Cutting torch questions #1
psu927
Member
Used to do all of my cutting around here with the stick welder and portaband. Just got a used torch setup and have a few questions. Everything I read on the internet about the basics says when I start it I should have a 10" flam or the smoke in the acetylene should stop. If I adjust it untill the smoke stops I have about a 14-16" flame. I'm not sure what nozzle is on it. It has one center hole and 4 outer holes. I can't read the writing on it. I do have an assortment of nozzles. Should I have a large cone in the middle after I add oxygen, or should i have 4 (because of the 4 outer holes) small cones that don't change when I hit the lever? I can get it to cut, just fills up the cut behind the torch as I am cutting. (moving fast as I can). Also a few questions about safety, the torch and guages are an Airco, and there are no flashback arresters. Big deal? And whenever I shut the torch off (oxy first) I get a flashback or "pop". Should I be doing something different? Thanks fellas
/ Cutting torch questions #2
FLASHBACKS ARE A MUST!!! Get them before going any further. I always light the actylene, then add O2 until I get a neutral flame (blue jets coming from all the holes around the center hole).
Your outer holes are the heating element (acetylene and O2) with the center being the O2 for cutting. An oxy-acetylene simply oxidizes the steel in a VERY rapid manner. You can shut off the fuel (acetylene) and still cut with the O2 as long as you go at the right spped.
Tip size will determine pressures and thickness that you can cut. It sounds like the kerf is being filled as you cut, which means you are going to fast or the pressures are wrong...or the tip is the wrong size. Look on Smith, Lincoln, Harris, or other good company's website and I'm sure you will find a tutorial on oxy-acetylene cutting. Read that, then come back with questions!:thumbsup:
I take it flashbacks weren't always used though correct? What are the hazards if I do not have them? I guess my main concern is if I am using too much acetylene and what size my current nozzle is as well.
/ Cutting torch questions #4
As with welding, and cutting I listen to what is happening. Every torch has a sweet spot, sometimes you only need to press the oxygen lever an 1/8-inch, sometimes a 1/4-inch, what you want is for the cutting cone to sound like a small jet engine.
First picture is what I like the cutting cone to look like. Second is a neutral flame.
/ Cutting torch questions #6
Nope. My current set of torches is a 50-60's era Harris that I got from CL. Local welding store had them rebuilt for 75 bucks, I added arrrestors, and they should last as long as I live!
Arrestors stop the O2 and acetylene from mixing in places other than at the tip. You DO NOT want them to mix in the torch or the lines!! It basically stops the gases from burning back into the torch or hoses.
Is your torch used? May want to rebuild it if any question of age or use.
too much acetylene will lead to a dirty flame, too much O2 will put the flame out. There really is no such thing as too much O2 when hitting the lever, it will simply oxidize the steel and you will get a clean kerf and you will waste O2.
I guess if it sounds like a small jet engine before I hit the lever it's too much of both gasses?
/ Cutting torch questions #8
The center hole os just for the oxygen (O2). The four smaller holes are the preheat flames. Adjust as you were doing, to get a neutral flame on the preheats.
Find out what size tip you have, too big or too small will give you a hard time.
Heat your steel with the preheet flames untill the steel is red hot and press the cutting lever to start the O2 flow. The hot steel will burn in contact with the O2. Progress slowly to make the cut. If you lose the cut, you went too fast. If the top edges of the cut are melted off you went too slow.
/ Cutting torch questions #9
yes!, probably too much O2. And to be safe, NEVER EXCEED 15PSI for the acetylene. I have never used more than 5-7, should really never need more than that for cutting. It gets real unstable at pressures higher than that!
Will it just leak if it needs rebuild?
/ Cutting torch questions #11
Yes, but I had that with mine. I and my friend wound up with a glove of acetylene that ignited....was not fun but no damage done. If in doubt, rebuild it.
/ Cutting torch questions #13
The neutral flame is the important part. Too much O2 is "Oxidizing flame" too actl is "Carborizing flame". You light the torch and dial back on O2, then bring it back up until the blue cone is perfect.
Also learn to use it with the gases fairly low rather than on higher than needed. Gas is expensive!!
Always know what is around you too. Many fires and explosions have been caused by poor torch handling.
Don't cut any vessel (barrel, tank, can) that you are not sure what is/was in it.
/ Cutting torch questions #14
I always turn the acetylene off first.Turning it off last will cause soot to contaminate the tip.
Good info guys thanks a bunch!!
2006 Chevrolet TrailBlazer SUV (A66738)
2006 Chevrolet...
2019 Autocar ACX Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2019 Autocar ACX...
2016 Freightliner Cascadia (A64911)
2016 Freightliner...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
New Holland Workmaster 25 (A64911)
New Holland...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
