How do you store you logging/tow chain?
/ How do you store you logging/tow chain? #1
Buty
Canton, GA
Kubota L3200
I like to have my chain with me at all times but haven't found a good place to put it on my tractor. How do you deal with this? Thanks.
/ How do you store you logging/tow chain? #2
Here is something that works well for me.....
Good luck.....
/ How do you store you logging/tow chain? #4
I have a homemade hitch on my 3ph and I hook the ends in the top of the tube that the top link hooks to and drop the middle in the notches I made to pull from on the cross piece. Holds two 8ft chains well, I keep it on most of the time.
/ How do you store you logging/tow chain? #5
I hang two from my logging hitch.
/ How do you store you logging/tow chain? #6
In two 4" plastic pipes screwed to a piece of plywood and fastented to the stone guard on the operators' platform. I got the idea from posts on TractorByNet.
/ How do you store you logging/tow chain? #8
Another great idea from TBN!
/ How do you store you logging/tow chain? #9
On the shop floor until I need it. Glad you asked his question because obviously I have the same problem.
/ How do you store you logging/tow chain? #10
Great idea.
/ How do you store you logging/tow chain? #13
I carry a small chain in the tube for my loader mount on my kubota. Two 4" pipe plugs and it stays outta sight and dry until needed.
/ How do you store you logging/tow chain? #14
My neighbor keeps up with mine, I ask him!
/ How do you store you logging/tow chain? #15
/ How do you store you logging/tow chain? #19
I keep my boxblade on my hitch whenever another implement is not needed and I keep a chain wrapped around the harp/hitch framing
/ How do you store you logging/tow chain? #20
Same for me except that I carry two 6' chains that way.
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
Mahindra 3550P (A60462)
Mahindra 3550P...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2012 DOOSAN G25KW GENERATOR (A60736)
2012 DOOSAN G25KW...
1011 (A61165)
1011 (A61165)
