I will never use poly twine again
   / I will never use poly twine again #31
We went all plastic a few years back simply because of the supply of sisal is sort of irregular. I prefer sisal for squares, easier on my hands.
   / I will never use poly twine again #32
It gets wound up in equipment and wrecks seals. I hate the stuff!
sisal and metal bailer wire will also wrap up on a shaft and hog a seal too... just sayin.
   / I will never use poly twine again #34
By the time somebody gets around to fixing the leak, the sisal twine has rotted away and the cause remains a mystery.
probably so :)
I didn't think anyone in this county still tied bales with metal.. untill I was hogging and found some and spent an hour under my 10' hog ( propped up on a stump for safety ) with a pair of gas pliers unspooling it before it ate a seal... yummy stuff.. :)
   / I will never use poly twine again #35
probably so :)
I havent seen sisal for 15 years or so ....cant say i miss it !
   / I will never use poly twine again #36
I used sisal for years but got tired of it rotting on the bottom of the rolls after just a few months. I like how it decomposes but the rolls lose their shape and get loose after it rots. They don't shed water as well. I switched to plastic many years ago and just have to make sure I pull all of it off the roll when I feed. The twine I use is bright yellow and not real hard to see.
   / I will never use poly twine again #37
I buy straw from the amish up the road that is baled with wire. I guess the logic being to keep the mice from chewing through. I'm VERY careful where I put it after I cut off the bale. It is always useful later, just not around my shafts!!! :licking:
probably so :)
   / I will never use poly twine again #38
yep.. bailing wire is like metal duct tape!
   / I will never use poly twine again #39
Years ago, late 1980's, I did a couple internships at horse farms in Lexington Ky. They got in some alfalfa from out west with 3 wires on them, 150lb bales or better. I have a 1940 Case NL stationary baler that uses precut wire. I take in to threshing shows sometimes to display and bale a little straw. Most time we run it off a belt of a AC WD-45.
   / I will never use poly twine again #40
The TSC in Hudson, NY stocks baling wire. Somebody must buy it or it would not be there.
But I haven't ever sold any twister parts for a NH wire tie baler.
(2) FIBERGLASS LADDERS (A58374)
(2) FIBERGLASS...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
17201 (A55852)
17201 (A55852)
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
