Buying Advice Small Tractor
/ Small Tractor #1
jdwb
Union Springs, Alabama
Mahindra 5530
Looking to purchase 30 to 35 hp tractor with turf tires used to pull a 6 ft finishing mower. This is for our local school. It will be used to cut 3 to 5 acres, fairly rough terrain. Need some ideas on the tractor to purchase.
/ Small Tractor #2
Will there be any other usage...like will a front end loader be purchased as well? Any idea of budget available? Any idea what dealers are reasonably close by?
There are a lot of great tractors in the 30-35hp range now, by quite a few companies. If you have rough terrain, it pretty much makes 4wd a no-brainier, but that still leaves a lot of other things to decide.
/ Small Tractor
We will only use it to cut grass and when I say fairly rough terrain, I mean it is not smooth like my home yard. It is not hilly, it is fairly level. We are a local Christian School with a very tight budget. We may have to look at used as well new. Dealers within 50 miles--New Holland, Kubota, Mahindra, John Deere, Massey Ferguson, etc.
/ Small Tractor #4
Get a old Ford or Massey little utility tractor.
/ Small Tractor #5
I second that. You can get a good older tractor for about $5000 to $12000 depending on the model options and conditions.
One thing to consider is who is going to drive it. If many different people are going to, I would say go with hydro because of the ease of operation(no grinding gears and riding clutches), If only a few people will operate it go with a gear drive, they are much more robust but take a little more knowledge to operate.
/ Small Tractor #6
Sounds like you would be better off with a Z-turn mower. Would take you ALOT less time. I have many customers that have had me
turn there fields(1-3 acres) into lawn. My Z handles it fine, and I can mow 3 wide open acres in about 45 min to a hr with my 60" deck
depending on how thick and wet the area is.......
These areas are not as smooth as there lawn, but not so bad as I bounce out of my seat. My Z goes 11mph, and if its too bumpy it will
remove my butt from the seat...... Ferris make a Z with suspension, but I had issuse with the ones I had. My Exmarks and Toro's have held up well.
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
ATLAS DRILL PRESS (A63569)
ATLAS DRILL PRESS...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
Cat D4G Dozer (A64047)
