Buying Advice Small Tractor
/ Small Tractor #1
jdwb
Union Springs, Alabama
Mahindra 5530
Looking to purchase 30 to 35 hp tractor with turf tires used to pull a 6 ft finishing mower. This is for our local school. It will be used to cut 3 to 5 acres, fairly rough terrain. Need some ideas on the tractor to purchase.
/ Small Tractor #2
Will there be any other usage...like will a front end loader be purchased as well? Any idea of budget available? Any idea what dealers are reasonably close by?
There are a lot of great tractors in the 30-35hp range now, by quite a few companies. If you have rough terrain, it pretty much makes 4wd a no-brainier, but that still leaves a lot of other things to decide.
/ Small Tractor
We will only use it to cut grass and when I say fairly rough terrain, I mean it is not smooth like my home yard. It is not hilly, it is fairly level. We are a local Christian School with a very tight budget. We may have to look at used as well new. Dealers within 50 miles--New Holland, Kubota, Mahindra, John Deere, Massey Ferguson, etc.
/ Small Tractor #4
Get a old Ford or Massey little utility tractor.
/ Small Tractor #5
I second that. You can get a good older tractor for about $5000 to $12000 depending on the model options and conditions.
One thing to consider is who is going to drive it. If many different people are going to, I would say go with hydro because of the ease of operation(no grinding gears and riding clutches), If only a few people will operate it go with a gear drive, they are much more robust but take a little more knowledge to operate.
/ Small Tractor #6
Sounds like you would be better off with a Z-turn mower. Would take you ALOT less time. I have many customers that have had me
turn there fields(1-3 acres) into lawn. My Z handles it fine, and I can mow 3 wide open acres in about 45 min to a hr with my 60" deck
depending on how thick and wet the area is.......
These areas are not as smooth as there lawn, but not so bad as I bounce out of my seat. My Z goes 11mph, and if its too bumpy it will
remove my butt from the seat...... Ferris make a Z with suspension, but I had issuse with the ones I had. My Exmarks and Toro's have held up well.
3PT HAY SPEAR (A63291)
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
John Deere 412R (A63688)
John Deere 412R...
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
