Posthole Digger Land Pride PHD shear bolt
/ Land Pride PHD shear bolt #1
RobA
Chester County, SE PA
Kubota L5030 HST
I have a Land Pride PD15 post hole digger. Was using it a while ago and the auger stopped turning. I'm assuming the shear bolt broke but haven't had time to look at it. I looked at the manual before trying to fix it (and get myself in trouble as usual) and am confused as to how or what to try to fix. The PD15 does not have a clutch. The manual shows the shear bolt at the entire Eurocardan driveline (#12 in diagram, "Driveline (826-164C) Eurocardan Shear Bolt"). I don't get it.
/ Land Pride PHD shear bolt #2
There is two shear bots that attach the auger to the drive
Thanks, if that's the case #4 in the diagram must be the shear bolt. They have it listed as "HHCS 3/8-16X2 3/4 GR5" and "HHCS 3/8-16 X 2 3/4 GR2". Not sure why they are listing 2 different grade bolts.
/ Land Pride PHD shear bolt #4
Good question.
/ Land Pride PHD shear bolt #5
My oops my drawing shows #8 as the shear bolt drawing #14770
/ Land Pride PHD shear bolt #6
#4 is the shear bolt. #14 is the stud that screws into and through the universal joint yoke, and then into the groove in the input shaft to the gearbox; when the shear bolt shears and the yoke spins around the shaft, this stud keeps the yoke from slipping off the shaft because the stud extends into the groove and just spins around in it.
Shear bolt breakage is a common occurrence with PHD's; I actually built a little bracket that bolts to the gearbox on my Bush Hog PHD to hold spare shear bolts.
If you can't find a factory replacement, just get a grade 3 hex bolt the same size as the sheared bolt; grade 3 is the weakest grade and it is unlikely the factory bolt would have been made of anything with less shear strength. In my experience, the shear bolts on PHD's are to protect the drive shaft; they are fairly long to reach from the tractor PTO to the gearbox when the PHD is raised completely, and to save money the manufacturers use a light grade of drive shaft.
A few manufacturers use a shear bolt with a reduced size on the thread end; I am not sure whether that is to drive you back to the dealer for replacements or to discourage you from using hex bolts from the hardware store because you might get a grade 5 or 8 bolt that is much stronger than the grade 3 and might not shear before the driveshaft were damaged. If that is the case, just drill out the smaller hole in the yoke to the same size as the larger hole in the other side of the yoke.
/ Land Pride PHD shear bolt #7
Thanks for the comeback Farmerford, That #4 is # 8 on my drawing that's why I put the drawing# on the post
/ Land Pride PHD shear bolt #8
OOPS: I took so long to write my response (got interrupted by business) that you got more responses that gave you good advice. Since Land Pride says a Grade 5 bolt is okay, I would use a Gr 5 replacement unless something else in the manual tells you that the GR 5 is only for certain drive shafts.
Thanks for the replies and help. Now it makes a lot more sense. I'll probably pick up several grade 5 bolts today and try to fix it this weekend.
/ Land Pride PHD shear bolt #10
Post what size you get for the next guy who does a search.
/ Land Pride PHD shear bolt #11
Go to tractor supply and get the g5 bolts. They are cheap there and you can get an assortment for future breakdowns.
Brett
I went to 3 stores yesterday: Lowe's, Tractor Supply and a local hardware store. They all had 3/8" grade 5 bolts but no one had 2-3/4". just 2-1/2" and 3". I need to figure out if the 3" bolts will stick out too far and interfere with anything. Or cut them to 2-3/4". I'll also try the tractor dealer tomorrow.
I wound up going to the tractor dealer where I bought the PHD. The parts guy looked it up (using the same manual I used) and then he suggested I just use a 3" grade 5 bolt form their hardware aisle. I bought several and fixed the PHD over the weekend. Thanks for all the help.
/ Land Pride PHD shear bolt #14
The two bolts that attach the auger to the gear box output shaft are NOT used as shearbolts. At least, not on the Leinback PHD's I have used. There is a reason for that.... Just imagine if you have the auger buried deep, and then you sheared BOTH of those bolts, what's going go happen when you lift up the PHD??? The auger is going to stay buried in the hole. This is why there are TWO bolts on the output shaft, and only ONE (shearbolt) on the input shaft (to the gearbox). Hopefully, you won't ever shear the pair of bolts off and not be able to pull the auger out of the hole.
On the Leinbach's, the PTO shaft has a set screw on the end that attaches to the gearbox. The set screws rides in a groove on the input shaft. This is so that when/if the shearbolt does shear, the PTO shaft will hopefully stay hooked up and not come off and start flopping around wildly until you can you disengage the PTO drive.
/ Land Pride PHD shear bolt #15
See post#7, We already covered that.
2015 MACK GRANITE (A65643)
2015 MACK GRANITE...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
6ft Teakwood Cowboy (A65583)
6ft Teakwood...
2002 Built Rite Utility Trailer (A66285)
2002 Built Rite...
Kubota Rock Hammer for Excavator (A65579)
Kubota Rock Hammer...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
