Yanmar, converting fixed speed Yanmar to variable speed.
/ Yanmar, converting fixed speed Yanmar to variable speed. #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I found a small fixed speed 3 cylinder Yanmar Thermo-king diesel that has no throttle lever for speed adjustment. I would like to change it to variable speed by replacing the injection pump. Not much information available from engine tags.
Does anyone know what is required? Perhaps just a new injection pump with a throttle lever?
Numbers on block are K6K29977
Valve cover
TK3.74
K29977
Any info would be appreciated.
Thanks 90Cummins
/ Yanmar, converting fixed speed Yanmar to variable speed. #2
I have a Hatz diesel with fixed throttle and wanted to change it to variable. I was told that all I needed was to change the governor spring (from a Hatz representative).
Wonder if that's all you need for your Yanmar??
/ Yanmar, converting fixed speed Yanmar to variable speed. #3
Positive ?, reason I ask is that all the TK 3.74 that I've worked on had a lever for speed control and a separate fuel shut-off solenoid.
Like this pic from a TK manual.... yours not the same ?
/ Yanmar, converting fixed speed Yanmar to variable speed. #4
What type of flywheel does the engine have? Is it adaptable to a clutch, or does it have an oddball flywheel with a fixed coupling to drive the compressor?
I've only seen the engine in photos, it doesn't have any levers on the injection pump but there is a closure plate where the lever would be.
The flywheel end has a PTO shaft with pulleys on it so I can't see the flywheel.
The owner said it is fixed speed with no adjustments.
I would think (hope) it could be changed with little effort/cost with parts on e-bay.
90cummins
/ Yanmar, converting fixed speed Yanmar to variable speed. #6
Well somethings up then cause if it was indeed on TK refrigeration unit it WOULD have a high/low speed lever.
See if you can find out the model unit it came from and I'll dig up a manual.
/ Yanmar, converting fixed speed Yanmar to variable speed. #7
Can anybody help find the HP and torque rating on this engine. Also is it similar to any other non thermo king yanmar engine. Thanks
/ Yanmar, converting fixed speed Yanmar to variable speed. #8
Looks like its only 12.6 HP? Why is this so heavy?
/ Yanmar, converting fixed speed Yanmar to variable speed. #9
The HP rating is likely at a lower rpm than L&G engines. Once you figure out the throttle/governor issue and raise the speed the HP will also go up.
Sorry, can't help with the speed issue.
Try this guy: Sheaffer's Town & Country Tractor. He's very knowledgeable and has great parts contacts.
/ Yanmar, converting fixed speed Yanmar to variable speed. #10
/ Yanmar, converting fixed speed Yanmar to variable speed. #11
/ Yanmar, converting fixed speed Yanmar to variable speed. #12
I do have one why do you ask?
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
2004 International 7400 C&C 017797 (A62613)
2004 International...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
