Handling Filled Tires
/ Handling Filled Tires #21
Glad to hear an 18.4-34 loaded is doable. I need to pull the left off my JD 6415 to install a fuel tank guard. My plan is to find out what size the axle hub bolts are and get two more as long as possible and cut off the heads to make guide studs. I am thinking of using a pallet jack and pulling the wheel/tire straight out far enought to install the fuel tank guard.
I have successfully R&R a 16.9-28 that was loaded and had a cast iron center.
I used to have to remove the outside tire from the dual rears every year on a 9000 Ford. Take them off in the late spring after breaking all the ground when starting to plant and then in the fall put them back on. These had the cast iron centers also and they were rolled to a nearby tree where they sat all summer till ready to start turning under the vegetation after harvest in the fall.
2 people work much better than one but as a strong young man I could do it alone, when you are young, you are invincible and nothing can harm you.
/ Handling Filled Tires #22
I did mine by myself. Left the center part of the wheel on the tractor. I removed one, rolled it up to a wall and left it leaning against it, put a jack stand under the tractor, and moved the jack to the other side. Two of the center bolts are actually studs which means you need to get the wheel perfectly aligned. So I decided to left the center on the tractor. Worked real well. All I had to do is get one of the bolts loosely into a hole, the tire doesn't even need to be that straight. Once you do you can just carefully raise and lower the tractor with the jack to get the others to line up and the tire will not fall over.
If you left the center on the tractor and swapped the tires from side to side, what did you accomplish? You have to turn the centers to gain the max amount of distance and by just moving the outside rim you didnt do anything. Also the two studs are there for alignment and you dont have to align perfectly, just get on bolt in the hole then you can wiggle it around on that bolt to get the other bolt aligned and then slide it on. Everything is then perfect for the studs.
If I were going to remove the center hub from the rim, I would just take off the hub then and turn it around, rebolt and then replace the tire on the same hub. That is way more work than just taking off the lug nuts and and swapping sides with the tire.
If your rims are like mine in the photo you can gain a couple inches on each side by moving the hub mount from outside to inside but the major move is in swapping the center hub to gain the cup distance.
This is a photo of the front on my tractor (rears are same type) and you can see how I narrowed the front tires by putting the hub to the outside rather than inside. IT was previously mounted to the holes at the valve stem. They are offset by 2 inches. My tractor came with the fronts wider than the rears and I never noticed till I tried putting it on my 83" wide between the fenders trailer. The fronts wouldnt fit but the rears fit tightly. With the camber on the front, it was not apparent that the fronts were 2 inches wider on each side till I tried to fit them between the fenders on my trailer. Now the fronts match the rear and the rims are mounted the same on front and back. I could put them back as they were on the front and then also change the rears to match and increase the stance by 4 more inches if I wanted but it wouldnt fit on my trailer then.
/ Handling Filled Tires #23
The Kubota tires, at least the 40 series, mount to the center disc differently.
/ Handling Filled Tires #24
We did loaded farm tiresall the time . Jack itup in the center of the tractor , just enough to get the bulge out of the tires . Now loosen everything up . Jack it up a little more to see which is the high side , the side that comes up first . Remember atractor pivots on the front axle . Now adjust the jack so you can remove bolts/nuts on high side wheel . You never want any space between tire and floor . You will feel when things are right .Keep adjusting your jack until ther eis no interference between wheel and lugs . Grab this tire by the top and walk it out , moving your arms back and forth , the tire will walk out . Lean this tire against something very carefully . Block up that side and move your jack a little bit towards the other side about 1" will do it . Proceed the same way and jackstand it . Walk that tire to the other side and lean it against the hub . Bring your jack back over and take blocks out . Notice the top hole in your hub and walk the wheel in . Always kee p the wheel leaning towards tractor . Adjust the jack until you can get anut started . Jack it up a little more and it will fall on . I could have changed them in the time it took me to type this. If you have any doubts , DO NOT ATTEMPT.
/ Handling Filled Tires #25
Yes you can do this by yourself . Those wheels are only waist high .
/ Handling Filled Tires #26
it's them head high ones that scare ya!
To kevin37b - thanks for that detailed description of the wheel changing process. As I read that, I could envision myself doing it. I have a floor jack under the middle of the axle for extra support, and a bottle jack at each side to allow for "fine tuning" of the height.
It's obvious that wheel assemblies vary widely with different makes and models of tractors, and on this particular one the disk must stay in the same position and the only adjustment is to turn the wheel around, the mounts in the rim being off-center. I'm still mulling over whether to remove the disks versus just unbolting the rim from the disk. Is it really a lot harder to re-align the rim to the disk than matching the disk and rim assembly to the axle? I have broken loose the rim bolts in preparation, but I guess I'll loosen lug nuts and bolts, too.
As far as the height of the tire, these 17.5Lx24 tires stand 48" tall. You must be a tall guy if they only come up to your waist! It's 38" to my waist, and if they were only that tall I'd have more confidence to tackle this procedure.
Still trying to psyche myself up to do it, and waiting for a helper that I can trust to actually help.
/ Handling Filled Tires #28
Next time I go to Portland & the mid-coast I can stop in and give you a hand!
/ Handling Filled Tires #29
Jim, I'll do your 17.5Lx24 if you do my loaded 18.4rx34 :laughing:
RickB, thanks for the offer, but we're currently at our place in Colebrook, New Hampshire, which is why we now need chains, hence the wheel widening. I was a hero moving snow around on the level going in Yarmouth, but on the hills up here things are getting a bit squirrely with ice underneath the snow.
Zebrafive, you must be one rugged dude to handle loaded 34" wheels, makes me feel like a wimp for worrying about our 24"ers. I guess I'm getting more cautious in my old age, but there's no getting around the fact that they must weigh about 7-8 hundred pounds and have to stay upright throughout the process.
You know, it's kind of ironic. We got the tractor as a labor saving device, and it sure is, but between changing attachments, transporting the tractor, doing maintenance on it etc, I sure have to do a lot of pushing, pulling, prying and lifting!
/ Handling Filled Tires #31
A little different design from the LS but the same principle. Kubota has one bolt whereas my LS has two bolts holding the rim, plus the LS is solid all the way around the rim with the S turn in and out continuously rather than just a single little lug. Install the center hub on inside or outside of the connection on the tire rim to change track by 2" per side. Flip the rim to move 4+ " per side. Your's looks to be at max width now.
/ Handling Filled Tires #32
It is obvious from your photo that if the center disc were as they are in this photo, they were already flipped to cup outward. Most tractors are installed with the cup in and the tire installed as you now have yours depicted. THis is why most folks have to flip the center disc rather than remove the outside hub.
Trying to get that bolt back in the rim from the inside and put an nut on by yourself must have been a real bear, I know it was on my LS front tires when I had to swap the rim lugs from outside to inside and it was only loaded with air.
I just removed and replaced both tires on my Kubota B26 this morning looking at the hydraulic relief valve and strainer. It took about 2 minutes to remove the lug bolts using my Harbor Freight 3/4" impact, pull the tire, then 5 minutes of looking at the PRV and determining that I couldnt work on it with what I had then not more than 5 minutes to reposition and mount the tire. It is only a 12.4x16 R4 and not loaded but I didnt lift it, just rolled it and raised or lowered the tractor as needed to get the bolts aligned, tightened the nuts which snugged and centered the other lug bolts. Then tightened them with the impact and all done. Of course having the backhoe stabilizers made quick work of lifting and lowering.
/ Handling Filled Tires #33
Yes definitely get a helper if you are the least bit in doubt . They are very heavy and if they decide to go you are not going to stop it . Make sure the floor is clean and dry . no slick spots or trip hazards .
/ Handling Filled Tires #34
yep.. plan your path.. and have an escape route!
/ Handling Filled Tires #35
The Kubota manual has three positions for adjusting the width. The center discs can't be reversed without the tire rubbing on the inner fender. The inner most position has the tire with the valve stem facing in. The next position is having the valve stem facing out but the disc on the outside of the brackets on the wheel. This is slightly, maybe an inch wider, than the inner most position. I have my wheels set in the widest position (as seen in my picture), the valve stem facing out and the disc on the inside of the brackets. To go from the innermost to outer most position requires the wheels to be swapped side to side. To go from middle position to the outermost would require the center disc to be removed from the tractor and the wheel so it can be mounted to the inside. Simply looking at where the valve stem is, facing out or in, should tell you if the wheels are in the innermost or middle position. Mine were set to the innermost when I got it.
Well, I finally did it! Got my wife to help me move the tires and got them swapped side to side. I took the advice about taking off the disks with a grain of salt, and loosened the lug nuts and bolts just in case, but I tried removing the rims from the disks first. The tires were too heavy to slide, even with a pry bar, and wiggling them back and forth was going to take forever until the rim would clear the disk, so I put a couple rim bolts back in and removed the lug bolts and nuts. Using the bottle jack I could get the height just right to rock the wheel free. Then we carefully rolled the wheel back and forth until it cleared the hub and we could roll it clear. We then switched around the disk on the wheel, set it aside and attacked the other one the same way. Getting them back on went well, by raising and lowering the axle with the bottle jack until we got them hung on the lug studs, and we were home free!
Thanks again to all who offered suggestions and encouragement. I really wanted to do this myself, and I was 95 percent sure I could, but the weight of the tires made me think twice about it. Having it in the garage, with a smooth floor helped a lot. I wouldn't have wanted to be rolling those tires on rough ground.
Now to get some chains!
/ Handling Filled Tires #37
I'm glad you had some help. As you well know now, they are a handful. Always best to be safe than sorry. - robert
Sent from my iPad iOS 6.01 - TNB v1.6
/ Handling Filled Tires #38
glad you got help.
if nothing else.. it's someone to call 911 for you ( NO JOKE ).
i always tell my wife if I'm going out to work on something that could pin me..e tc.
/ Handling Filled Tires #39
That's exactly one of the reason's I put this up in the new shop. Have my self spoiled with the one I put in my other shop, and not going backwards now. :)
I pulled the rears on my Massey 180, loaded 15.5 -38's, along with the spin-out rims, and center cast hubs all in one piece, one at a time, with a chain hoist on a trolley. Then rolled it away from the tractor, out of harm's way. Then brought another hoist on trolley in place to remove the axle housing. Oh soooo sweet.....!!
/ Handling Filled Tires #40
nice shop!
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
