Garage elevator man lift build ideas needed
/ Garage elevator man lift build ideas needed #21
Hi I was just on KIJIJI & there's a fork lift mechanism for sale in Ontario ,GTA ,maybe Peterborough , can't remember just now. Possibly do a search for forklift in Ontario.
/ Garage elevator man lift build ideas needed #22
I had a homemade elevator in a house I own and it was handy for moving quite a bit up stairs and down. Basically, it had an electric wench attached to a 4'x4' steel framed box. Everything was guided in the elev shaft by nylon strips screwed to steel channel. The controls were at each floor and in the elevator with deadman switches to trip if you left anything outside the shaft or in the shaft. After using it for a few years I started to get concerned with the wench and switches acting up and finally replaced it with a spiral staircase.
Also, I started to "chicken out" since this was the first one the guy had built and he later put one in a new house he built with the "worm style" that you are proposeing and it fell with him in it and broke his back. Just be careful and consider kids making it their new play toy.
/ Garage elevator man lift build ideas needed #23
Mine goes from the basement to a closet on the first floor. It uses a pair of 16' boxed barn door tracks. The tracks are mounted to the wall studs on the 1st floor and to a metal Unistrut frame bolted to the basement floor.
The metal frame "L" shaped lifting carriage is supported and slides along the tracks held in place with the bolts from 4 barn door track trollies. To avoid metal to metal contact, 1/2" thick, 2" dia 'pucks' cut from HDPE (aka white cutting board material) are placed on the bolt shafts, these provide lubrication between the metal surfaces. The trolly bolts have double nuts and are safety wired.
HF largest hoist provides the lift, these have a build-in braking system to prevent a run-away situation.
It's been in use 2 yrs. Recently the cable started showing the beginning signs of wear so it will be replaced with one twice as thick.
At some point I like to replace the HF winch with an elec chain hoist, problem is they're so heavy....
Next time I'm up at the property I can get pics if anyone is interested.
/ Garage elevator man lift build ideas needed #24
I would like to build a man lift/elevator with a 1000lbs capacity. I have been looking for a used palette lift but haven't seen one locally for over a year. Shipping is cost prohibitive. The attic opening is 4x6' and the total lift height needs to be 9' The platform should also fold to save space when not in use. I was thinking of hydraulic or worm gear type or even a winch with pulleys. Open to suggestions! What size/type and thickness of steel should I use? Thanks Eric
I design freight elevators for a living. From what you are describing you are looking for a small cantilevered platform type of lift. not sure why you feel you would need the platform to fold to save space. lifts come in every configuration under the sun and I've probably worked on more than that at one time or another
A single column supporting from one corner has the highest stress loading moments of any design next would be a single wide column located on one end. A scissors type would require excavating a pit and for stability a single or pair of vertical guide rails are advised. There are many safety codes that must be followed some are more stringent than others especially if this is going to be used for human transport along with the lifting of freight.
For VRC vertical reciprocating conveyors the code that most low height freight only lifts fall under is ANSI/ASME B20-1 For elevators used for human transport the code is ASME A17. Those are the 2 main ones but there is also standard for conveyors and related equipment / JORDAINAN LIFT SPECIFICATIONS /EUROPEAN STANDARD (EN 81-1: 1998) / BRITISH STANDARD (BS 5655) just to name a few
For private home use like in your barn you will not have to meet every aspect of each of these however if you were to install a lift of any type without at least meeting the minimum standards of safety in regards to fire or personal property damage or human injury. should anyone be injured as result of failer you can be held liable.
That being said here are a few tips.
#1 worm screw drive as someone said the brass nut will wear and can allow the platform to fall to prevent this use a follow nut under the support nut the follow nut never carries a load and should the drive nut slip it will be there to prevent damage this is acceptable in the codes and to ANSI standard B153.1
#2 Hydraulic; there are 4 main accepted ways to do this one is using a ram under the platform requiring a hole to be drilled and an environmental sleeve installed to prevent soil contamination in event of rupture. the 2nd hyd use is called hole-less this has the cylinder mounted in or between the support columns one method is 1 to 2 ratio push the cylinderis secured and had a pulley or sprocket over the rod end usually one end of a chain or wire rope is anchored to the platform the other at the base of the cylinder a minimum of 2 should be used per cylinder 1 to carry the load the other as a safety for many lifts there are as many as 2 to 4 cylinders with 2 chains and 2 safety cables and sometimes more than that for heavy lifts.
The 3rd method is direct acting hole less this requires the cylinder to be as long as the rise height either pulling or pushing. In any push type method the rod diameter must be large enough to prevent buckling
The 4th method is using the cylinder to pull on a pulley again sometimes several are incorporated this method can be used to achieve 2 to 1 3 to 1 4 to 1 even 10 to 1 pull just like using a block & tackle each ratio up grade causes the platform to move faster while requiring a larger diameter cylinders or higher pressures or both
The method I use almost exclusively is the last one at 2 to 1 ratios most of the time for lifts with less than 40 ft rise over 40 ft rise 3 or more to 1 ratios I also incorporate many redundant safeties since my lifts are commercial and must meet all codes with a human operator
Let me know if you require a preliminary design Due to legal reasons I can not and will not post or publish a complete design however I can and will send you some specific guidelines and how to's so that you may extrapolate on these and design your own I will (GIVE) you any advice that I am legally allowed
/ Garage elevator man lift build ideas needed #25
Here is a photo of one of my lifts being tested it is an 8 ton lift with 20 ft of rise note we have more than 20 tons loaded on the platform
This is metric tons by the way
Some of my lifts are very special purpose
This one has dock levelers on both ends and is over 40 feet long
but some are tiny only capable of 2 tons
/ Garage elevator man lift build ideas needed #26
ttRiff the problem with a winch using a cable is there is only 1 suspension rope.
And remember cables have a minimum bend radius going to a larger diameter cable will not make it last longer most cases it it will shorten the service life. Using a highly flexible cable can extend the service life Think of a mobile crane, you will never see 6x19 class cables on one of them 7x37 is almost twice as flexible as 6x19. In the case of a winch the larger the drum diameter the longer the cable will last however the gear reduction may have to be changed
Does your platform have an automatic breaking or locking system that engages if the cable were to break? if not it need one.
/ Garage elevator man lift build ideas needed #27
Frank ,If you would send me any info as these are projects I want in my new place and its always easier to install while building rather than trying to make them fit later .Thanks
/ Garage elevator man lift build ideas needed #28
This is like the lift I described above.
Dean,
We have an old blacksmith shop near me that uses one of those, but the platform is big enough to put an entire carriage on to move it to the second floor for storage. I think it had knots in the rope, but wouldn't swear to it as I haven't been in there in over 40 years.
/ Garage elevator man lift build ideas needed #29
Interesting thread! As we are designing a new home (and we are in our mid-50's), we are looking to make the house as accessible as possible. And we noticed that a stairway takes up a lot of space on both floors! We will have a basement because the cost of this space is cheap, because the taxes on this space are low, and because we have a walk-out sloped lot. But it would be great to have a personell elevator instead of a stairway. Is there a reasonably priced residential elevator? It should be big enough for a wheelchair I suppose, and it would be only a 10 foot lift. Do you know of options I could consider? thanks!!!
/ Garage elevator man lift build ideas needed #30
I don't know of anywhere in the world where an elevator only as a means of traversing from one level to another is accepted. On low structures having 3 floors or less an elevator may be used in conjunction with a tight wound spiral stair case on rare occasions
I tight wound spiral stairway is considered 6 ft diameter or less.
There are residential elevator manufactures who offer elevators as small as 24 inch by 30 inch interior cabin dimensions
These are usually only hidden in a closet.
When designing home for an elevator a couple of options could be to design the stairway around the elevator shaft-way. Even better is to design for a vintage look like the old open meshed cabins with concertina doors. There are even the vintage looking controls with modern electronics
I someone likes the look of a circular stair they may consider using a round elevator car .
I am not a licensed or registered passenger elevator designer, so I refrain from making very specific recommendations, also I would chose not to recommend one manufacture over another. I often purchase propitiatory and patented controls and safeties from several for my freight lifts since at times it is more economical than making these myself. But All passenger elevator manufactures do this as well.
/ Garage elevator man lift build ideas needed #31
Here is something for those who have an extreme sloped lot. Back when I was building boat houses and marinas this was a solution for one customer to get from their home down to their dock.
/ Garage elevator man lift build ideas needed #32
so basically your saying nothing ?
/ Garage elevator man lift build ideas needed #33
Its not that I am saying nothing I am simply making sure it is clear that I do not do elevators for passenger service. Although I imagine that at one time or another someone has ridden every one of my lifts, probably on a daily basis. I just don't condone it,
And I was pointing out that any house so far as I know requires an alternative means of going from one floor to the next additional to an elevator. This might be something as simple as a ladder in some cases. like getting up to a loft.
There are several reasons why there are fire & safety codes. I feel that some of them are carried to the extremes at times by local municipalities.
/ Garage elevator man lift build ideas needed #34
The subject of DIY elevators or a simple way for someone to construct a means of lifting materials in a barn or other building is needed by some folks.
1000s of years before there were safety standards large stone blocks were raised by ropes by the use of blocks & tackle pulley systems. When something went wrong objects fell often killing many people.
Modern high rise buildings were limited in height because there was no safe means of transporting people to the upper floors without them having to climb numerous flights of stairs. Not until the invention of an automatic way to prevent an elevator car from falling did very tall buildings start to be erected. You can look up the history of the elevator for all of the gory details
However somewhere along the line safety systems over took practicality for limited use lifting systems.
No lifting device may be used to transport people vertically horizontally or up an incline either commercially or in a private home without meeting these often very stringent safeties. These are at best very confusing to folks who need a means of lifting objects or desire a means to go from one floor to the next without having to climb stairs
What is needed is a simple explanation of a few of the most pertinent safeties.
First and foremost is a device that automatically prevents the platform or cabin from falling there are many things involved in this depending on the means the platform / cabin is raised these can become very involved , far too numerous to even try and explain. This has to deal with velocities, redundant suspensions and many others.
Next is preventing anyone from accidently being injured by pinch points. These are pretty much self-explanatory there should be no opening large enough for a person to extend their arms or legs to any part of the lift that may injure them.
Next is fire prevention. Elevator shaft ways can become chimneys which accelerate or increase fire damage. Non-enclosed shafts and exposed mounted open platforms do not. However they can do nothing to prevent a fire from traveling to the next floor level.
Electrical safeties fall under a National electrical code
With hydraulic lifts or elevators there are minimal precautions which must be followed to prevent contamination from spillage
For mechanical or geared lifts refer to the first requirement.
These are some of the absolute minimum things to consider when thinking of a lifting device or elevator
When searching for a manufacture for a lift to be used in a garage or barn try not using the word elevator it may help to find a more economical device. Explaining its primary use as a means to lift materials up to a loft area or mezzanine also helps
/ Garage elevator man lift build ideas needed #35
Doesnt a house with a walkout basement already have a way to get to the other level? You go outside and go back in the door on the other level. In addition, there are legal egress windows required. Seems to me that an elevator taking the place of a stairway is changing one method for another. Either method could be blocked by fire or collapse, but there is always the other path of going outside to get out or to the other level. Saying I still need to have a stairway if I have an elevator makes no sense. A stairway can also act as a chiminy in a fire, or allow fire top pass from one level to another.
NOW, I have hijacked this thread far enough. Obviously I am talking about a personell elevator, and the OP is asking about a freight elevator, and the expert (Frank) is not qualified to specify residential personell elevators, but is helping a great deal for the original subject. I will re-direct my inquiry to another google search or a new thread. Thanks.
/ Garage elevator man lift build ideas needed #36
I have searching through my old archives to see if I could come up with a light duty unit that I had designed. the problem here is since everything I have built is used in the industrial sector with the structure having a minimum FOS (factor of safety) of 5 to one and suspension cables @ 8 to one. This is the lightest duty lift in my archives and it has some special features not normally found on lifts as well this is a 1 ton rated lift with a 5 by 7 ft platform 15 ft of rise surface mounted so that there is no obstruction in the walk through area when the platform if in the up position the ramps allow for loading from either end it is off loaded from the side when raised if the pressure of the pump is adjusted to its max setting the lift would raise over 3 tons
ON one service call my tech noticed they had figured out how to monkey with the pressure settings and were lifting 5000 pallets. He readjusted it back to the 125% setting then cut the adjustment bolt off
I do have some single and 2 column lifts but they are much heavier one is 6 ton rated
/ Garage elevator man lift build ideas needed #37
On a personal note if I were going to build a simple lift for my own use and only needed a 500 to 700 lbs capacity I would probably use something similar to the one someone mentioned in an earlier post with 2 heavy duty overhead door channels mounted to a wall or use standard "T" rails like used in passenger elevators as the vertical guides. I wold concentrate on putting the strength in the platform making it "C" shaped lifting it from the top of the "C" as near to the center as possible with a spring loaded locking device that would grip the vertical guides automatically in the event the lifting cable or chain were to break
/ Garage elevator man lift build ideas needed #38
Pleased to see you received a more positive response here, than on the other forum.
/ Garage elevator man lift build ideas needed #40
The problem of the lifting cable breaking can be easily avoided. You simply use one that is many times stronger than you need, and inspect it periodically.
The winch gearing, and brake or locking mechanism, is where I would be concerned. That seems much more likely to fail, allowing the winch to slip, or freewheel.
This is especially concerning, since some people are apparently trusting their life to HF quality??? :eek:
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2007 TUG GPU 400/60 28V 60kVA Towable Diesel Generator (A59228)
2007 TUG GPU...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
