Tractor Sizing What size tractor do I need?
/ What size tractor do I need? #1
Matthewf13
Hi guys,
I am buying a tow behind rough cut mower this year to cut my 10 acres. The mower weighs about 500 pounds and my land has small hills on it. I currently have a Craftsman with a 24hp B&S Intek engine, do you think I need something bigger? Recommendations?
/ What size tractor do I need? #2
Are you really cutting 10 acres with a chraftsman lawn mower??? Must take a long time.
Haha..I hire someone to cut it for $450. My fields are WAY too thick to mower with a little mower.
/ What size tractor do I need? #4
Hi guys,
IF you've settled on a mower and its got its own motor i'd pick up an ATV it will ride better over rough ground since it has shock absorbers rather than you being the shock absorber
/ What size tractor do I need? #5
I second that. Or a side by side for comfort.
/ What size tractor do I need? #6
Hello Matthew,
I would recommend a John Deere in the 2000 series(2005,2505,2720).
You'd have plenty of power to pull your new mower. I don't know how your Craftsman will do with that much weight on the back when you get to the hills. If the grade is steep, even on a small hill, your Craftsman may not be able to handle the stress of the constant use. 10 acres is a lot of mowing.
The JD will give you a lot more options than your Craftsman will. It will be much more versatile than the tractor you have now and I believe that you will get a lot more use out of it. I get a lot of use out of mine!
/ What size tractor do I need? #7
Mattthew,
If your fields are that thick, you might want to consider something in the 3000 series......
You can look at the Kobata too. My friend has one and he likes it.
/ What size tractor do I need? #8
Yea, you need something in the 3000 series with a rear brush hog. Id forget about the pull behind mower completely, I dont think you will be happy with that setup with 10 acres.
/ What size tractor do I need? #9
I guess first of all we need to know if you plan on keeping this like a yard or just mow it three or four times a year? I assume since you said rough cut your just looking forward to mowing it every two or three months. In that case I would get a compact tractor or utility tractor with a bush hog in the 30 to 60 hp range. If you want to keep it like a yard hands down get a zero turn mower. That is just way to much to mow with a basic mower and too much time unless you have a fold out finish mower. For a zero turn to make any good time it would have to be pretty smooth.
/ What size tractor do I need? #10
You will be surprised at how fast you can cut 10 acres of pasture grass with a lawn mower with a 60" deck if it is smooth enough to run at optimum speed. SOME of the larger commercial grade mowers with the larger tires and suspension seat will mow at 10MPH (claimed speed) and with very little overlap plus no turning and overlapping around trees or other obstacles, they will beat most tractors pulling a 6 foot bush hog. The only negative is they wont cut saplings but small bushes and weeds are dog meat with them. I mow about 5 of my 11 acres with my ZTR mower in about 2 hours or so which includes several dozen trees, flowers and shrubs and 2 pond levees to mow around.
/ What size tractor do I need? #11
A tractor is a multi-use tool.
Get a good ZTR if mowing is the only chore you have.
Good luck
I actually should only have to cut 3-4 acres once a month and then the other 6 once or twice a year. I am actually trying to sell my second piece of property (the 6 acre piece) which is why I don't want to get a big tractor. and when I say hills I mean a very slight incline. Nothing much..
My tractor will pull a 3 1/2 by 6 foot chain harrow with little problem as well. She is definitely tough.
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2018 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2018 Ford F-150...
207269 (A52708)
207269 (A52708)
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
