used trailer help
/ used trailer help #1
hchxoom
SE US
JD
I've been looking off and on for a trailer to periodically tow a tractor (JD 5045) and implement or two back and forth to hunting property, and for other nonroutine hauling. Haven't been in a hurry since I could borrow or lease once in a while... just kind of waiting for the right deal/time. Been looking for a double axle 10-14k with brakes at every wheel, 22'-28' range gooseneck. Will pull with a 2010 diesel f250 (4x4). I trailer a horse periodically, so not new to towing, but am new to equipment towing.
Found this one the other day... 25+5 dovetail, tandem dual 10k dexter axles. It is heavier than I was looking for, but if the price is right it might be worth the extra capacity in case I need it in the future. I haven't seen it yet, and wanted to get some advice from TBN experts on what to look for (and what to look out for). I don't mind a "beater" as far as looks for my limited purposes, as long as it is structurally sound. I am pretty insistent on new tires on any trailer I tow, so assume the first thing I'd do on any used trailer is get tires.
Any downside to a heavier trailer like this? Any tips, or traps to avoid?
/ used trailer help #2
I bought a used hd trailer last year. The price was right but I did have to replace a bearing, and a broken leaf spring that I didn't catch. I'm like u, I want new tires on a used trailer, I replaced 4 last summer, and will do the rest this spring.
/ used trailer help #3
Check welds for cracks, bearings, wheels for cracks, brakes, lights, wiring, wood deck, ect.
I am in the trailer business and 9 times out of 10 you can buy new by the time you end up fixing what is wrong with used.
On that trailer figure on 8 tires, $1200. 8 bearing kits, $250 if you do it yourself. 8 brake backing plates, $400 if you do it yourself. New lights and wiring, $200 if you do it yourself, extra $50 if it needs a new brake-away battery. New wood deck, $400 if you do it yourself. As you can see a used trailer can get expensive quickly.
One comment on that trailer. For your equipment you will be fine but the ramps look light weight for a 20,000# gvwr trailer from the pic.
Chris
/ used trailer help
Thanks, Chris... very helpful. Yes, I've priced out a Kaufman 15k the way I'd want it at a little under $6k. Not as heavy duty and a little shorter, but new with no worries. I think I could get the trailer in the pic for about $4k, so if it checks out structurally would be all-in similar cost.
/ used trailer help #5
Chris
These figure sound a little high to me. I know I get get some for a lot less. But I do understand your point.
/ used trailer help #6
What does the trailer weigh? I am guessing 6000lbs empty. If your tow vehicle is rated for 12,000lbs that leaves 6000lbs for cargo.
Only down side I see is if you can't handle the weight of the trailer and load with your tow vehicle.
/ used trailer help #7
After looking at the picture, I'm with Diamondpilot on this one. Spend a little more and get a new one.
/ used trailer help #8
I'm not a trailer expert but the paint, if there ever was any, seems to be gone on that trailer. Was it a factory branded trailer or a shop built? I know you say you don't care if it's a beater but if you are going to get it and spend money and time to fix it up, not counting paint and your time, and still come out at about the same as a new trailer, why would you do it?
I've bought used trailers and I've bought new and I believe DP is right in 95% or more cases. The exception would be if you found an almost new trailer at a good price or if an old trailer was just dirt cheap.
/ used trailer help #9
Pilot is right on asfar as future expenses .The trailer does not look bad structurally . If you are going to use it the brakes need to work . I find that to be the biggest problem . Pilot has some good info on controllers . Like Chris says , you may be better off with new . Used trailers are a good way to pi$$ away money
/ used trailer help #10
I bought a Betterbuilt 20' + 2', 14K gross bumper pull with brakes on both axles, spare tire, xtra tiedowns, chainbox, sealed wiring harness, ramp assist for $4300 tax include last year.
New is cheaper!
/ used trailer help
Thanks, all. Really good advice and I appreciate it.
/ used trailer help #12
If you can buy the stuff cheaper please let me know where? I am in the business and this is the best I can do on 10k axle stuff. Yes, 3.5K stuff is less but we are talking a big trailers here.
I put $3000 in brakes parts alone on a 25K trailer before with 12K axles
Chris
/ used trailer help #13
Another thing to consider is DOT, that trailer would put you into needing DOT inspection and under the all the requirements by DOT in Texas. Unless running farm tags. Just going by looks, that trailer has seen some use and @ 4K I would scrutinize it carefully. I have bought several 40'ers, some new and some used. I got 1 used one that bit me in the ***, ended having a bent axle and would tear the tires up in 10k miles. 10 k axles are not cheap
2001 TAKEUCHI TL150 SKID STEER (A64279)
2001 TAKEUCHI...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A61573)
2013 International...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
