Only front chains?
/ Only front chains? #21
Alright let's see if I can explain this correctly. The front drive on these tractors is more of a assist then a full time 4WD like on bigger equipment sooo it is not quite as robust as the rear drive. The drive ratios and tire sizes are set up so the output ratios are the same to the front and rear. So when you are in 4WD the front and rear drives ARE locked together and spin at the same speed in the DRIVE TRAIN, does not make any difference the tires are different sizes because the gear ratios take care of the tire size difference. Now when you put front chains on the stick up farther than the rear chains well you just effectivly changed the tire size and also messed up the gear ratio that the factory had worked out, sooo this put the driveline into a bind in 4WD and it does it even going in a straight line. With the 4WD out it will NOT bind up. So basically if it were me and I had all 4 chained up I would not use 4WD unless I was just getting unstuck. I would not chain up just the front either. The rear is designed to take all of the torque all of the time so the rears would get chained first and the fronts only in extreme conditions like ice.[like we are seeing now] I am still going to just use the rears and see what happens. CJ
/ Only front chains? #22
Sorry I call BS on this. I understand what you are saying, but just isn't significant enough to cause the "binding" you are describing on dirt, mud, snow, or ice. And these are the only conditions we use 4WD. 4WD on pavment or concrete is bad for the drivetrain chains or no chains.
And the text I bolded is simply not true, unless I am not understanding what you are saying. Front and rear tire sets need to be matched. If you change the rear you should change the front by a proportionate amount.
/ Only front chains? #23
Again it is very simple The gear ratios are set to allow for the tire size difference. I'll tell you what put a tire 1" smaller on the front or back axle of your 4X4 truck lock it in 4WD and drive it on a dirt road, [you said dirt would not matter right?] then try to unlock the 4WD and I promise you it will not unlock because it will be in a bind.I used to have people come into my shop all the time who put new front tires on their 4X4 and it would not unlock. Well with the old tires on the back I just laughed and move 1 new tire to the back and the old to the front and it magically fixed itself!! you can call BS all you want but unless you have been doing repairs for the last oh 20+ years or so on stuff just like this I will go on what I have seen and what makes sence. Remeber it is your tractor and you can do what you want but don't complain when it breaks.
So your last sentence you explained it to yourself, YES if you put a 2" bigger OD tire on a 4X4 vehicle you need to put a 2" od bigger on each axle. Now on units like our tractors with different gear ratios front and back to make up the difference on tire size I honestly do not know if the sizing holds true or not, I have never tried it for myself with equipment. CJ
/ Only front chains? #24
All I know is that I have been running chains on all 4 to snowplow for years with my DK 35.
In the winter I never take it out of 4 wheel drive till spring.
Works fine for me. No damage, no windup. Just goes where I want it to go.
/ Only front chains? #25
This appears to be just describing an open differential. I don't see how chains could possible cause and issue in absence of any other support or explanation.
What my dealer was saying is with chains on the front the slippage that normally occurs without chains is hampered and does not allow the front differential to do what it was designed to do. The only documentation or support explanation provided at this time is the reputation of someone with 50+ years of owning a tractor dealership and the results of fixing broken tractors during that timeframe.
/ Only front chains? #26
Vince what kind of chains are you running? Are they standards or V-BAR? CJ
/ Only front chains? #27
I'm still learning, but from what I read in my owners manual the fronts are sized and geared to turn about ten percent faster then the rears when new to give the fronts a positive bite for steering so they will pull the tractor in the direction you want to go. As the fronts wear down, and they will wear down faster then the rears in most cases they will get closer to even with the rears which is OK but eventually they will be enough under size that the rears are pushing them which is bad as it makes the tractor hard to steer. When that happens you need a new pair of fronts. Putting chains on just the rears gives them an advantage and uses up some of that ten percent the fronts started with but when new should not be a problem. Putting chains on all four should maintain the balance but I might go with a less aggressive chain on the fronts to allow slippage when needed rather then have the whole weight of the tractor hanging on the side of a U joint when it is turned to full steering lock. If your fronts are noticeably more worn then the rears chaining just the fronts might be a good thing as it would restore their original working diameter. I still wouldn't flog it while making a hard turn though.
/ Only front chains? #28
I could see where the added traction of the V BAR chains and a gear tractor could break something in the front diff. The hydrostat does really cusion things a bunch. I know with the front chains on I could literally climb right up the snow pile. The bottom line is you are taking a chance, is it worth it, well that is for each one to decide. For myself no front chains unless we get alot of ice. I really don't need them, been doing good so far. CJ
/ Only front chains? #29
As stated earlier, I have DUO's on the rear and some very worn (v-bars shaved level with link) small truck chains converted to 2-link ladders for the front (of DK35).
I use 4WD mainly hills and virtually all of my snowblowing is on a hard-packed snow (not ice) base. I can sometimes see the fronts giving a bit when moving up a hard-packed section. I think it is important to maintain a steady, smooth pace with no shock load. That may required going slower than the tractor/blower's capacity, particularly uphill.
The times I do notice some minor slippage and shock is when I am in 2WD and the DUO's give way in those bare patches between the patterns. That's when I'll use the 4WD.
Going by feel, I don't sense I'm stressing anything under my road conditions and operating speeds. I think I am much harder on the front end in the summer when moving a full bucket of gravel or fresh-cut birch down a steep, hard-packed trail with the front end doing all the braking.
I think it is important to minimize shock and stress as much as possible through smooth operation. I'm no expert but it seems a lot of it can be sensed through feel. For example, I make turns as wide as possible, especially in 4WD. On the DK35, and on firm ground, there is a noticably tighter feel to everything from the last 1/2 revolution of the steering wheel to the tightest possible turn. It's OK to go to the limits when necessary but good to make it as easy as possible for the machine.
/ Only front chains? #30
Standard 4 link ladders, front and rear.
I'm pushing a 9' converted truck plow and traction is really good.
/ Only front chains? #31
Thanks, it seems like the 4 link would allow some slippage. Good to hear they grip good. CJ
/ Only front chains? #32
Vince, If you don't mind I have a couple of questions. I am using a 7 1/2' QA plow on a DK45 SE HST with R4s and loaded rears, no real ballast on 3ph.
Do you have loaded rears and or additional ballast?
Do you plow on hilly terrain?
Do you get mainly wet or dry snow?
Do you use the FEL in float mode?
I have no real problems with dry snow. Wet snow I should put my Duos on the rear, but the ride is just plain awful. So I get stuck a lot backing up hill and have to curl the plow to get going again. My front end would rather slide sideways than push a bank of wet snow off to the side w/plow angled. If I use the float mode I just lift the front end off the ground. You seem to be doing fine with that 9' plow so I am trying to figure out your secrets. Thanks Don
/ Only front chains? #33
seacap04
Here is an older photo of my setup.
R-4 tires, Loaded rears, 4 link ladder chains front and rear.
And A 7' rear blade.
This year so far we've had around a foot of light/dry snow. On average I would say we get 70% dry snow 30% wet.
I never use float on my FEL. Puts to much weight on the blade and can't steer. I set the loader down with just a small amount of weight on the blade and go.
The blade follows the terrain just fine this way.
I do not use float and put chains on the front to help with steering.
Even with chains the front can still push with the blade angled on accasion in heavy/wet snow. But its not a problem as long as I don't let the snow get too deep before plowing.
Man I was about to drop the hammer on some chains but figured I would check this thread I started one last time. Some times I regret getting on here because I am back to square one. The fact is a lot of my snow removal I have to run parallel along slopes and hills. This is almost impossible since every time I float the bucket the front end slides sideways down the hill. I obviously do not want to hurt my tractor but need a fix or else I just have a really expensive snow shovel.
Sooo , let me ask this, would a high quality set of rears give my tractor enough grip in the rear as to prevent the front end from sliding sideways.
/ Only front chains? #35
Doubtfull.
Personally I would put chains on all 4 and quit using float.
/ Only front chains? #36
This has probably been mentioned previously but it should be noted when changing tire sizes on a FWA, the change needs to be worked out as a percentage rather than simple addition. For example, adding 2" to rears of, say, 40" diameter results in a 5% change. (2 divided by 40) Adding that same 2" to the fronts of, say, 24" diameter would result in a change of approximately 8%. (2 divided by 24) The result of this scenario would be that the fronts will be "leading" the rears by much more than the design intent. The same result would occur when chaining the fronts and rears assuming that the chains increase the OD by the same amount front and rear. The front wheels would be trying to outrun the rear wheels resulting in more stress on the front drive. Not saying it would or would not be catastrophic over time.
Doubtfull.
Not necessarily float but dropping the bucket and taking weight away from the front.
/ Only front chains? #38
If I were you I'd buy a pair of rear chains and use them. If after doing so you still see a need for fronts then go for it. You're going to slide sideways even with chains in some situations, unless you get a pair for around $1600 or more, with studs, like my dealer showed me in his catalog. That's for just the rear!!:eek:
/ Only front chains? #39
Thanks Vince That info helps a lot
Yeah Dingo Man A lot of info to digest on this thread. Thanks for starting it.
/ Only front chains? #40
im using standard 2 link chains myself. i thought the vbar would be too aggressive, plus damaging to concrete pad where its parked. so far i am real happy with the chains...on all 4 tires.
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
2003 Freightliner FS65 Converted School Bus (A64194)
2003 Freightliner...
