Mowing Kioit Rx Pto shaft breaks
/ Kioit Rx Pto shaft breaks #1
kiotirx
Belgi
Kioti RX
We recently bougth a nex Kioti Rx with electric PTO start. I used to have a Deutz where you could engage the pto slowly with the clutch. But now it's electric, so it's immediately on full speed. I have put our Peruzzo mower on it and the first thing that broke was the Pto shaft to the mower. I have put a heavy duty PTO shaft and now the transmission in the mower broke. Is there a way to have the Pto speed build up slowly on the Kioti, or do I need an other sytem of Pto Shaft?
Help me before I have more costs.
thanks
/ Kioit Rx Pto shaft breaks #2
Welcome!
Only engage the PTO with the tractor at an idle, then build your RPMs up at a steady pace.
Hi dt86
even at idle, it goes from 0 to 300 rpm in a blink of an eye, so all the tension is directly on the transmission or pto shaft. isn't there a way to build it up like with a clutch? or is it normal with the electric switch for the pto in Kioti?
/ Kioit Rx Pto shaft breaks #4
That is normal with all electric switches which is Pizz Poor design but everyone is doing it. All you can do is keep your engine speed as low as possible without stalling. Your tractor should idle at 900 rpm and that shouldnt be 3/5th of your PTO speed. Pull the throttle back as far as it will go and engage the pto. If the engine stalls increase the RPM by 100 and try again. I dont think there is anything else you can do other than swap for a tractor with a clutch operated PTO.
/ Kioit Rx Pto shaft breaks #5
What about some kind of overrun clutch like guys use on the 8N and 9N tractors? Wouldn't that provide some kind of cushion until the implement got up to speed?
Ok, thanks for the help.
I will first fix the transmission and put a heavy duty pto shaft, and hope it doesn't happen again. I will look if i can go as low as possible on idle, maybe adjust the throttle a bit. Somethings old things are better......
/ Kioit Rx Pto shaft breaks #7
What is the hp rating for your mower? Perhaps the 60 hp RX is too much for it and adding a stronger driveline will damage other components.
/ Kioit Rx Pto shaft breaks #8
What about a slip clutch drive shaft might allow some of the shock load to be absorbed in the clutch packs in terms of slipping rather than the other components
Dave
/ Kioit Rx Pto shaft breaks #9
I'm not familar with your mower or tractor , but something ain't right . Flail mower , rotary with two big hinged blades , new , used ,how big ? It should stall tractor before it breaks anything . Just trying to help .
/ Kioit Rx Pto shaft breaks #10
The mower should have a slip clutch at the input shaft. Propperly adjusted, it should absob the shock load momentarily before anything breaks.
/ Kioit Rx Pto shaft breaks #11
:welcome:
/ Kioit Rx Pto shaft breaks #12
That wouldnt help any as it slips in the opposite direction allowing the equipment to remain turning when the PTO stops. Its like a ratchet set on tighten in the direction that the PTO turns.
/ Kioit Rx Pto shaft breaks #13
I'm not sure about that the way its being described engaging it sounds like its basically performing the equivalent of a clutch dump instead in a in a truck where you just dump the clutch and hope for the best instead of a modulated clutch release. This mower probably has a fair amount of rotating mass. Its basically like taking a medium duty truck loading it up to its GVWR and dumping the clutch with descent RPMs on the motor. i've seen everything from twisted Prop shafts, Transmission that have ripped the mounting bosses out of them and differentials spun around the axle shafts 15-20 degrees. normally these trucks have no problem hauling around a heavy load but do something they really were not intended to do and stuff breaks.
Kiotirx What are you using for a Shear Bolt, stainless steel or a grade 8 bolt? I would definitely put a slip clutch on it if Kioti has no way to adjust the modulation of the clutch. Normally the shear pins should give way before the gearbox although under these circumstances maybe not
/ Kioit Rx Pto shaft breaks #14
Engage it at a idle or as low of a rpm you can with without stalling the motor.
You should also check the length of the PTO shaft to be sure it is not too long and to be sure it is not too short.
many thanks for all the answers.
I have checked the way it engages the pto and that electric-hydraulic. The electric switch engages a hydraulic pump and the oil forces the pto clutch to grab into the engine.
A mecanic told me that you can lower the speed of the hydraulic oil so it will go slower to work. anybody experience with that?
Also can you simply slower the idle rpm or is it electronic?
thanks
thanks
/ Kioit Rx Pto shaft breaks #17
thanks
I have no experience with it, but my friends Case 110 must have a similar system, it brings the PTO up slowly. I do what others have suggested, I only engage the PTO at an idle and I've never had an issue with my snowblower. It does make the auto setting on the PTO a little useless, but this is the reason I've never been comfortable enough to use it in the auto setting (other in the summer testing it out a couple times).
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
429860 (A61166)
429860 (A61166)
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
