snow pusher size
/ snow pusher size #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
I've got a 3000# tractor. It uses a 6' rear blade quite well. I'd like to find a snow pusher for the 3 pt hitch but because these gather and retain more snow weight, I am at a loss as to get a 6' or be safer with a 5' and I do not know if they make a pusher for the 3 pt. Looked on line but can't find any.
/ snow pusher size #2
How about adapt wings to gather?
/ snow pusher size #3
If you have the ability (or a buddy does) why don't you fab up some simple end plates for your rear blade and see how that does? I've not used a "pusher box" but it would seem to me that before long, you would run out of room to put the snow if it were not on a loader type set up. Your blade should lift to a decent height compared to a "close in" 3pt mounted box. I've never seen a 3pt model myself.
/ snow pusher size #4
Arrow, my std rear blade swings 360^ and the box blade works great in both directions, esp good for pulling drifts away from buildings, doors, etc and packing a bit to be scooped & dumped. Having abandoned both of them for snow handling years ago for the ease of doing 99% with the FEL (crick in my neck, too..) may I ask how different snowfall is in RI than here in MI that a rear blade appeals at all? btw: My Ford 4WD is ~3k# too, and wears turf tires with no chains ever needed. Anyway, I suspect more than a foot or two wider than your wheel track could hamper maneuverability. (ask me how I know...)
/ snow pusher size
Rusty I do have a fel and use this to "pile up"
/ snow pusher size
Actually OG I would reckon the snow here looks about the same as yours there. Its what it gets removed from that may be different. I have a stem landing field thats 70x140' that when the blade is straight, is much more efficient than attempting to take out a small bite of the increasingly large windrows the rb makes. Thought if I had something that held more snow, I'd increase the efficiency of this operation. I've done quite well with the combo of rear blade and fel all these years and actually go forward with the rear blade as much as I do going backward. I seem to be able to not tolerate inefficiency as much as i used to and looking to shorten the work load.
/ snow pusher size
Well now I'm curious why you don't put one out front and save your neck?:confused3:
I do not have a quick hitch attachment and have bucket tines bolted to the bucket to lift tree stems to the pile. As I skid trees in winter, I do not have the patience to keep unbolting,rebolting or pinning and lining up holes and re pinning. A 3 pt just makes this exchange easier. My body doesn't seem to mind being twisted around and actually makes my back feel better for some reason.
/ snow pusher size #10
I use an 8' containment plow on the fel of my tractor and it does quite well.
/ snow pusher size
Your post gives me an idea HC. I think I need to invent a new front end attachment for how I use mine. The bucket other than being a platform for mounting tooth bars and such is probably the least used implement I have. I need to invent a snow plow blade that has tines to lift and pile stems and that you can quickly pin containment sides to when it snows. I may as well think about how to mount a set of forks to the thing too. (actually that's the easy part)
/ snow pusher size #12
I have a 8' heavy duty snow pusher for the front of my tractor and it pushes good. I will extend the front wings to 4' in the summer. My guess is you would have no problem with a 6'+. Could you adapt the unit to attach to the tines. We built snow pushers that attached to forks for all of our loaders when I worked for a trucking company. Slide it on throw a chain on it and you were good to go. CJ
/ snow pusher size
Now there's an idea. Would any pictures of these fork pushers be around? I started a new post in "attachments". It shows a picture of what I have already.
/ snow pusher size #14
Isnt your FEL just like a 5' box, only that it is on the front.
Personally, I never liked driving over the snow I need to plow. And there isnt much traction in reverse as well as the 3PH isnt really designed for it. So I would come up with something for the FEL if possible.
/ snow pusher size
It would be if it did not have a top or I should say the sides extended beyond the top so as to allow more snow to be upwardly contained. Also more than the 5' wide would be nice. Gives me another idea however.
/ snow pusher size #16
No pics, that was a long time ago. But 2 pieces of pipe that fit over the fork cut the same length as the fork was what we did. Welded it to the pusher with a few support gussets and 1 cross pipe and we were good. Slide the forks into the pipe and chain it on. Took about 2 min. tops. CJ
/ snow pusher size #17
Three points are designed to pull not push;can get real expensive real fast.
/ snow pusher size #18
would caution use of direct plow blade attached to FEL arms/bucket. without some sort of "trip" (spring on plow, so if it hits something, the spring allows plow blade to fold back, instead of twisting FEL arms)
prefer something that i can actually change angle. much like a 3pt hitch rear blade. or blades found on many regular pickup trucks. so as ya going down the driveway/road the snow goes off to one side. a static blade, that is perpendicular to travel. will require a ton amount of forward / reverse to clear things out in front of you.
below picture possibly some ideas.
/ snow pusher size
That is so kool Ryan the way you can draw over. What program allows you 2do that? Thanks so much for your insights. Much to ponder. The V and angle cannot be considered as I am trying to remove snow from expansed areas as opposed to "lane" type removal. I like your modular concept for the bucket. I was thinking I need something like a manure tine bucket that I could add gathering sides to. I could leave this on all season and when I'm skidding, take off the sides. Can't figure how to keep the tines onto the attachment. The tines (I'd only need a couple of three) would be used to pick up stems so they need to be exceedingly strong. I'm moving in the direction of the pin attachment so as to keep my lift closer to the pins increasing lift capacity.
/ snow pusher size #20
your other thread.... regarding same thing.
http://www.tractorbynet.com/forums/attachments/267822-inventing-new-attachment.html
just paint that comes with every microsoft windows computer, mac computers have like program. trying to draw lines that show 3D is a tad tricky. actually think the lines look like scribble. but glad they helped get idea across.
as far as "expanded areas" such as a parking lot, or like type of thing. and wanting manure tines left on.... and sides that can be taken on /off
mindless ramblings....
might be possible, with a pipe hinge, and piece of rebar. but problem would be the angle brackets that go from outside edge of the extensions and angle back to rear end of bucket. you would almost need to make a custom fit brackets, with sheet metal over them. in order to allow for it... na... way to complicated and frustrating...
EDIT>>>> look at link mangus580 post in your other thread. more spicfically, look at toomanyGT avator icon, showing a grappel or rock bucket. remove the upper grappel teeth. and think about how you could add sheet metal to the rock bucket, with pins. so you could have tines at one time, then add some sheet metal insert some pins, and have a heavy duty generic bucket.
more mindless ramblings....
how about just buying a second heavy duty bucket, cutting the bucket it half. and add each half onto bucket you already have. that might work out better for structure wise. the only issue, is the sheet metal sides of your current bucket, could get pretty badly dented and bent up, causing problems to remove the current manure tines you have now. perhaps taking some L shape angle iron, and welding it directly onto edges of the sides of bucket. to beef up things. but what about outside edge forces of the extensions... you just can put the bucket you cut in half. and just bolt sides of each half to sides of main bucket. that would most likely rip things apart for sure. you would also need to beef up the side of bucket that is facing forward....
EDIT>>> buy another heavy duty bucket, and splitting it in half. then adding some metal for reinforcements on current bucket, and each half of other bucket. and some how bolting or pinning them together might work out nicely. to restate it again, you will most likely need to reinforce the sides of current bucket pretty good. more so the front edge of the sides.
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
