Looking for Input RE: Deere Sub Compact with Yanmar Engine
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #1
pwhondaman
Newhall, IA
John Deere 4020
I'm considering purchasing a Deere sub compact, somewhere in the 30-35 hp range and wondering if anyone has any input on the Yanmar engines Deere uses for these smaller tractors?
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #2
I looked at small tractors in the early 80's. Deere was made by Yanmar then as it is now. Had I bought at the time I had settled on Yanmar. I'm sure if there was a problem you could read about it here.
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #3
The Yanmar powered Deeres are nice machines. Some of the newer ones are a Deere machine with a Yanmar engine and some of the older ones are Yanmars built for Deere under contract. I don't think you'd go wrong with almost any.model.
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #4
:welcome:
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #5
The 3X20 series are Yanmar powered and have been very good machines. I've had a 3720 cab tractor bought new in 2007 and it's been very reliable and trouble free. You can do a search on 3320, 3520, and 3720 and do a lot of reading here on this forum. The center of gravity on the 3X20 tractors has been topic of many discussions but there are remedies if this is a concern.
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #6
I have a JD4110 with a Yanmar engine. (2004) The only complaint I have is once every two or three months I have to add a gallon or two of diesel. :)
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #7
I used to own a JD870 (1996 build) and had it for 14 years. This was a Yanmar built...but JD branded tractor. Loved it. The only issue i ever had was a broken front end drive gear....apparently this model was known for that issue).
Id have never sold it...but i needed a cab.and more power. 28 HP just didn't go far enough
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #8
I have a very low hour 1989 1070. It is a Yanmar built machine and it's a tank. Wouldn't hesitate one bit picking one up.
Sent from my iPad using TractorByNet
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #9
I like my Yanmar 870. Low hours though with about 500 hours in 13 years. Lots of hours the first year or two. A few fuel filters and a battery has been the only maintenance besides oil changes.
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #10
Yanmar is a top name in small diesel engines, they are used extensively in tractors, generators, construction equipment, and the marine industry.
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #11
Have you considered the Yanmar brand of tractors? Maybe a cheaper alternative to the expensive green paint? Any thoughts from the others?
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #12
I've had a 1995 jd855 since new with a 1 litre yanmar. never had a problem except as above-having to add fiesel every so often. even tho mine has low hours, i think it's a great motor and don't hesitate to recommend yanmar!
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #13
Have had my 455 Yanmar now since 1999, 2500 hrs +. Only problem was sticking fuel solonoid which I solved by coating it with olive oil. I use Mobil 1 fully sythectic Turbo Diesel 5-40 oil. Oil light came on once (1,000 hrs ago) when I was mowing on steep hill but I believe since I was using fully synthetic oil the engine has been fine.
JPC
/ Looking for Input RE: Deere Sub Compact with Yanmar Engine #14
:rotfl:
This is all very reassuring, hope my little 3120 proves as reliable.
2018 VOLVO VNL670 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2018 VOLVO VNL670...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
UNUSED WOLVERINE TDB-11-72W 72" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
