Box Scraper hauling logs
/ hauling logs #101
I have owned a MUTS Trailer from Canada for two years. I have winched many tree trunks into it. I have hauled a lot of dirt. MUTS has held up well.
The mast and winch combination is effective.
Both "ends" of trailer remove easily.
I wish I had purchased MUTS prior to doing $15,000 damage to left knee working without good equipment.
http://www.muts.com.ca
/ hauling logs #102
Thats a pretty good unit you have there jeff. It matches your 4 wheeler well.
I was hoping to see how gaproperty gets 3/4 cord on his trailer.
/ hauling logs #103
Beautiful day in north-central Florida today. I was out chipping and took some fresh photos. How is the weather in the Granite State?
ONE of the things I like about digital photography is how it makes frequently used, grimy equipment look clean.
/ hauling logs #104
Sharp looking unit,like the way inside shape.
/ hauling logs #105
Yes. Weight in trailer is carried low and with the low pressure tires (max 15 PSI ) the MUTS will follow the RTV500 anywhere. Seldom need 4WD and have only locked the differential 3-4 times in two years of regular use. Combination must have some goat DNA.
How is the weather in New Hampshire?
/ hauling logs #106
/ hauling logs #107
Winter is the second best time of year to be in the woods, the first is obviously hunting season! :)
/ hauling logs #108
Gordon,
You have some of the nicest pictures! I remember one that you took that was also a winter scene, it was similar to your second pic you just posted, and showed the snow sticking to the branches and the tractor with some logs behind it I believe. It was very picturesque. :thumbsup:
/ hauling logs #109
Gordon,
Thanks, I am glad you enjoy them. The north country is a pretty place and I enjoy showing it off. You probably mean this one from a couple years back. It is one of my favorites.
/ hauling logs #110
Ahhh... you need some wind to get the snow off the branches.. the back of my neck is cringing just thinking about it..:)
Sean
/ hauling logs #111
Sean
What you need is a hard hat liner like this. No more snow down the back of your neck.
Happy New Year everyone.
/ hauling logs #112
So that would make you the Sheik of Vermont, right?? Some nice deer hides there, nice mount too!
Sean
/ hauling logs #114
Better you than me. I have enough problems with one woman, and she likes me! Now, the oil well idea has potential..
Sean
/ hauling logs #115
No oil wells in Vermont.
But they produce syrup, lots of it.
The Sultan of Syrup?
Really ... when I saw that head gear on the broom my first thought was if I were a crow I wouldn't go anywhere near a field with that dude standing in it.
And Piston is right, you take some great pictures in your woods, Gordon. I think it's your combination of light, beautiful land and skillful composition.
/ hauling logs #116
That's the one!
I even had that as my background for a while.
/ hauling logs #117
I have been thinking about a trailer. Sounds like a good way to go. What kind of set-up do you have that allows you to winch the logs onto the trailer. A picture maybe. Do you stage up the logs in the woods first then go get the trailer. Seems like the trailer would be in the way while you were cutting and repositioning for the initial winch out of the woods and onto the trail unless you can fill the trailer from one spot.
http://youtu.be/WdqrJeZqYa8
I have modified my trailer. Removed side boards and middle stake. . So I lift the logs on using my logging winch. There is a steel arch that the hydraulic cylinder was attached to work the dump. I chain a pulley to the top of this arch, run the winch cable through. I use the logging winch to hoist the logs up onto the trailer.
As for staging the logs.. Sometimes I do and sometimes i just winch the tree trailer side cut it up 8 feet and winch them on. The trailer is licensed for the road so I disconnect from tractor and connect it to the truck and haul it home.
I have a boom that will swing out over side. Just never attached it to the trailer yet.
/ hauling logs #118
As for trailer being in the way I park the tractor on a bit of an angle the cable runs along side trailer. Sometimes I run the cable through the pulley and winch from there. Not much tipping after the trailer has 500 pounds of logs on.
Ps. I upgraded my tractor to a L4740 kubota.
/ hauling logs #120
Lift with the 3pt, but pull with the drawbar.
2023 Case TV380 (A62177)
2023 Case TV380...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
3PC. GALVANIZED HAY RING W/ (1) EXTRA PIECE (A62130)
3PC. GALVANIZED...
2016 Ford F-350 4x4 Cab and Chassis Truck (A61568)
2016 Ford F-350...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
John Deere 2155 (A62177)
John Deere 2155...
