Do most older tractors leak?
/ Do most older tractors leak? #21
saying a tractor should not have a leak is like saying the economy should not be bad right now.. people shouldn't murder and steal, and interest should be higger that .02%.
should and 'are' are on different sides of a fence. ;)
it's common for a tractor to leak.. it's expected for an older one to leak.
when I see an old tractor without a leak.. I check the oil before starting to make sure it isn't empty!
/ Do most older tractors leak? #22
I am saying it should not have a leak (puddle of oil underneath) but most tractors if they have been ran any will have a seepage (a residue of oil on the block).
BTW my 8N did not leak and the economy should not be bad.
/ Do most older tractors leak? #23
It's normal to have a few small leaks on old tractors. I try to fix all my leaks though as I find them. Under all our equipment the floor is dry including the older equipment I use to have. Like i said I fix the leaks as I find them if they are easy fixes. Most of the times it's a simple hose clamp that needs tightned or so on.
/ Do most older tractors leak? #24
Thanks for the chuckle. My 56 Harley has a small leak.[ chain oiler].
/ Do most older tractors leak? #25
it's like when hyd line blows and coats everything in a 15' radius with hydro oil.. I don't get bent out of shape.. that's just rust proofing.. :)
/ Do most older tractors leak? #26
Like Rusty Jones? If a Hydro leak is lubing the hardware should I pour a pint of PB blaster in the oil?
/ Do most older tractors leak? #27
I have a leak on my tractor that loses a bit less than a tablespoon a day, just leave a small dish under it. Just much easier add a bit every few months than to pull tire, axle and trumpet to replace a gasket. Keeps me honest and checking the hydro oil every week or so.
/ Do most older tractors leak? #28
And it gets a total change every 3 months.
/ Do most older tractors leak? #30
His tractor only holds 5.625 cups of hydro oil?
Only you would do the math when everyone is just kidding. Oh Well, Happy New Year.
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2017 Nissan Juke SUV (A61574)
2017 Nissan Juke...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
UNVERFERTH 14' FIELD CULTIVATOR (A63291)
UNVERFERTH 14'...
