Do most older tractors leak?
/ Do most older tractors leak? #1
sirrobinhood
Bronze Member
Bolingbrook,IL
Kioti DK55
Hello all,
Ive been looking at some older tractors..like massey and JD. I dont think I ever saw one that didnt leak!
Anyway, should I be concerned with a slight leak..between trans and engine..I think rear seal?
Tractor sat inside on a concrete floor for a few days and had about a golf ball size oil spot on the floor.
This was on a massey 231
/ Do most older tractors leak? #2
Maybe the owner also had a Harley and just thought it was normal and never fixed it.
:confused3:
Howdy from Michigan
/ Do most older tractors leak? #3
Don't tractors and oil leaks go hand and hand. I have yet to see one other than brand new that didn't leak.
/ Do most older tractors leak? #5
That is kind of like asking if dogs bark. Some don't, some will a little and some never stop. :)
/ Do most older tractors leak? #6
If it stops leaking,....you better check the oil.
/ Do most older tractors leak? #7
And if it stops leaking, it usually stops going-soon after.......
The leaks on Old Tractors is a form of automatic controlled underbody lubrication - stops everything from rusting & seizing up.......
/ Do most older tractors leak? #8
I would say most old tractors deserve a leak here and there .
As long as it isn't running out while running it is probably ok.
Having to add a little oil is not a sign the motor will fail soon.
there are some additives for engines to soften old seals.
Compression test, clutch& pressure plate condition, hydraulic pressure would be more of a bigger worry to me than a small oil leak.
Spitting a tractor in half for a new clutch is an expensive repair.
Adding a little oil every month is not.
Just my opinion.
/ Do most older tractors leak? #9
Some of those old cast iron engine weren't mill like todays engines,some case double gasket we needed.
Oil spots..tractor just marking its spot. :)
/ Do most older tractors leak? #10
It really depends on the owner from what I've seen. They can be fixed but often enough it is cheaper to add a quart of oil.
/ Do most older tractors leak? #11
It is obvious that you arent using it enough to keep the proper amount of oil 'sorb (dust) on the tractor. And by the way a 2002 is not OLD, heck it isnt even grown till at least 18 and 5000 hours or so. Most of the old farm tractors were used heavily spring and fall for 2-3 month and likely averaged 12 hours or more per day so it wasnt unusual to put over 1000 hours per year on one for the first 5 years or so, then they were usually replaced and or put out to pasture for a more gentle life. The engines were built to overhaul easily back then and parts were heavily constructed so you rarely saw a broken axle etc like on the CUT tractors today.
Machining of surfaces likely werent at the tolerances of todays equipment and relied on thick cork gaskets to seal. Cork is wood and over time will dry out and no long seal like many of the synthetic rubber type gaskets of today so I would say that all old tractors that havent been rebuilt recently will leak a bit of oil. If it is leaking like an old Harley then you may have to spring for a new gasket along with some mechanic work to install it.
/ Do most older tractors leak? #12
Seems to me most of the replies have been both an accurate and realistic summary of old tractors in general. If the leaks are bad enough you will wan't to address them. I have a few damp spots on my 820 but nothing I am going to worry about right now. This is a 40 year old tractor so I expect to see this. My injector pump is the next thing to fix as it leaks a little while sitting, more like a few drops a day. The 110tlb and 4520 have no leaks that I can see and with 1000 hours on the backhoe thats not bad.
/ Do most older tractors leak? #13
He'll my "NEW" tractor leaked from the time it was dropped off the truck ! Now the dealer is picking it up !
/ Do most older tractors leak? #14
It's just a fact of life. Old tractors leak. Like Gary and others said, tolerances, cork instead of rubber, etc...
Were they designed to leak? Obviously not, but nobody told the tractors that!
Old tractors are a far cry from today's tractors. The whole engine could be rebuilt by most owners. Worn cylinders? You just replaced the sleeves and rings. Lift wont hold? Turn to Group III in your Massey manual, and get to work....But on the other side of that coin, things didn't always get torqued to spec with the correct tightening sequence, old gaskets were reused in lieu of new ones, etc... things like that.
Unless it's pourin' keep it roarin'.....that's how it was put to me!
/ Do most older tractors leak? #16
some leaks are virtually 'normal' or at least expected.
leaks at cluth to eng would be rear main or inut shaft seal..e tc..
/ Do most older tractors leak? #17
I would say my 67 MF 135 does not leak but I don't want to cause a gusher.
/ Do most older tractors leak? #18
Don't think of it as leak. Think of it as sweating horse power.
/ Do most older tractors leak? #19
built in rust preventer!
/ Do most older tractors leak? #20
A tractor should not have a leak. A little seepage is alright and common. You are not going to get away from having a little oily residue here or there on a old tractor.
