Do most older tractors leak?
/ Do most older tractors leak? #21
saying a tractor should not have a leak is like saying the economy should not be bad right now.. people shouldn't murder and steal, and interest should be higger that .02%.
should and 'are' are on different sides of a fence. ;)
it's common for a tractor to leak.. it's expected for an older one to leak.
when I see an old tractor without a leak.. I check the oil before starting to make sure it isn't empty!
/ Do most older tractors leak? #22
I am saying it should not have a leak (puddle of oil underneath) but most tractors if they have been ran any will have a seepage (a residue of oil on the block).
BTW my 8N did not leak and the economy should not be bad.
/ Do most older tractors leak? #23
It's normal to have a few small leaks on old tractors. I try to fix all my leaks though as I find them. Under all our equipment the floor is dry including the older equipment I use to have. Like i said I fix the leaks as I find them if they are easy fixes. Most of the times it's a simple hose clamp that needs tightned or so on.
/ Do most older tractors leak? #24
Thanks for the chuckle. My 56 Harley has a small leak.[ chain oiler].
/ Do most older tractors leak? #25
it's like when hyd line blows and coats everything in a 15' radius with hydro oil.. I don't get bent out of shape.. that's just rust proofing.. :)
/ Do most older tractors leak? #26
Like Rusty Jones? If a Hydro leak is lubing the hardware should I pour a pint of PB blaster in the oil?
/ Do most older tractors leak? #27
I have a leak on my tractor that loses a bit less than a tablespoon a day, just leave a small dish under it. Just much easier add a bit every few months than to pull tire, axle and trumpet to replace a gasket. Keeps me honest and checking the hydro oil every week or so.
/ Do most older tractors leak? #28
And it gets a total change every 3 months.
/ Do most older tractors leak? #30
His tractor only holds 5.625 cups of hydro oil?
Only you would do the math when everyone is just kidding. Oh Well, Happy New Year.
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
7888SFL (A61567)
7888SFL (A61567)
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
