Welded grab hooks
/ Welded grab hooks #1
Bday
Lucerne, IN
53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
Finished welding the hooks on the loader yesterday. Had to add channel to mount hooks on. Dual loader uses a pipe at top of bucket. I think they'll hold.
/ Welded grab hooks #2
Looks pretty darn good to me; wish I had done ours like that.
/ Welded grab hooks #3
Be careful when you use those hooks placed outside of the loader's arms. A heavy load will make the tractor quite tippy even with good ballast.
/ Welded grab hooks #4
The welds on the hooks look really good!:thumbsup:
But in the second picture I would put a little more fill in that crater at the heel of the C-channel.;)
/ Welded grab hooks
Seemed like the best place to put them. The bucket design is different to what I have normally seen with the pipe at the top. I was going to use angle iron, but didn't have anything heavy enough.
/ Welded grab hooks
I need to wrap the corners going down toward the bottom of the bucket. I hit some paint at the finish of that bead had to grind out some pin holes. Will tie it altogether on the weld on the short corner of the channel.
/ Welded grab hooks #7
What kind of equipment are you using? Machine brand, model, wire, and gas?
/ Welded grab hooks
A spatter shoot'n Hobart Beta mig 250. I picked it up with my student discount when I graduated from Hobart Welding school. It runs well, but the arc is unstable in the upper settings produces alought of spatter. It's 90's technology!
Running Hobart .035 with 75/25. I've been real happy with Hobart's solid welding wire. I welded some rusty material last summer with a Weldstar brand wire. Went back to Hobart what a difference. The weldstar was American made. Hated to go back to chinese stuff, but what a difference!
/ Welded grab hooks #9
In the second picture the weld on the right all most looks like the wire speed could be turned up a bit. Or maybe your hand was in a bind working towards the corner.
When Mig welding I have a personal policy of running as hot as I can handle it. Out of the hundreds of welding tests I've taken, one of the very few I failed was a vertical up with Mig. It was beautiful! But when the coupons were bent, (side bend) it had too many flaws to pass code. I ran it too cold.
These pictures are of Lincoln's L-56 wire with C25 gas, and a 46-year old CC engine drive.
/ Welded grab hooks
Looks almost like a spray transfer. I think we used straight argon and cranked the welder up. Made some pretty beads!
/ Welded grab hooks #11
No, like I said. I like to run hot!:D
Here is some spray I did with .035 L-56 wire, 90/10 gas, and my Lincoln V350-Pro.
/ Welded grab hooks #14
It's only metal, you still can.
I like that attitude!:thumbsup: When working with metal it is so easy to change if you so desire. It's that God awful wood that's so hard to work with if you change your mind. :laughing:
/ Welded grab hooks #15
Cool! That was going to be my next project. Now I'll have the input of a lot of people much smarter than I. (I'm still better-looking).
My plan is to weld the hooks to some 3/16" or 1/4" angle iron - several inches long - and weld the hook-angle assemblies to the bucket. I figure that the welds will hold better if they're several inches long than if I were to weld the hooks directly to the bucket.
I'm new to wire feed welding. What diameter flux-core wire should I use? I have .030.
/ Welded grab hooks #17
Well they look great. I'm a rookie with a Millermatic 180. sometimes I say "not bad" and then I have my share of Chicken s--t. What heat/speed settings would you be using on those hooks??-very typical application-
By the way, on the subject of bucket hooks, I'm a fan of one in the middle. When I bought my first CUT (755 Deere) took my bucket to local welder. Great old boy WWII SeaBee and then worked as a factory guy for Koehring-traveling the world trouble shooting (Koehring made big cable shovels, cranes and then got into hydraulic machines before they disappered). In any case, I bought two weld ons with me, he shook his head and said.."one in the middle, never have to worry then about a lopsided hook up".
/ Welded grab hooks #18
I have 3 hooks on my bucket, but I try to never use the ones on the sides for loads. I just use them to carry the slack in the chain 99.9 % of the time.
Here is a very good calculator, you should book mark it.
Miller - MIG Welding Calculator
/ Welded grab hooks #19
thx-good use for those outside hooks-and thx for the guide.
/ Welded grab hooks #20
Our 210 has a nice chart when you flip up side panel to change out wire spools, will give you a good general idea, common sense from there.
2022 EZ-GO ELITE...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2021 Dodge Durango SUV (A61574)
2021 Dodge Durango...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
UNUSED WOLVERINE LAND LEVELER (A64281)
UNUSED WOLVERINE...
