Headlights not working on JD 2210
/ Headlights not working on JD 2210 #1
Icf
Campbellville, Ontario
John Deere 2210
Always worked fine and last night I went to plow snow and they don't come on. 4 ways still work fine. Thinking it is not bulbs since there are two and unlikely they died in unison? What should I do to diagnose ?
/ Headlights not working on JD 2210 #3
Blown fuse, bad switch, or a bad relay would be the three main culprits. I would check the fuse first.
If it is the fuse, I would check for other wiring issues. Fuses don't pop for no reason usually.
/ Headlights not working on JD 2210 #4
I agree with the others. Your Operator's Manual should show you where the fuses are located, and which fuse goes with a specific function. If it is a blown fuse, always replace with one of the same capacity indicated in your Operator's manual.
Thanks for the replies. I will check fuses and report back
I found a blown 20amp fuse and replaced it. The fuse box is a lame little plastic box with no protection from the elements so I have given it a wrap in electrical tape to keep it sealed. Maybe it was water that caused the blown fuse. For now I will wait and see if the fuse blows again. Thanks for the tip. I enjoy DIY work on my tractor but I am not super technical. Now I know where to come for help!
78in. Skid Steer Bucket w/ Blade (A65640)
78in. Skid Steer...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
