leaky tranny cooler lines
/ leaky tranny cooler lines #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
My tranny cooler lines still leak!
So my truck is stock '01 Dodge Ram2500 4x4, Cummins with an auto. The tranny cooler lines are hard piped(1/2" tube) from the transmission up to the front of the truck, just under the crankshaft damper/pulley. Then, there are quick disconnects, that go in to rubber hose. Those continue to the secondary cooler in front of the radiator. At the actual cooler, the hose slip on to hard pipe(1/2") and are held by hose clamps.
I had a leak at the quick disconnects. It had been happening for a while, but actually got bad this last week; it went from a little drip now and then to really leaking. So, I bought new ones, and new hose to go from the QC fitting to the actual cooler.
It still leaks at the quick disconnects... Just as bad as before.
The hard line from the tranny has a ridge about 1/4" from the end, that the quick disconnect "snaps" on to. I'm wondering if the actual hard pipe is worn too, and may be causing the leak...?
I do not see why I could not just ditch the quick disconnects, and use hose clamps to hold the rubber hosing directly to the hardline? After all, that is how it is attached to the actual cooler....
Anyone else dealt with this?
/ leaky tranny cooler lines #3
We have a 1999 Dodge about the same as yours. We just replaced the couplers with hose by cutting the end from the transmission lines. When we had the transmission rebuilt due to the hard lines rusting thru the transmission shop said they do the same. Rick
/ leaky tranny cooler lines #4
This is a major issue with GM trucks with the allison tranny. What guys do to fix it once and for all is cut off the hard line square and either use compression fittings or braze on fittings then go to hydraulic hoses. Its the only way to fix it right and how it should have been done from the factory.
Chris
Chris, what kind of compression fittings?
The hard line "looks" like it is in good condition at the ends. The "ridge" about 1/4" from the end "looks" good. It must be worn though from flexing and etc, at least enough for the QC not to seal.
I really don't want the rubber hose to come off while I'm 100's of miles from home, out pulling the 5th wheel, or while I am out in the boonies hunting.
/ leaky tranny cooler lines #7
Not familiar, but why cant you cut it and use rubber trans cooler line? Is that line to small or something, you could always use hydraulic lines hose clamped on right?
As far as compression fittings hes talking an end like you would have on a brake line on one side and then a fitting and the ring that tightens onto it to seal it while you tighten it to a hydro line that you put in there. I know this makes no sense the way i described it but if you know what compression fittings are for anythining that you kind of have an idea.
/ leaky tranny cooler lines #9
different chris.. but.. :)
they make a compression fitting for hy applications. I made up some comp to orb fittings for a tractor pow steer pump.. then unioned to hardline on tractor via comp fittings on hose.. the orb went into pump.
saved alot of work on new pre bent hardlines..
After checking a couple local parts stores for compression and barb fittings, I went to a parts place that does everything from car stuff, to big rigs and tractors.
I had them make up a set of hoses with a compression fitting at one end.
I've run it in the driveway, topped off with fluid, and run thru the gears; no leaks. DSCN1386.jpgDSCN1387.jpg
/ leaky tranny cooler lines #11
looks good.
I think my stuff was parker too. would have to check tho...
buddy of mine made em for me. sure did save some work / time
/ leaky tranny cooler lines #12
This is a major issue with GM trucks with the allison tranny. What guys do to fix it once and for all is cut off the hard line square and either use compression fittings or braze on fittings then go to hydraulic hoses. Its the only way to fix it right and how it should have been done from the factory. Chris
Still doing high-school Ford Chevy arguments are we?
/ leaky tranny cooler lines #14
Didn't you know? GM tranny's explode after 100 miles??? Lol.... Seriously, I never knew any of my Silverado's SHOULD be having all these problems.
I don't visit this site as much as I used to. I got tired of hearing what a piece of junk I drive.
/ leaky tranny cooler lines #15
Fact, GM tranny lines leak like a siv....
Chris
I'm not sure that siv is the term I would use, but yes they do leak on occasion. I was in charge of a fleet with 40+ 2004-2006 Chevy and GMC 2500's with 4L80E transmissions and we had to fix some tranny lines. My 2001 GMC 3500 w/Allison never leaked in the 10 yrs and over 200k miles I had it.
/ leaky tranny cooler lines #16
Kind of like our Suburban with the AFM is supposed to use a quart of oil every 50 miles. I just checked it this past weekend (I normally don't because it never has used any, so why bother, used more oil wiping it off the dipstick) because I was just curious and checked since it SHOULD be doing it. Nope, with the OLM down to 30% left, it is right on the full mark where it was when I changed it. I have no idea on the mileage as I just go by the OLM, but I know it has had a few trips to the Cleveland Clinic in where I ran it 75+ there and back and a few hundred miles pulling the stock trailer or the flat trailer and then the rest being normal trips by my wife to town and such.
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
