transporting concrete off road
/ transporting concrete off road #1
jbarker855
Collins, NY
John Deere 855
Hello all-
I am in the early stages of planning on building a pole barn, and just getting some of the logistics sorted out. It will have to have a concrete floor. Barn size will be about 30 x 80, with a 10 foot wide porch down the long axis of the building. Probably looking on the order of 40 yards of concrete. Where I live, my driveway that leads to the build site crosses a narrow bridge. It is 8 feet wide and spans 90 feet. It is an old flatbed train car. It is iffy if it could support a cement truck. Even if is was strong enough, the lay of the land dictates rather sharp turns before and after the bridge so that a longer vehicle like a full size cement truck would not be able to get a straight enough shot to get on the bridge. Just to give a better idea, UPS trucks cross no problem. I have had 35,000 pounds (full size loaded moving truck) on the bridge, so I know it can support that much.
I live in a valley, and vehicles besides an ATV or bulldozer would not be able to get through the steep terrain any other way than the driveway which crosses bridge.
I have thought of 2 ways to get the concrete back. One is to use power buggies (Quick ride-on concrete buggy and material mover - The Power Buggy). They have a capacity of about 3/4 yard, so this would mean about 50 trips across bridge. Bridge is about 1/8 mile from build site. Another would be to get a loader (small enough to fit over bridge) with a big bucket to move the concrete. I will be hiring a concrete guy to do this, but I just wanted to have this thought out before talking to them.
Any thoughts? Better ideas? Helicopter transport?
Thanks!
-Jay
/ transporting concrete off road #2
Your concrete guy should have some ideas as well. That 1/8 mile is 660 feet. Check with the pumper truck guys to see if they can pump concrete that far. What it sounds like you really need is just a way to get the wet concrete across the bridge. How about an empty concrete truck, or dump truck, or ?? stationed on the far side and the concrete trucks coming in stay on the road side and off load via (a pumper, or ??) into the empty truck which then hauls it to the barn site. There are also trucks that arrive with the sand and gravel in separate hoppers and mix it on site. They're intended for small batches, but maybe light enough empty to cross the bridge. Have the sand and gravel stockpiled near the barn and load the truck there.
Let us know what you decide to do.
/ transporting concrete off road #3
Another option might be a concrete pump. 1/8 mile works to 660 feet. I dont know how much it would cost to rent a pump with 750ish feet of pipe, bit it can be done, they pump concrete up skyscrapers and they are a lot more than that straight up.
Aaron Z
/ transporting concrete off road #4
The pumping is a good idea but I would guess the front end loader bucket and/or power buggy would be the most economical options. 50 trips might sound like alot but really isn't that big of deal. Just try to stagger the delivery times of the concrete (2nd truck, etc.) so it isn't sitting on the truck too long before you can begin placing it.
/ transporting concrete off road #5
A line pump shouldn't have a problem getting the concrete to the site. Back in the day I did a job on a golf course using two pumps, one pumping to another. Its been so long ago that I don't remember the distance, but it was pretty dang far!
/ transporting concrete off road #6
A concrete company will start charging you extra if the truck takes more than ~20 mins to unload due to your slowness.
A concrete pump such as this one: Schwing / Stationary Pumps / SP 305 can pump 800 feet horizontally
Aaron Z
/ transporting concrete off road #7
Have you had your local town highway supervisor or DOT bridge inspect come out and "inspect" your personally owned bridge for a penny for his thoughts? I have no idea if they would do this kind of a service, but asking couldnt hurt. The worse they can do is say no and sorry. the best case is they let you know who you can contact or they might do it for your safety.
/ transporting concrete off road #8
Might not hurt to have the local FD take a look at it as well. They might not cross it in an emergency without having looked at it first...
Aaron Z
/ transporting concrete off road #9
I've used both and the buggy is the faster of the two. For a monolithic pour like you are wanting I would want to have two buggies going. The cost of the second one would be absorbed by the time charges. There is one caveat though, buggies suck on rough terrain. You can go faster than you can with a skid steer but they will also hang a ninety degree unexpectedly if they hit any bump just wrong. I'm talking a ninety that will throw you off the buggy if you are at speed. If the machine is still upright it will automatically stop and look back at you like the donkey you rode as a kid would do. Have the same snicker on its face too.
/ transporting concrete off road #10
Why not beef the bridge up and straighten the road.. just a little backhoe/dozer work and few old used (telephone poles) timbers,, Lou
/ transporting concrete off road #11
many good points here by others. question - can you post a pic of the said bridge and the footings underneath?
/ transporting concrete off road #12
Not to mention the case of beer it will cost you.:dance1:
/ transporting concrete off road #13
I had a similar problem - just about the same distance from where the truck had to stop and where we needed the concrete. We ran 2 mid-size bobcats to ferry the 9 yards of concrete from truck to the pour using dirt buckets. It worked great, but the two of us ran the machines wide open to get it done before it hardened.
Bridge is about 90 feet long, 8 feet wide. "Footings" are railroad ties on either shore that were put on the ground for it to lay on.
Here's some links to pics...
These pics aren't great, but gives a general idea.
No engineer would ever give a guess as to what it could support. WAY too much risk, way too many unknowns. This was recovered from a train crash in the 70's. The main beam underneath was damaged,/dented but obviously good enough to serve as a private bridge for the last 35 years. The car was originally rated to hold 135,000 pounds, but even if is was undamaged, it couldn't hold that now, because it is being supported only by the earth it sits on. It is being supported closer to its ends than it was meant to. I can see where the axles used to mount on it, and it is now being supported much closer to its ends than it was when it had wheels (so it is now spanning a longer unsupported distance).
/ transporting concrete off road #15
Your not too far from me, there are a lot of good options here but really, unless your finishing the concrete yourself then none of our ideas matter. You need to discuss this with your concrete guy. He may have his own idea to maximize his guys time there. You can mention some ideas but if he has his own buggies or other options that he prefers using then it won't much matter. Chances are if he has done any amount of concrete work he has ran into similar situations before. Good luck to you and hopefully you will post pics as this build progresses.
/ transporting concrete off road #16
I agree with Robert above, get with local concrete guys, (ones you plan on having do the job) as they could be way ahead on all your thinking in similar situation.
I agree most concrete and fire trucks wont pass over that bridge (driver risk) most wont take on. might be able to buy a BOND insurance for the process but without engineering plans I dont think you could do that either.
I'm sure in NY you can't get away with a temporary supports in the center sections or several either.
Pumping probably easiest way & cost may be better than you think. again consult with concrete guys preferably one with pumper & maybe one or two pumper companies in your area.
Mark
/ transporting concrete off road #17
Could you ask him to bring trucks with only half the load per truck or if he has some smaller capacity trucks? Cement trucks are designed for getting around construction sites and may be just as manourerable as a moving truck, so the weight may be your primary concern. As another poster said, a bit of work on the tractor may improve the turn too.
/ transporting concrete off road #18
Around here there is no delivery charge for 5 yards or more.
You might be able to order the concrete trucks with less than full loads and have them cross the bridge. ???
Two pumps back to back makes a lot of sense too.
Check with concrete finisher and concrete company for options.
/ transporting concrete off road #19
You could use one or more dump trailers. Mine will raise 12,000 pounds which is about 3 yards. You can rent them, and they're easy to pull with a tractor or good sized pickup.
/ transporting concrete off road #20
If your concrete plant has aluminum body trucks they weigh about 20,000, so it could haul 4 yards and be at 36,000 pounds, comparable to what you've already used.
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
