Operating loader without rear ballast
/ Operating loader without rear ballast #21
I didn't see mention of another loader-related reason for weighting the rear: If you are wanting to dig in with the bucket, your front wheels are often off the ground as you try to dig with a combination of curl and forward motion. Front wheels up puts max load on the bucket lip, which is usually good for digging and, with the fronts in the air, your forward motion depends on the traction from the rears (no matter you have 4wd) so you don't want the rears to spin too easily ...but, you do want them to break traction just before something else breaks, of course.
I think the issue about loading rears (via ballast and/or 3ph implement) has less to do with front bearings and more to do with efficiency and safety. Efficiency as per above, and safety having to do with having a rear wheel come up in the air as you try to lift that recalcitrant load slightly off center in the bucket. This will change your lateral stability and your pucker factor will zoom, especially in you are on a side-hill. This unequal lift is why many dealer willing to install a center bucket hook will advise against putting on hooks at each end which, if used singly rather than as a balanced pair, can be startling (ask me how I know ...now, my joystick hand is always pre-programmed to drop the bucket if...)
/ Operating loader without rear ballast #22
adding fluid to rear tires, or adding rear wheel weights. i do not see how could add more weight to front tires.
if anything front tires, would see total tractor weight (minus) not counting fluid in rear tires and/or rear wheel weights.
other words, tractor would still trying to do a front wheelie. but rear tires being held down, by fluid in rear tires and/or rear wheel weights. ok bad statement, fluid in rear tires, and/or rear wheel weight. is adding weight to the "rear fulcrum" and in that not adding any weight that is trying to be balanced out. errr that is completely not correct either. yikes it has been way to long since being in school. i done forgot the "depends" or the "except" words being repeatedly being said...
If you fill the tires, but it isn't enough to hold the rear end down yet, then when you lift with the loader and the rears take off, you have put the entire weight on the front axle, just as mentioned before, but now it is even heavier than it was when not filled. If they lift, it's all on the front. The only way is to counter it behind the rear axle. Even then, if it lifts, it's just that much heavier. You have to have enough back there (or far enough back) that it can't lift off the ground. Once you achieve that, you add even more and it starts to transfer weight back to the rear axle.
/ Operating loader without rear ballast #23
Precisely what I was trying to convey, just in different words:thumbsup:
/ Operating loader without rear ballast #24
ok, two fulcrum points, but... you are still stressing the chassis.
/ Operating loader without rear ballast #25
You stress the chassis every time you do anything with the tractor. That is why they are built and designed heavy enough to handle the stresses they are able to put on themselves
/ Operating loader without rear ballast #26
Exactly. That's why two tractors with the same power but different weights
will have one out working the other.
/ Operating loader without rear ballast #27
I played the I don't need no stinking ballast game for a couple years. You will not believe the differance in lifting and moving any load with a few hundred pounds on your back. Just the better ride and control is well worth the couple hundred spent, not including getting rid of the pucker factor.
/ Operating loader without rear ballast #28
No doubt in my mind about that LD, but when they don't understand, ya gotta try 'splainin' in different.
/ Operating loader without rear ballast #29
I agree with LD1 and Raydakub
And special thanks to the artistry of Boggen for this jem that helped us understand what a tractor looks like - lol. Can I have this for my avatar?
Seriously, Boggen I want it!
/ Operating loader without rear ballast #30
Thanks BOGGEN
"boggen" tractor coloring fun on T B N
save the image and paste in paint
here is mine:)
/ Operating loader without rear ballast #32
use the noted picture to your hearts content, you asked, good enuf for me, to return the respect.
Thanks BOGGEN
here is mine:)
View attachment 292927View attachment 292929
wow! little bit of color. really made that pic! nice job!
/ Operating loader without rear ballast #36
if the tractor is a 4x4 just keep it in 4 wheel drive when you lift anything ..it will save your *** trust me been there done that
/ Operating loader without rear ballast #37
Yes, 4wd is good to use no matter WHAT you lift. But it still isnt a safe substitute for proper ballast
/ Operating loader without rear ballast #38
The two fulcrum point explanation fits my experience. My JD510 is a 20,000 lb machine, and would guess roughly 90% of that weight is on the rear.
I like to use it to compact soil during construction projects. I heap the front bucket with gravel and to put more of that weight on the rear for compaction purposes the backhoe boom is lowered slightly with the stick extended outward so as to move most of the backhoe weight farther aft. There are times when the backhoe bucket is full of gravel too. What this does is transfers much of the gravel weight in the front bucket to the rear tires for more compaction. This is a two wheel drive unit, so if the front becomes too light to steer, the brakes can be used to assist the steering.
The whole point in this discussion, is adding and transferring weight to the rear has the tendency to lift the front.
/ Operating loader without rear ballast #39
I am posting late in this thread. My dealer won't sell a new tractor with a FEL unless the rear tires have ballast. Just a thought.
/ Operating loader without rear ballast #40
OK! Here's my question. Want to use my EX450 for truck garden farming. If the rear tires are loaded, will this tend to compact the soil and negate the tilling process? Would it be better to load the rears or to fabricate a load box that could be picked up on the 3 point when using the FEL and dropped when farming?
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
Landpride PL3048 (A64126)
Landpride PL3048...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
John Deere 348 Square Baler (A65579)
John Deere 348...
