Operating loader without rear ballast
/ Operating loader without rear ballast #1
RonnieB2
Blue, Texas
Branson 2910i
Hey there,
I'm a relatively new owner of a Branson 2910i with 4wd and a BL-20 loader I just had installed. I was recently talking with my brother, who has a John Deere of similar size. A dealer told him he shouldn't operate his loader without some sort of ballast on the rear, as it will ruin the front end (bearings?). I understand the need for rear weight for trying to life anything heavy, but never thought about the other issue. Can anybody fill me in on this?
Thanks alot.
/ Operating loader without rear ballast #2
Without enough weight on the rear of the tractor, every time you pick something up with the FEL you are in effect trying to tip the tractor forward and stand it up on the front axle -- meaning the front axle is carrying the entire weight of the tractor AND the load in the FEL. Whether this causes damage in the near- or long-term is dependent on about 87 different factors.
For this reason, suitable ballast at or behind the rear axle is needed. Filled tires and/or a heavy implement (such as a ballast box) are the solution(s).
Wrooster
(*) By the way, if you ever do find yourself in a situation with the rear wheels of the tractor off the ground (TPH ballasted or not) -- do not let go of the steering wheel unless you really like excitement...
/ Operating loader without rear ballast #3
tetter totter effect.
no ballast on rear = front tires. will end up seeing more weight being placed on them.
when there is more weight on rear. the "fulcrum point" changes. below the tetter totter errr on the tractor. further back towards rear wheels. other words. if you added a huge amount of weight on rear end of tractor. the tractor would end up doing a "wheelie" were front tires come off the ground. *been there done that* disc, and bush hog i have for the old allis chalmers tractor will get front end to want to easily come off the ground.
your "MANUAL" for tractor / FEL should state approx how much weight to add to rear of tractor. when doing FEL work. so the correct ratio of weight on front tires and rear tires is placed. and help prevent flipping tractor backwards doing a wheelie. or prevent doing a front wheelie.
a heavy 3pt hitch implement, such as a box blade, rear blade, bush hog. etc... many folks have used as rear ballast weight. if tractor is more dedicated and/or you will be maneuvering in ugly sharp small areas. a rear 3pt hitch ballast box can help reduce how much sticks out behind the tractor.
many folks fill rear tires with a fluid. rear tires with fluid adds weight, and the added weight is not placed on the axle. the added weight is also lower on tractor, and helps lower "COG" (center of gravity). and can help deal with tilting (working tractor on hills). be careful some fluids can be toxic, if they leak, some fluids can rust the rim out. it is normally not that expensive, to get a "tube" installed. tube might help prevent a leak from a thorn or nail as well. due to some extra thickness of rubber thorn or nail has to stick through.
some folks go with rear wheel weights. they bolt onto the rim / rear axle.
one of the regular maintenance things. more so when ya know you will be doing FEL (front end loader) work. is verifying you have front wheels PSI up to were it needs to be. to low PSI in front wheels, and risk running the tire right off the rim.
/ Operating loader without rear ballast #4
Pretty much what everyone else has said. Get proper ballast before you pick up anything with the FEL. Even picking up the empty bucket and traveling with it high in the air (always a no no) can be scary. Some dealers will not let a tractor with a loader out of their dealership without having proper ballast (box or implement) on the rear. As others have said, filling tires or weights is also recommended for the times when the loader is off and a heavy rear implement is on the 3pt. This will aid traction, and also stability. I made it a point when I got my last new tractor off of the truck, without any 3pt ballast, to go over to the gravel pile and scoop up a load.. talk about scary:shocked: even with loaded tires.. You need that ballast for sure.. I see newbies on you tube all the time trying to use their loader without ballast, and it just scares the he77 out of me!. And then they take off with the loader bucket up higher than the hood.. No wonder so many of tip overs occur in the first few days of tractor ownership. We see and hear about them here on this forum all the time.. But if you want tip over trouble, just don't put anything on the 3pt, get a big scoop of something heavy and drive around with it on uneven ground with the bucket as high as can get it. Be safe out there.
James K0UA
/ Operating loader without rear ballast #5
It should be said that loading the rear tires, while improving some things, does not reduce the load put on the front axles. For ballast to achieve that goal, it must be behind the rear axle. It must, in effect, attempt to wheelie the tractor. Only that effect is reducing load on the front axles.
xtn
/ Operating loader without rear ballast #6
xtn
Agreed- the same amount of weight is bearing on the front end. If the front bearings won't handle the load, then the tractor shouldn't have a loader on it. No sense in paying hard earned money for something that isn't designed to do the job that it is designed to do, or something to that effect.
My dad has a New Holland 3930 with a loader. The rear tires are loaded, but that's it. We've never needed ballast, and wouldn't use it because it would increase the length of the tractor.
/ Operating loader without rear ballast #7
to say nothing about the pucker factor when it wants to roll over on you. (this is the short version of all said above):D
/ Operating loader without rear ballast #8
Try driving down hill and stopping or backing up grade without balast with the FEL attached.
Its a treat
Weight behind the rear axle is great!
/ Operating loader without rear ballast #9
Its a treat
That going down hill can get pretty "sporty" real quick.
James K0UA
/ Operating loader without rear ballast #10
Hey there,
Thanks alot.
One thing to consider also, look at the size of the front end and then look how beefy the rear end is. If the rear is properly loaded with a ballast box and weight box and maybe even wheel weights, the rear end will be planted even harder and do most of the work then. You want the read end to handle the bulk of the pushing and straining. With all the weight in and on the rear end you shouldn't wreck any bearing in the front.
/ Operating loader without rear ballast #11
when there is more weight on rear. the "fulcrum point" changes. below the tetter totter errr on the tractor. further back towards rear wheels. other words. if you added a huge amount of weight on rear end of tractor. the tractor would end up doing a "wheelie" were front tires come off the ground. *been there done that* disc, and bush hog i have for the old allis chalmers tractor. will get front end to want to easily come off the ground.
n.b.
I may not be the first person to tell you this but proper punctuation (including the use of commas and periods when appropriate) *may* help you get your points across much more effectively. Reading and comprehending the two paragraphs above is somewhat tedious.
Wrooster
/ Operating loader without rear ballast #12
n.b.
Wrooster
*smiles* WYSIWYG (what you see is what you get). it is me. i got into habit long ago, and doubt i will want to get out of the habit any time soon. there may be good and some bad with current habit. and willing and wanting to take both at current, and happy with the outcome. *shrugs* my priorities are different.
/ Operating loader without rear ballast #13
Actually, liqued ballast and/or wheel weights has the ability to put MORE force on the front axle than without anything in the tires.
But a good combination of ballast AND a counterweight is reccomended for safe operation. I dont know the specs on your tractor, but just guessing that it is a 39HP with a FEL that can lift in the 2k lbs range. If that is the case, 1000lbs+ on the 3PH would be my reccomendation. And a good HD 6' rotary cutter fits that bill about perfectally.
/ Operating loader without rear ballast #14
ok... I am a math teacher... adding ballast to the rear does NOT change the fulcrum point. Think of a teeter-totter in the park (well they used to be there). In fact, adding ballast to rear ADDS weight to the front axle, whether using loader or not (some of the weight is distributed through the chassis).
/ Operating loader without rear ballast #15
Umm, you gotta get outta your books. If you add just enough to balance your loader (and the load), then yeah, it rocks on the front axle. We're talking about adding way more than that. You add enough weight to the rear end (and that means BEHIND the rear axle), you do a wheelie. Hunt around for a bit for an excellent explanation from joshuabardwell. Best one I've ever read.
/ Operating loader without rear ballast #16
There are two fulcrum points. The front axle and the rear axle.. when you add weight to the system behind the rear axle it unloads the front axle. Here is an example.. put 10,000 pound on the 3 point. What would happen? The front of the tractor would go up in the air. When you add weight in front of the front axle it unloads the rear axle.. I have Personally done it to the point the rear tires come off of the ground and it is not fun. The ideal situation is ballasted so that the front tires stay on the ground and the rear tires stay on the ground, and the front axle is not overloaded (which is easy to do because of its smaller size).
James K0UA
/ Operating loader without rear ballast #17
Uh, yea, what them two said:laughing:
Two fulcrum points is spot on.
Adding weight in the form of liquid tire ballast OR wheel weights adds NOTHING to the front. ONLY the rear. But it also does NOT take any weight off the front which is the goal with a counterweight.
There IS the possibility to put MORE weight over the front with ballast. Best way to explain it is by the following example:
Lets say the tractor weighs 3000lbs, and the loader can only lift 1000lbs before the rear comes up into the air. Thats 4000lbs total and ONLY over the front axle.
Now lets add 500lbs of ballast to the tires. The tractor now weighs 3500#. And with the added ballast, you can lift more in the loader before the rears come into the air. Lets say it can now lift 1500#. Now the total weight is 5000# over ONLY the front wheels.
Thats the idea of having something BEHIND the rear axle sufficient enough to change the fulcrum point to the rear axle. Now THAT weight is taking weight OFF the front axle because it is behind the rear axle. But the point being that the weight is heavy enough to to shift that fulcrum point. Cause if you dont add enough, and the loader can still make the rear end come up, all that weight you added is NOW over the front axle plus whatever additional weight you can lift in the loader vs without to get to that tipping point.
/ Operating loader without rear ballast #18
picture, to go along with folks comments above.
adding fluid to rear tires, or adding rear wheel weights. i do not see how could add more weight to front tires.
if anything front tires, would see total tractor weight (minus) not counting fluid in rear tires and/or rear wheel weights.
other words, tractor would still trying to do a front wheelie. but rear tires being held down, by fluid in rear tires and/or rear wheel weights. ok bad statement, fluid in rear tires, and/or rear wheel weight. is adding weight to the "rear fulcrum" and in that not adding any weight that is trying to be balanced out. errr that is completely not correct either. yikes it has been way to long since being in school. i done forgot the "depends" or the "except" words being repeatedly being said...
adding rear weight behind the rear axle.
depends on how far the weight is placed behind the rear axle. and how much the weight actually weighs. and the resulting effect it has on reducing weight on front tires.
ok, i give.
/ Operating loader without rear ballast #19
Adding weight behind the rear axle acts as a lever arm.
Take a specified weight, the further it is behind the rear axle, it will act to pry the front end off of the ground in relationship to the distance it is placed behind the rear axle.
/ Operating loader without rear ballast #20
I tried using my machine, a Pasquali 993 w/FEL with out the ballast box just for a tractor parade, this past summer. Almost had to go home & change my shorts while pulling off the trailer! FEL acted like a wheelie-bar, rear-end came up, quick, fast & in a hurry. Articulating machines don't steer with one set of axles in the air! Had to keep the bucket 2" off the ground during the parade, every bump jolted the rear into the air. Learned my lesson for next year's parade.
Shadow
East Texas Gooseneck Trailer (A65563)
East Texas...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Case TV450B (A64126)
