Buying Advice L3200 Dt 4wd question
/ L3200 Dt 4wd question #1
SandandEight
Enterprise, Ms
2012 L3200 DT 4wd
I am thinking of buying a new L3200dt 4wd with front end loader. I was wondering if the 4wd is selectable or all time, also can you lock the differentials?
/ L3200 Dt 4wd question #2
Selectable and yes you can lock rear diff.
Well I pulled the trigger. Just ordered a L3200 DT 4wd with frontend loader. I never knew I would be this excited about a tractor it should be in next Friday. I am glad that I didnt get suckered into the Green fad.
/ L3200 Dt 4wd question #5
I believe you will be quite happy with it...For the money its a very good tractor. I'd have the dealer fix the 3pt hitch jerkyness before leaving with it.. If you have any questions about it send me a PM.
/ L3200 Dt 4wd question #6
Congratulations on the new tractor!!!! I am with you on not doing the Green thing. I have turned the corner and not looking back. Since I have decided to go orange again, I do not even seem to hurt my neck as bad everytime I go by a JD dealer :)
/ L3200 Dt 4wd question #7
Fine tractor! Congrats!
/ L3200 Dt 4wd question #8
I'm new to the forum, and was thinking about buying a L3200dt loader as well. I was wondering if I can use the L-- R as a shuttle to go back and forth? In other words, keep it in 2nd and use the forward back for using the loader Thanks for your help.
/ L3200 Dt 4wd question #9
Welcome!
Yes you can, but you have to use the clutch. I do it all the time.
/ L3200 Dt 4wd question #10
thanks, I was hoping for that answer.
the dealer said that the clutch worked 1/2 way to shift and all the way to stop the PTO, is that the case with the DT model?
/ L3200 Dt 4wd question #11
No, the L3200DT just has a single stage clutch, no halfway stuff. The L3800DT works like your dealer said.
/ L3200 Dt 4wd question #12
thanks, that is what I thought. Does the PTO slow down significantly to cause a problem when at the end of a row in the case of tilling/mowing?
/ L3200 Dt 4wd question #13
No, not too bad on a rotary mower, a finish mower will likely stop as will a tiller though.
I really like the two stage clutch on the 3800! :)
/ L3200 Dt 4wd question #14
When i bought mine I looked at the L3800 and passed because I didn't need the extra hp. However I wish now I would've bought it for the double clutch. It's worth the extra 1k if not for the HP def for the double clutch....
/ L3200 Dt 4wd question #15
makes me think once again, as I do not want to be disappointed. I will have to ask for the price difference and see. I also have a width issue, as I have areas of tight woods and trails will limit passage, but looking at it now, they are the same width.
/ L3200 Dt 4wd question #16
They are the same size. Like said the 2 stage clutch is worth the difference and the extra HP is nice when needed. Price was pretty close when I was comparing. The L3800dt has surpassed my expectations, no regrets here. :)
/ L3200 Dt 4wd question #17
Each are great tractors.Considering I bought mine mainly for bushogging, i regret not getting the "live" pto. Granted it's a 1K I saved, but honestly i spend more than that each time I buy a new gun.lol. Now you take a L3200 with a "live" pto and actual syncro tranny and you will have a ultimate compact tractor for the money. If Kubota builds that I will never look at another Grand L in the future.
/ L3200 Dt 4wd question #18
I tried the Mahindra syncro tranny and was impressed, but the loader was just too low to the ground for me. I am waiting for the price for the l3800 though.
/ L3200 Dt 4wd question #19
My dealer said it would be around another $1k for the l3800 upgrade and another $1k for the Hst. Just to give you idea.
/ L3200 Dt 4wd question #20
hard decision, not sure what I have planned would justify the extra 1K, some tilling, hogging, I have not even been able to try a gear drive here (south fl), since they are crated until a new owner wants it. Hence the multiple schizophrenic hesitations.
