Buying Advice L3200 Dt 4wd question
   / L3200 Dt 4wd question #11
thanks, I was hoping for that answer.
the dealer said that the clutch worked 1/2 way to shift and all the way to stop the PTO, is that the case with the DT model?
No, the L3200DT just has a single stage clutch, no halfway stuff. The L3800DT works like your dealer said.
   / L3200 Dt 4wd question #12
thanks, that is what I thought. Does the PTO slow down significantly to cause a problem when at the end of a row in the case of tilling/mowing?
   / L3200 Dt 4wd question #13
No, not too bad on a rotary mower, a finish mower will likely stop as will a tiller though.
I really like the two stage clutch on the 3800! :)
   / L3200 Dt 4wd question #14
When i bought mine I looked at the L3800 and passed because I didn't need the extra hp. However I wish now I would've bought it for the double clutch. It's worth the extra 1k if not for the HP def for the double clutch....
   / L3200 Dt 4wd question #15
makes me think once again, as I do not want to be disappointed. I will have to ask for the price difference and see. I also have a width issue, as I have areas of tight woods and trails will limit passage, but looking at it now, they are the same width.
   / L3200 Dt 4wd question #16
They are the same size. Like said the 2 stage clutch is worth the difference and the extra HP is nice when needed. Price was pretty close when I was comparing. The L3800dt has surpassed my expectations, no regrets here. :)
   / L3200 Dt 4wd question #17
Each are great tractors.Considering I bought mine mainly for bushogging, i regret not getting the "live" pto. Granted it's a 1K I saved, but honestly i spend more than that each time I buy a new gun.lol. Now you take a L3200 with a "live" pto and actual syncro tranny and you will have a ultimate compact tractor for the money. If Kubota builds that I will never look at another Grand L in the future.
   / L3200 Dt 4wd question #18
I tried the Mahindra syncro tranny and was impressed, but the loader was just too low to the ground for me. I am waiting for the price for the l3800 though.
   / L3200 Dt 4wd question #19
My dealer said it would be around another $1k for the l3800 upgrade and another $1k for the Hst. Just to give you idea.
   / L3200 Dt 4wd question #20
hard decision, not sure what I have planned would justify the extra 1K, some tilling, hogging, I have not even been able to try a gear drive here (south fl), since they are crated until a new owner wants it. Hence the multiple schizophrenic hesitations.
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
