Grapple up, now or later?
/ Grapple up, now or later? #1
Bfitzgerald3
Harbor springs, mich
Kubota Mx5100
I have a kubota MX5100 on order w/ a single rear remote. Delivery is scheduled for three weeks. This will be my first tractor experience... I just bought a large parcel (157 acres) and never had a need.
The property was bought in foreclosure. The previous owner had it logged (butchered if you will) and about 60 to 70 acres are covered in tree tops/limbs from the high value timber they removed. I would like to remove the evidence of pillage and am just realizing that a grapple might be my best friend.
I admit that I haven't learned enough aout grapples to ask truly intelligent questions...however, with a good loader already coming, should I consider getting an attachment for it or a regular grapple? If you were me, would you pony up for a third function valve on the front now or wait til u have funds to get the attachment? Realistically I'm looking a clearing the carnage next fall.
Thanks!
/ Grapple up, now or later? #2
Yes - get it! Adding remotes later is easy on the 5100 (Took me about an hour at the most two add my second one)
The grapple has saved me SOOOOOO much time it is unreal. When a tree is down and you can make 5 cuts, grab it move it and dump it in your burn piles in 20-30 minutes instead of spending 3 Hrs doing it all by hand it is priceless! After the last big storm we had 5 trees over our road and I had it cleared in about an hour with the help of my neighbor- he made a few cuts and I was moving the trees and brush. We even opened the public road so EMS etc could get in if need. When you have land and trees they are GREAT!
/ Grapple up, now or later? #3
Grapples are great, if you can burn the piles, if not you might want a chipper. I don't use my grapple any more, since I got a chipper. YMMV.
/ Grapple up, now or later? #5
I used to grapple the logs out to a pile and cut them up later.. big mistake, trying to cut in a pile is nuts. I'd have to think that making a pile to pull it apart to chip would be a mistake too, but what do I know.. :confused3:
Now I just drop it, cut the logs to size, move them with the bucket, chip it up into barrels, and dump it in with the chickens.
(he'd need a lot of chickens tho, with 60 something acres..)
/ Grapple up, now or later? #6
I would get the third function now if you are not the mechanic sort and will have to have the work done for you later.
I am in the process of adding 2 remotes to my tractor now.
The cost of doing it yourself is less expensive, but you need to be somewhat mechanically inclind or have some help available if you are not.
I am not buying a factory setup/ rather fabricating all my own brackets etc.
I just built my own bucket grapple and am anxious to use it this spring.
Tom
/ Grapple up, now or later? #7
I can't really imagine cleaning up 70 acres of logging slash with a tractor, your biggest problem will be keeping sticks from ripping up the bottom of the tractor. But I'm sure you can atleast clear some areas and trails and you'll love a grapple for that. My place had some logging done by the previous owner and it took a few years for the tops to rot down, but nature took care of them with zero tractor damage. Also depending on how many deer you have, the tops can protect young trees while they get tall enough not to be topped by deer. We have very few small deciduous trees in areas that weren't cut, but now the regrowth in the cuts is alot of maple and and some oak.
The tops and limbs are largely clumped into piles of parallel pieces...ready to be grabbed and dragged. Seems perfect for a grapple. I hope to pile it in a safe place to burn.
As I hunt around, some of the units I see are referred to as rakes, some as grapples. The front rakes seem to be better set p to do what I need....drive In to a pile, grab, pull, stack, burn.
Is the third function required for either option? Easy to do as a DIY project? Cheap enough to have the dealer install to save some time?
As for chickens, I'm tring t convince the significant other to get more than a handful...organic free range eggs are crazy expensive here. Seems like if we do 6, we could do 30.
/ Grapple up, now or later? #9
You may be able to have the third function added at the factory.Be carefull of the weight of any grapple you purchase.The heavier the are the less you can lift.I added a thumb and tooth-bar to my HD Roundback bucket.Works for me.
/ Grapple up, now or later? #10
Just FYI - I have a 48" grapple on my 50HP and it is plenty wide enough and keeps the weight down (that is good advice) - the less grapple weight the more you can move and lift
/ Grapple up, now or later? #11
Personally with that much land to work I would start with a M7040suhd if it must be a kubota. Just the 24 inch front wheels will make life easier in your described enviroment and its only 5 grand more but with all capabilities increased. Get the third function from the factory and all the rear remotes you can. Get a big grapple that is designed for forestry cleanup thats at least as wide as the front tires. just my 2 cents.
/ Grapple up, now or later? #13
I agree about the 6 vs. 30 (or 60..) Free range eggs are probably expensive because free range chickens only last about a day, around here anyway.. I only let them free range when they stop laying. ;)
/ Grapple up, now or later? #14
Grapples are awesome! I think I've used mine more then my FEL. It's well worth the money. I'm in the process of cleaning up 20 acres for a home site and its been a great tool for brush and logs.
/ Grapple up, now or later? #15
A grapple is a wonderful tool, and you won't be sorry you bought it.
For what it's worth, here's my long-winded experience installing a W.R. Long 3rd function kit on my MX5100, just in case you decide to go that route.
http://www.tractorbynet.com/forums/kubota-owning-operating/192572-w-r-long-kit-plus.html
If you get a grapple and use it to clear slash, I highly recommend you make a couple of mods to prevent limbs from damaging your equipment.
http://www.tractorbynet.com/forums/owning-operating/195968-everybody-loves-guessing-game-6.html#post2276991
http://www.tractorbynet.com/forums/customization/195153-added-grill-guard.html#post2240129
/ Grapple up, now or later? #16
Thanks!
I have an mx5100hst and I use it much like you plan to use yours. I had the dealer install the wr long third function when I bought the tractor and they did it for little more than the cost of the valve. I run a 56" wr long obg2 grapple and I absolutely love it. I wouldn't consider a grapple that weighed much over 500 pounds for the mx. I have moved lots of logging slash and LOTS of logs with it already. I think you will be well satisfied with your tractor and grapple combo.
/ Grapple up, now or later? #17
Absolutely get a grapple. I and many others here are quite pleased with our 48" WildKat econo grapples. Don't order online, call Anita for the best deal.
/ Grapple up, now or later? #18
Just ordered a 60" grapple from MIE and the hose kit for my Kioti DK 40.
Spoke to the dealer today. A third function, installed would run about $900 and isn't a standard option for the MX5100. Said it could still be done, but still recommended that I wait until the grapple becomes a reality, then run lines from the rear remote to the front... Maybe $300... it "won't be as pretty, but it will save a lot and most people don't end up using them too much." If I were using it regularly, he thought it would be a good idea.
I'm sure there are other opinions here on what would be best for my situtation. However, I have a lot of respect for a dealer that will give advice that earns him less money.
Thanks to all for their advice. A grapple is in the future, for sure!
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
211298 (A62131)
211298 (A62131)
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
