Non-Contact Infrared Thermometer
   / Non-Contact Infrared Thermometer #1
DFB
Elite Member
Southern VT, Southern ME
John Deere 4100 HST /410 FEL, R4s
...with Laser!
So who has one???
I want to get one of these. I'm sure it will more than earn its keep around my house even more so in the garage and I might even check the grease temp in the new apple cider donut machine I just installed down at the Orchard where I work too!
So today I went looking online (Amazon) and quite frankly found the amount of choices pretty overwhelming. Prices ranging from less than $20 to easily way up over $100. I will assume the cheapest is nothing more than imported junk without much accuracy though many great reviews from ghost hunters and those seeking other paranormal activity.
At about the $40-$50 range buyers seemed to be generally pleased with models such as the Actron CP7876, Kintrex IRT 0421, Micro Temp MT Pro, and the Maverick LT02 though consensus still varied on accuracy, maybe from a lack of emissivity adjustment on these units for the objects being measured? But....from there its not much more for a lower end professional brand name Fluke 62 MINI , Klien IR1000, or Greenlee TG1000. Theres also 2 professional offerings from WCI a product name I'm not familair with. All under $75. So that will be my self imposed cutoff point $75! I'm already leaning heavily toward the Greenlee for about $66 with its adjustable sensitivity though I cant find any independent reviews online about it.
Whats good? What not? What will do the job? Is emissivity compensation THAT important for most things you do with them? What about warranty? The Kintrex IRT clearly states a 2 year warranty. Battery? Looks like AA or AAA is prefered power source to 9V The 9v being found mostly on the cheap ones. I do take pride in my tools, I have quality name brands they earn me a living a lot of times along with a few Harbor Freight tools that dont suck :)
   / Non-Contact Infrared Thermometer #3
I use a Fluke 566. But it is $400+. And it is for work, so extra cost was not issue.
The questions I would ask first, is what range of temp do you need to measure, and how much accuracy do you require. From that info, pick one that matches closest to your price range.
   / Non-Contact Infrared Thermometer #4
We have a Raytek the shop owns and I have a $49 Sears unit in my road tool set. Both work well and are indespensible. Biggest downfall to IR thermometers is not thinking of how to use one to troubleshoot a problem. Dead nuts accuracy isn't very often important; usually you are looking at temp differences between different test areas. For example, I have had 100% success identifying a single leaking hyd cylinder piston of a pair in parallel such as a FEL using an IR gun and without cracking loose any fittings or spilling any oil. Oil passing by a leaking piston seal will raise the piston and barrel temp in the area beyond that of the rest of the cylinder.
   / Non-Contact Infrared Thermometer #5
I have one from Horrible Fright. I bought it originally for cooking, but it it helpful for lots of things. With a sale or coupon, it should be about $40. When I first got it I did a lot of things to determine accuracy. It seemed pretty good, and has lasted for a few years now.
   / Non-Contact Infrared Thermometer #6
I have a Mastercool brand unit, two AAA batteries, model # 52224-A. http://www.mastercool.com/media/thermometer_flier_LR.pdf $49 at Amazon now.
Mine was a gift three-four years ago, still works fine, battery life is fine. Seems to be consistent and accurate for 50* - 100* range. I haven't tried it on hotter things.
   / Non-Contact Infrared Thermometer #7
Consider these 3 aspects when buying an IR Gun
Emissivity- Adjustable is good but it depends on what you are using it for.
Spot size- sample spot of 1 inch at a given distance. 8:1 is 1 inch spot at 8 inches away from the gun.
Temperature Range- what are you looking to measure and buy a gun to cover this range.
Here is a link to WW Grangers and I gathered some IR guns to compare.
Kenny D.. I see Raytek on there too. One reviewer says the model MT6 is the same as Fluke 62 and that Fluke owns Raytek. Mostly 4 and 5 star reviews.
Robert N... I'll give thought to that heat range thing. Most of them list high end measurements in either 700+ or 900+F range.
Rick B... Good example and great point you make. I read on one review where a failing wheel bearing on trailer was recognized by the heat difference as opposed to the other wheels.
   / Non-Contact Infrared Thermometer #9
I have used mine to check the tire and hub temperature on my trailers while traveling. I have also used it to validate the temperature on my welding rod ovens.
Thks guys! Seems like they all work pretty decent hey...
On that point spot its seems they most range 8 9 10 or 12. I would think the farther away the better?
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
