Tractor Sizing Tractor Recomendations please $5k and under
/ Tractor Recomendations please $5k and under #1
Kenn1320
Howell, MI
LS2030H
Id like to get some advice from guys that have tractors, since Im new to all this. Im looking for a tractor that would be good for moving snow(1/4 mile drive way) and simple food plot type work(mow/disc or till/cultipack). Im looking for used and trying to stay under $5k. I live in MI and the annual snow fall is all over the map. I could probably get by with an ATV, but Id like to get a tractor. Any advice would be greatly appreciated.
thanks,
Ken
/ Tractor Recomendations please $5k and under #2
I have a 2003 Kioti CK 20 gear drive with 4wd and FEL that I gave 5k for about 2 years ago. It is not very big, but in my opinion it is a lot of tractor for the money. If you want bigger, you will have to go a older and probably 2wd. Good luck.
/ Tractor Recomendations please $5k and under #3
I would look at a 4wd Yanmar Diesel tractor. Parts can be obtained via hoye tractor and Yanmar Diesels are very reliable. I purchased a YM169D (16 hp 4wd) for $2800 and it was a great little tractor. Pair that with a loader and you will have it made in the shade. :thumbsup:
/ Tractor Recomendations please $5k and under #4
thanks,
Ken
What are you looking for? What implements would you like to run? Implements would determine the HP size. Diesel or gas? Do you want a FEL on your tractor?
If I get pto driven implements, I would be looking at a 5ft brush hog, 5ft tiller, maybe a 2 stage snow blower.
/ Tractor Recomendations please $5k and under #6
Having owned a 1964 MF135 diesel for twenty years that was a great tractor I am partial to the MF135's. I would say if you looked around you could find a nice one in this price range.
/ Tractor Recomendations please $5k and under #7
It is an interesting question. What used tractor in the $5000 range will give the best value? everyone will of course champion the tractor they have in the yard, just human nature don't you know. You can't expect a used tractor in that price range to be trouble free and of course it is beyond any warranty so it becomes what you paid for it plus anything you have to have repaired on it to make it go for the next five years or so. And you might add in ( and this can be a big one) how much you will pay to rent a replacement tractor while yours is in the shop and you have work that "Has to be done". Shop carefully. A worn out green tractor is just as worn out as a red , orange or blue one.
OK guys, found a couple tractors that seem to fit my criteria. Share your thoughts, both in terms of reliability, potential repair cost differences, functions/features that are good bad, etc. Basically do you feel these are a good match for me and if so which one and why.
MF130 Perkins Diesel 2100hrs well maintained in very good condition(their words, not mine), 4spd hi/low trans, live power, pto, newer tires and battery, tool box, extra lighting, $4900
Ford 3600 3cyl diesel 4200hrs, 8fwd speeds/2rvs, tires and rims are good(not loaded). He replaced a tube in one rear, water pump new 2yrs ago, injector pump rebuilt 2yrs ago($1800), 1 remote out back. $4500
thanks,
Ken
/ Tractor Recomendations please $5k and under #11
MF135 Perkins Diesel 2100hrs well maintained in very good condition(their words, not mine), 4spd hi/low trans, live power, pto, newer tires and battery, tool box, extra lighting, $4900
thanks,
Ken
Prices seem high. I paid $3600 for a 1964 MF135 diesel deluxe in Jul06.
I suppose you're planning on using a rear blade with these for snow removal?
Good luck
/ Tractor Recomendations please $5k and under #12
old fords are probably the most popular in our area (mid mi). you can probably find a fixed up 8n with all the attachments you want for way under $5k
I have been told by many to stay away from the 8/9n tractors.
Good luck
Yes looking to use a rear blade for snow removal, so filled tires and or weights and chains will be needed. Ive seen a few with front blades, that would probably work better.
/ Tractor Recomendations please $5k and under #15
repeat.
/ Tractor Recomendations please $5k and under #16
That MF is a 130 not a 135, is that correct? . Why is a 9n bad? A 3000 series is better.
/ Tractor Recomendations please $5k and under #17
You have to know how to evaluate those old Fords. Many of them have wornout engines and drive trains that will require rebuild. Three of my neighbors have bought old 8Ns. One had low compression and needed an engine rebuild which he did as a restoration project. Another neighbor tried to use his 8N with an old IH wire-tie baler he bought without using an over running clutch in the pto drive and managed to twist the internal pto shaft into a corkscrew. The 8N doesn't have an internal ORC. The third neighbor made the mistake of buying an 8N without thoroughly checking it out. Another case of low engine compression and there it sits awaiting an engine rebuild (unless he dumps it at a loss).
Murphy good catch. In my mind I thought it was a 135, but it is a 130. These 2 tractors are apples/oranges, thanks for bringing that to my attension.
/ Tractor Recomendations please $5k and under #19
The 3 thousand series tractors are good models, are these at a dealer?
/ Tractor Recomendations please $5k and under #20
Both tractors would easily fill your niche for food plotting and snowblowing. Both have live PTO which is a real bonus for snowblowing/tilling. The ford has the bonus of 10 more Hp over the MF and a rear remote which would be nice if you ever decide to pull implements with a hydraulic lift cylinder. IMO I feel both are priced a little on the high end. I would say 3500 max for about either of them. If they don't bite no worries there are plenty of tractors for sale in Michigan that will fill your need.
8n/9n's are great little tractors if all you have to do is haul stuff. Their major limitation is there lowest gear is still generally too fast to run a tiller. These small ag tractors the: Ford Naa/jubilee, AC D-14, Oliver super 55(ended up buying one of these), IH/Farmal 504, and the MF 35 are about perfect for plotting up to 5ac All these models are mostly gas and can be picked up for about 2500. They are all in the 30-40hp range and offer some sort of live/independent PTO. Any tractor even an 8n will perform leaps and bound better than a quad for plotting. Quad implements usually aren't quite heavy enough and are far more $$$ than used farm implements.
A lot of these old tractors have a lot of life left in them you just have to be pretty thorough in looking them over. I always bring a compression gage with me to check the cylinder compression. This will give me a real quick idea of whether or not it has some worn rings or in need of valve job. Check for blue smoke. Run the tractor through all the gears/PTO, Stand on the brakes and see if the tires lock, then run the tractor in lowest gear and depress the brakes gradually (to create a load on the tractor) to see if the governor works correctly and the clutch isn't slipping. Don't do this for prolonged periods because sellers automatically think your trying to glaze the brakes and burn the clutch but you are the buyer and with these things all sales are usually final so it makes sense to check them out. Minor oil leaks from seals/gaskets are to be expected so I don't put much value on what is dripping. Most leaks from my experience are more of an eyesore than anything. Hope this helps with you finding a future tractor to fill your needs. Have any additional questions feel free to msg me.
2012 FORD F-550 SUPER DUTY (A63569)
2012 FORD F-550...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
