Gatormade trailers still gets C grade
/ Gatormade trailers still gets C grade #81
Never heard of Tow Max but have bought a couple dozen sets of Tow Master Trailer Tires and they are by far the best trailer tire I have had.
Are you sure they are Tow Max and not Master?
Chris
/ Gatormade trailers still gets C grade #82
I've been reading through this forum today. Yeah, I'm looking to buy a new equipment trailer for my tractor and equipment. Currently have a CHEAP entry level utility trailer, a Baker bought in Natchez MS. I think I paid $650 for it with "upgraded" tires. This was about 3 years ago. It came standard with old repainted Chevy 15" rims and used tires, but the upgrade was old repainted Chevy 15" rims with new China poppers on them. I upgraded to Maxxis tires about a year later, but had no problems with the tires that were on it originally. As for quality, it's been pretty good, I've had no real problems with it and I'd say as for reliability, it's done everything I've asked of it. My only real complaint is the ramp pins to lock it in the up position are just pieces of rebar torch cut and bent at a 90* angle and slipped through a couple of pieces of pipe welded to the trailer frame and the ramp frame. Oh well, it's worked to keep the ramp in the up position for these years LOL
As for paint, none on the bottom, but the 2x12's are pressure treated.
Just a comment about vehicle inspections and the suggestion that if all states had inspections, the highways would be safer... I lived in Louisiana for 20 years, owned up to 5 vehicles at a time. That state has annual safety inspections. I can state unequovically that I never had my brakes checked, never had my exhaust system checked. The entire safety inspection consisited of a horn check, wipers, turn signals and headlight check. NOTHING MORE..... so, mandatory state safety inspections isn't the answer, rather, I think holding the inspectors accountable for what they inspect (integrity) is more important than just paying $10 a year to get a sticker.... OK, I'll get off my soapbox now...
As for what I've learned in this forum: Gatormade used to make quality trailers, probably still do, but you have to watch what you buy and make sure it doesn't have any issues before you pay the money. They use "China made parts" but so do a great number of other manufacturers. I'd rather buy American, but I'm on a budget and I need to be conscious of what I spend. And, as pointed out in some posts, just because it says "American made" doesn't necessarily mean that the sum of the parts weren't made in China anyway.
What to do??? What to do???? I think next time I visit my daughter, SIL and grandkids in Cincinatti, I'm going to drive on down to KY and check out the factory. If I see something that fits my needs, and the price is right, I'll change out the Scotch connectors and bring it on home...
Thanks for all who offered observations and comments, I learned a bunch, but still don't know that Gatormade is any worse or better than any other trailer being sold around this area.
/ Gatormade trailers still gets C grade #83
You might want to call them and ask where their dealer is in Lexington or closer to you. The factory is pretty far off I-75 and it is not really setup for retail sales. There were hundreds of trailers there when I picked up mine about a month ago, but none that I noticed really sitting out for customers to examine. Most were stacked up for transport to dealers.
/ Gatormade trailers still gets C grade #84
Hmmm from the discussion I had asking questions on Ebay, they pretty much invited me down to check them out. I'll have to contact the factory and make sure that the "internet department" and the "real people department" are saying and thinking the same thing... :)
/ Gatormade trailers still gets C grade #85
I don't think I want to take the large decals off - who knows what the paint looks like underneath them! It's funny you mention the large decals, on the back of the neck there is a large one that has "GATor" trailers that looks very close to the CAT symbol. That one is coming off and being replaced with a Cummins decal.
I know this post is old but can someone tell me what is under the back axle of this trailer? It looks like a smaller diameter wheel (yellow in color) with a tire mounted on it right behind the right rear wheel. Its perpendicular to the axle it looks to me. Very strange. I can't figure out what it is.
/ Gatormade trailers still gets C grade #86
Mud flap with yellow writing / emblem.
/ Gatormade trailers still gets C grade #87
Black mudflap with a round yellow logo.
Aaron Z
/ Gatormade trailers still gets C grade #88
Darn if its not. I couldn't figure out what it was but now that you tell me i can see it.
Doh!
/ Gatormade trailers still gets C grade #89
Since this thread has been resurrected, I thought I might as well share my experience.
Yes, Gator Made still gets C grade.
You get what you pay for and I was well prepared after reading this and other forums.
A C grade trailer, though, is good enough for my needs.
Fair welding, fair powder coat, piss poor wiring. Like I said, I was prepared for that.
I removed ALL the wiring and replaced it.
My trailer is a 12' utility trailer with stand up equipment ramps ($100 extra).
With the tandem axles and stand up ramps, the trailer empty had negative tongue weight when I picked it up at the factory.
I removed the ramps and strapped them down in the front of the trailer for the 4.5 hour drive home. Otherwise the hitch rattle would have driven me to drink (more).
When I removed the ill placed and badly fastened down 2x8 deck, I discovered one wire had already slipped out of the Scotchlok to the left tail light. When I grabbed hold of the Scotchlok cluster f*** at the center of the rear frame, another wire fell out.
But like I said, I was prepared for the bad wiring.
The 16/6 cable (brake wire should have been 12 gauge) ran over the crossmembers with the deck boards screwed tight down against it.
/ Gatormade trailers still gets C grade #90
i have owned many trailers over the past several years and i use them commercially (EVERY DAY). i noticed many of the threads here about the gatormade gooseneck trailer. i just picked up a brand new 20+5 gatormade tandem dual 2013 model. i must say that they have out done themselves. this is the best quality trailer that i have ever owned, or have ever seen for that matter! i think gator made may have had a few years where quality was average. however, all complaints that i have read have been addressed. paint is now powder coat. no primer, no issues, just clean quality on every part of the steel structure. the i beam is 14" on the neck and frame (more heavy duty than any others that i can find). the tandem dual axles are all Dexter (the best that money can buy). the loading ramps are wide and very safe. wiring is completely sealed and out of the elements. all lights are LED lights. i bought this trailer because it is more heavy duty than any other trailer that i could find. so far it has been great.
/ Gatormade trailers still gets C grade #91
Powder coat always looks great at first, but tell us how the powder coat looks in 3-5 years.
I'll take an automotive primer/finish over powder coat anytime.
I have more powder coated stuff that the paint just peels off of that I care to admit.
Can't stand powder coating!!!
/ Gatormade trailers still gets C grade #92
Sniff, sniff, new poster who's first two 2 posts are praising Gatormade trailers and how great they are... Has a slight hint of astroturf.
Aaron Z
/ Gatormade trailers still gets C grade #93
AAron, I am not sure about the new poster.... I'm not going to pass any judgement, but as for my experience with Gator after being a part of this forum and asking questions 8 months ago, here's my experience.
In March/April of this year, I was looking for a trailer, responded to this forum and got some answers. Anyway, as I said back then, I was going to the factory next time I was down to southern Ohio to visit my kids. I went to the factory in late April, bought a 16' tandem axle flatbed trailer, upgraded the tires to radials for an extra $100 and towed it home. I've used it a number of times to transport my tractor and implements (about 5500 lbs). The GVW of the trailer is 7200 lbs and I'm at near max with the load I tow. So far, it's performed as expected, the wiring, lights, brakes, tires, paint have been reliable with non problems. The only thing I can complain about is the trailer tongue jack. It is mounted directly behind the ball coupler and it interferes with lowering the tail gate of the truck. I could solve this one of two ways, buy a lower hitch ball carrier (using a 2" now and trailer sits level) or buy a Curt extending hitch ball carrier. I have looked and can not find a shorter hitch jack that would sit below the tailgate and I don't want to change to a different location for the hitch jack because the battery for the brakes is mounted on the jack shaft. I'm reluctant to do any welding (powder coat paint) and so far, it's not been an issue. I'm thinking that the best option would be to buy the Curt extra length ball carrier and just watch for any sharp turns if the tail gate is down (I can't remember the last time I towed with the gate down).
Anyway, buying the trailer at the factory was cheaper than anywhere I could find the same trailer in Michigan. I'd say that not counting the trip (I was in Cincinnatti anway) I saved about $800 by going to the factory.
So far, with almost 7 months of use, I'm satisfied and feel it's been a good investment. ? Is it a "cadillac" of trailers, no, but is it worth the price? In my opinion, yes.
Shawn Mosley told me that Gatormade used to use Dexter axles and they had problems with the wheels coming off. So you, sorry, Gatormade are going back problematic axles? Shawn told me that they are using "American" axles when I bought mine. These "American" axles are 100% Chinese.
/ Gatormade trailers still gets C grade #96
I don't think there's an American made axle left to buy, is there?
I was told even dexter is going part Chinese.
/ Gatormade trailers still gets C grade #98
Well, I figured that there was at least some chance that a random happy Gatormade owner claiming to be from near their Lexington location was real...
Aaron Z
Thanks for the morning chuckle... :laughing:
/ Gatormade trailers still gets C grade #99
I agree. Looks good new but one a chip happens its all over. I carry a rattle can of touch up paint in my trailers tool box.
Chris
/ Gatormade trailers still gets C grade #100
Never had any trouble with my Dexster and Dexstar wheels. And yes they are American made. My trailers are Corn Pros though. Lol
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2019 Toro...
Hydraulic Breaker Excavator Attachment (A61572)
Hydraulic Breaker...
FLEX HEADER REEL FOR 20' HEAD (A63291)
FLEX HEADER REEL...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
